Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Green light blinking - Panasonic PT-40LC12
The TV stoped funtioning (black screen) - I checked the bulb and found to be all right. I saw few answers for the same question to check the fuse and check the voltage at the ballast. Please help me how to do those checks. Thanks and appreciate your help in advance.
  • 1 more comment
  • chrisstv Dec 17, 2007
    i have the panasonic pt 45lc12 tv and getting the green light blinking you know how to change the thermal fuse? I haven't done anything to resolve the problem yet.I don't think it could be the lamp as i just changed it about a month ago.I also have never had a green blinking light before.
  • lakeman Jan 22, 2008
    I'm not sure if my problem is related or not. I have the PT-50LC14 set which is about 2-1/2 years old. On start-up the green power light blinks normally about 7 times as if warming up and I can hear the fan running. At that point the set turns itself off and the green power light turns red (no blinking) iindicating the set is off. Repeated attempts yield the same result. We had this same problem when the set was less than a year old but it was so intermittent then that we did not call service. At that time we could try starting it a few times and it would eventually turn on normally. The problem went away until now. Have already tried cleaning the filter.
  • jalli Apr 28, 2008
    I got this resolved as per the recomendation by "ctf1800". Thanks a lot ctf1800. Thanks! Thanks! Thanks!!!!!. and Thanks FixYa
    I appreciate your help. It worked for me.
    Best Solution
    posted on Jan 28, 2008
  • 4,402 Answers
Found that the thermistor/temp measuring device is suspect, no resistance across legs. There is a label there that says F701 see service manual
I went here for a tech manual for the Panasonic
then ordered
Manufacturer: Panasonic
Part Description: FUSE
Part Number: LSJA0411-1
it was mounted to the case that holds the lamp. had to remove the back panel, etc. Also think I had to splice in the fuse or something. was a while ago.
i purchased a NTE8115 from my electronics supplier, closest I could find.
Radio shack also has them.
remove the back cover and measure for continuity across the thermal fuse
above the lamp housing.
if open jump it wth a 5 amp fuse, be sure to close the safety switch with
the small blue lever then try to power on.
If comes on ok you will need to replace the entire ballast assembly to get
that fuse.
Panasonic does not have a part number for just the fuse on the PT40LC
It is possible to cut off the fuse and replace with another but dont solder
Posted on Jan 28, 2008
After 6 days of inability to start my set, it miraculously started up last evening after I pressed and held the power button. Again the power LED flashed green 7 times, then red once then green again while I held the button in but this time the green flashing turned to green solid and the set powered up normally. (I had tried holding this button in several times earlier to no avail.) My problem is apparently not the bulb nor the ballast but rather some intermittency such as a bad solder joint or a connector that is intermittent. Anyone else experienced this sequence of symptoms?
    Problem Solver:
  • 16 Answers
Sent me the serial number, and I can check for any re-call ...
my e-mail is <>
Posted on May 22, 2008
When turningn on the power, the green light
Could be the lamp or balast your on the right track there you might want to check that..
Oct 04, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Power Supply!!! to all with this kind of problem, if you have a brand name get the supply rebuilt by tri state modules or pts corp. easy to remove and install yourself.
Jul 23, 2009 | Panasonic PT-40LC12 40 in. LCD Television
TEMP or BULB light aren't on and Bulb isn't burnt out So whats causing the TV not to turn on
Probably the ballast if lamp is ok.If there is not even a standby light the the power supply.
Apr 25, 2009 | Panasonic PT-40LC12 40" Rear Projection...
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Lamp will not light
At first i was thinking the ballast had gone bad but after reading a few other post i think it would be best to call pannasonic..
others forums read:
ballast had gone bad. Panasonic no longer makes these ballasts so mine needed to be rebuilt at the tune of $400.00.
With the ballast in place still nothing so now they claim that they need to order a "kit" from Panasonic which basically is all the components of my tv.
Jan 28, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Power button blinking green
disconnect the power cord overnight try it if ok change power cord cheers
Dec 29, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic Projection HDTV Made 9/2003
Your lamp has most likely blown out. that is what happened to mine and once I replaced the bulb it worked just fine. this is one of the cheaper stores to find a replacement bulb,
Aug 29, 2007 | Panasonic PT-40LC12 40 in. LCD Television
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
2,643 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
