Question about Canon IMAGERUNNER 2230 Copier
I have one irc cannon 3200 , work good but now ,he show me this error code E000733-0001 A NEED HULP , A HEVE ONLY THIS MACHINE IN MY OFICE , I WONNA KNOW WATS HAPEN , EN HOW CAN I FIX UP PLEASE , HELP ME
  • andzulisv May 11, 2010
    you may have a loose connector on the back unplug all connectors and plug back in turn coipier back on
  • 149 Answers
This error code indicates a communication problem between two electrical modules. The most common solution is to turn off the machine and then disconnect the flat cable that plugs into the back of the reader assembly (behind and below the document feeder), the connector has a button either side of it which both need to be squeezed to remove the connector. Check both ends of the cable and disconnect and reconnect it. Turn back on the power and if this was the comm error your problem will go away. If not, then try disconnecting all of the interconnecting cables between the machine and peripherals.
If none of the above works then you have an internal comms error and possibly a firmware error which will need to be upgraded by a technician.
Good Luck
Posted on Sep 26, 2009
What is error code E000003-0002 on cannon irc 3380i
Hi . The second error indicates there is a temperature problem in the fixing unit. You need to clear that error from service mode first.
with the machine turned on Press the next:
Press aditional function once
Press 2 and 8 at the same time once
Press aditional function once again .
Service mode should appear in the screen . If doesn't repeat the secuence until it does .
Then in the touch screen
select copier
Select Function Select Clear
Select ERR and press ok in the lower corner of the touch screen .
Turn off the machine for a few seconds (5)
Turn the machine on . If problem persist that mean the fixing unit is defective
Apr 21, 2015 | Cannon Office Equipment & Supplies
How remove error code E00004-0002
canon copier IRC-3200 Error code E000004-0181
Apr 15, 2013 | Canon iR5880C
Cannon 3200 when machine has warmed up error code 000732-001
This is a reader communications error. It's been a long time since I worked an IR-C3200 copier but all cables must be plugged in. They will only go where they were intended to go. Reseat all those cables and good luck, other wise you have a professional help problem. Make sure all the cable checks are done with power off. Then power up agai n and see what happens.
May 07, 2017 | Canon imageRUNNER C3200 Color Printer
I have a problem with my cannon irc 2620n , just show me this error code E220, i guees is same happen with scan lamp , but i wonna know , wat willi mean , en how can i kan fix up, pleas help me i willi...
Does your "lamp" is turned on when you open the cover? If not it could be that you have bad lamp controller pcb.
Try to manually pull the lamp on right side, and then turn on the copier, if lamp assy is moved in left position withaut error, that means that position sensor is OK, and you need to focuse yourself on "lamp"/ LED
Sep 29, 2009 | Canon IMAGERUNNER 2230 Copier
CANNON IRC -2880
this code is for a bad OHP sensor, wich detects transprerencies.
Aug 19, 2009 | Canon IMAGERUNNER 2230 Copier
Error 805 and 803
Hello sir; The error code you display 803 & 805 could be come from same problem, both all are composite board 24 volt supply problem, replace composite board will take care this problem. good luck.
Jul 24, 2009 | Canon imageRUNNER 400S Copier
Error code E00020-03a0
hello josephusjose,
E000-03a0-
this means that there problem with the CYAN drum /developer unit in case your machine is IRC 3200 series
Changing this unit will fix your problem
Jun 23, 2009 | Canon Office Equipment & Supplies
ERROR CODE E00002-0102
You have a fuser problem. You didn't specify a machine but if it is the irc/clc3200/3220/2620 you will need to replace the fuser unit. If you have a different model where the fuser thermistors/thermal fuses etc can be replaced then replace according to the manual.
Canon Copier Sevice Manuals
Oct 25, 2008 | Canon imageRUNNER C3200 Color Printer
Error code IRC 3200 machine
"E020" Black toner feed problem
Oct 06, 2008 | Office Equipment & Supplies
206 people viewed this question
old marine
old marine
