Question about Hobart N50 Stand Mixer
Hi somenone may describe how I can procede step
Hi
somenone may please describe how I can procede step by step for N50 hobart mixer's agitator shaft replacement? The agitator shaft is broken in coincidence with the groove pin and I'm not able to clearly understand the way to follow in order to take out the damaged part for replacement.
I just pulled out the cup and the planetary taper pin.
After that the planetary just empty turn on the main shaft without coming out.... of course I didn't force to much pulling the planetary cause I'm not sure if that one is the right way to get the agitator shaft gear!
Thanks in advance
  • 110 Answers
After you removed the tapered pin on the plant. you should be able to get it off the mixer main shaft @this point, there is nothing else holding it to the main shaft
Posted on Jan 16, 2010
Hobart N50 noises
The frequency is the same in all gears.
disconnect the power and invert the mixer and remove the planetary after driving out the taper pin, then you can access the transmission. It may be a rotor shaft bearing in the motor or no grease on the worm gears.
Nice touch with the video.
If you need parts:
Jan 04, 2014 | Hobart N50 Stand Mixer
We need to buy some parts for Mixer N50, Please provide us part list easy to order from you.
www.hobartservice.com click on locate an office, enter your zip and it will show the office closest to you. They will be happy to sell you parts for any Hobart product.
Jul 01, 2010 | Hobart N50 Stand Mixer
I want to order 4 pcs. Part # 107342 tumbler yoke & shifter pin assy. where can I order it and how much each for Hobart N50 mixer
SDBARBAS - You might try using the very easy "Hobart" smartparts webapp on the Hobart website. Cut and paste this into your browser Address line: http://catserv1.itwfeg.com/Hobart-Root/items.cfm, which is the parts list and an exploded view of the assembly for: Planetary, Tumbler and Agitator Shaft Unit Assembly. Go to Item # 64, and select "Add". The screen will change to 'Parts Selected'. Increase Qty to 4, hit "Update Quantities" and then hit "Confirm Parts Selected". On the next screen, select "Find Service Office", and follow the instructions on that pop-up window. You should be able to find a Hobart Service Office in your area that can price out your 4 tumbler yoke and shifter pin assembly. Good Luck... I hope this is helpful.
Nov 18, 2009 | Hobart Food Mixers
Hobart N-50 Mixer beater attachment spins but has no resistance
Sounds like the shear pin on the planetary shaft has sheared off. Has the mixer been subjected to a heavy load. Remove the planetary and see if the shear pin is intact otherwise you may have to open up the transmission.
Ron
Jun 04, 2009 | Hobart N50 Stand Mixer
In need of a Hobart N50 spiral hook
Hi. Goto globeequipment.com they have an ED hook for your N50.
If this solution has assisted you, please rate it. ricardok45
Apr 06, 2009 | Hobart N50 Stand Mixer
Worm gear hobart slicer
What is the model number?
Looking for older Hobart logo for N50 mixer 1965
you would have to have it made not available
Jan 03, 2009 | Hobart N50 Stand Mixer
Hobart N50 / KitchenAid Model G: how do i remove planetary?
you need to remove all the back screws then if it doesnt come tap it with arubber mallet it may be seized on
Nov 19, 2008 | Hobart N50 Stand Mixer
Noisy Hobart N50 Mixer
First, there is a double set screw (one on top of the other - if they are both there) towards the back of the planetary.
Remove the first screw, it should have a normal tip, not pointy. Run the mixer in 1st and adjust the screw, first out then in. Then repeat in 3rd. You should clearly hear a difference.
If not, you probably need to repack the grease in the transmission. The proper grease is called "Darina II". It's expensive ~ $35 per mixer.
Apr 13, 2008 | Hobart N50 Stand Mixer
Hobart N50 Tripped
The reset button is to protect over amping the motor. The N-50 is not a very strong unit, (commercially), but you won't break a gear. If you overload the unit, you'll either trip the overload (reset button), or you will break the taper pin that attaches the planetary to the center shaft.
If you're looking for a small commercial unit, and you're in the US, look into the 10 qt Precision Mixer.
Apr 04, 2008 | Hobart N50 Stand Mixer
Hobart N50 Stand Mixer Logo
327 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
