Question about Lenovo Computers & Internet
Anyone know where I can buy the IBM T21 wired cmos c2032 button battery in the UK? Thanks in advance
    President:
  • 2,678 Answers
Http://www.battery-force.co.uk/show_CR2032_Batteries.html
Posted on Sep 25, 2009
  • Alun Cox Sep 25, 2009
    Sorry I think this is the one you want
    http://www.smallbattery.company.org.uk/s...
Ibm thinkpad t21 comes on with error 0271 and then changes to what looks like a screen symol with a lock at the side of it. can you help please?
hi, ibm t40,t41,t42 etc. error 271 check date and time setting and wont cmos/bioss/pop password. solution 100%... you have change cmos battry but your problem still so dont worry. i'm solve problem. my email id-m.word96@gmail.com...
Dec 06, 2010 | IBM ThinkPad T21 Notebook
Starting ibm thinkpad
Errors 161 and 163 mean the time and date are not set in the CMOS. This typically means the CMOS backup battery is dead / going dead.
Mar 05, 2009 | IBM ThinkPad T21 Notebook
Starting ibm 600e
Hi there.
Errors 161, 192, 163.
All three of these errors are connected to the back up battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips screwdriver required)
2. find the small connector with 1 black & 1 red wire coming from it.
3. disconnect above connector and gently pull the Red&black wires. The backup battery should just pull out from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot welded so need to be cut/broken off). Buy a new CR2025 battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
Solder the leads onto the new battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows 161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off switch at side.
Good luck and thanks for using FixYa!!
IBM T21 NEW MOTHERBOARD PASSWORD PROBLEM
Break BIOS Password
A user may also put a BIOS password preventing you to even enter the system but if you wish to access the system do not worry we you can still do it. However, I only recommend this trick for your own personal use.
What is BIOS?
Bios stands for Basic Input Output System and is a firmware code run by a PC when first powered on, which is a type of boot loader. The primary function of the BIOS is to identify and initialize system component hardware (such as the video display card, hard disk, and floppy).
How to Break a BIOS Password?
The following steps work absolutely fine for a Desktop and are the easiest of all.
Steps:
• Shut down the computer and take out all the plugs connected to electricity.
• Open up the CPU cabinet and locate the CMOS battery on the motherboard (it will be a silver circular battery just like a button cell).
Remove the battery and keep it out for some 2-3 minutes as this will flush out the CMOS memory which stores the BIOS password and all other configurations.
• Now place the battery back and start the computer normally.
Steps for Laptop:
• Open up the BIOS at the time of booting.
• There are some backdoor passwords which the manufacturing company had set that will be accepted by the BIOS. You will just need to know the make of your BIOS. Try out the passwords from these lists.
List of Award BIOS backdoor passwords:
BIOSTAR, AWARD_SW, AWARD SW, AWARD PW, CONDO, LKWPETER, J262, 01322222
List of AMI BIOS backdoor passwords:
AMI, AAAMMMIII, BIOS, PASSWORD, A.M.I., CONDO
List of PHOENIX BIOS backdoor passwords:
phoenix, PHOENIX, CMOS, BIOS
You may also want to try this utility CmosPwd 4.8
Oct 25, 2008 | IBM ThinkPad T21 Notebook
Comp probs
Remove the Thinkpad main battery. Look for a small yellow disk. This is the CMOS battery. It is connected to the motherboard with two (2) wires that plug into the motherboard. The plug is included on the wires of a new battery. Check EBay for Thinkpad CMOS batteries. I have also heard Radio Shack in some cases carries this battery.
Mar 25, 2008 | Computers & Internet
Locked screen
emove the CMOS battery, POP will be vanished right away. But after that, you have to enter BIOS to set the time/date, otherwise laptop won't boot.
if that doesnt work goto
http://www.passwordmethod.com/
Jan 02, 2008 | IBM ThinkPad T21 Notebook
IBM thinkpad T21
I had a similar problem after My pc got damp in a bag in the rain. I contacted IBM and was given this fix which I am supprised worked but it did so here it is cannot hurt to try. Remove the main battery and the mains power supply press the power on button for 17 seconds. This I think is to drain all the power from the laptop altogether. Replace the mains lead and turn on. Once the laptop has openen up into windows turn it off and replace the mains battery then power on again. In my case this worked I hope this helps.
Oct 17, 2007 | IBM ThinkPad T21 Notebook
IBM T21 shuting down
start your lap in safe mode and watch the shutting down time and let me know
Oct 10, 2007 | IBM ThinkPad T21 Notebook
BIOS/RTC/CMOS backup battery
Please tell us the type / part number of the battery and where you are located. It's a big world out there!
Aug 20, 2007 | IBM ThinkPad 390x Notebook
IBM T21
i have the same problem. actually its a common problem for many T21 and other old IBM laptops.
i searched that you have to take all power (batery, adaptor)
press the power 10 times and press it for 30 secs then reinsert the battery or adaptor and try to power it on.
they say its done to discharge a certain capacitor that got overcharged after overcharging the battery.
that worked for me before but now my T21 wont start any more with this process.
May 20, 2007 | IBM ThinkPad T21 Notebook
Computers & Internet Logo
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
