Question about Brother DCP-110C All-In-One InkJet Printer
Unable to print........see troubleshooting guide
I have a similar issue as other posts. Have checked for paper jams, paper clips and staples..........all clear.
Have ran the diagnostic mode and my ERROR CODE is 41.
Can you give me a clue on possible repair?
Cheers - Muzz
  • Oz_Muzz Dec 17, 2007
    Thanks for your reply - not the news I had hoped but an excellent service.
    Cheers and Beers to all during the festive season - OZ_MUZZ
  • 832 Answers
The printhead is defective and cant be fixed anymore. It needs replacing (Spare part prized as much as a new dcp!).
Posted on Dec 16, 2007
Paper jam c
Unable to print troubleshooting and routine maintanance chapter in user's guide
Mar 23, 2013 | Ricoh Aficio SP-C210SF Printer
Init Unable 48, See troubleshooting and routine maintenance chapter in User's guide
What is the condition of your print cartridges? They could have dried out during the 2 month period that you didn't use the printer. Try, cleaning the contacts of the cartridges and the printer. If you have new cartridges to try....even better.
Jan 15, 2008 | Brother MFC 240C All-In-One InkJet Printer
I had never had an issue with this MFC 5440 CN until now,It was working perfectly and since a couple of days ago it does no want to print. All ink levels are OK, there are no pieces of paper stuck...
Ivan, see if there are some paper clips or other similar objects stuck somewhere around the paper rollers. There are micro-switches around the rollers, you may want to take a brush and clean up any dust buildup that may be causing these micro-switches to trick the printer into thinking that there's a paper jam of some kind
Dec 21, 2010 | Brother MFC-5440 Printer
Brother Intellifax 2920 Error "Unable to Print"
Check the flux capacitor, those usually go out on brother faxes.
I just replaced mine last week, same problem.
Jan 05, 2010 | Brother IntelliFax-2920 Fax
K5400dtn - paper feed and on buttons flashing - won't print
This usually the indicator for a paper jam or similar.
You need to check over the printer for any scraps, jams, etc.. that are stopping the paper or printhead from moving normally.
You also need to check for any lids or doors open and make sure that the duplexer in the back is locked into position properly.
I had to search hard but the flashing lights troubleshooting guide is available here on the HP website.
Feb 21, 2009 | HP Officejet Pro K5400dtn Printer
Print unable 36 error
The 36 error mean: The machine does not work due to a paper jam. Clear the paper jam, if doesn't work maybe a sensor is dirt or bad. To disassambly the printer you need the service manual and some know how ( electronics knowledge).
All the best !
Feb 21, 2018 | Brother Multi-Function Center MFC-240C...
Unable to Print
plz try by reinstalling the printer
Nov 27, 2008 | Brother MFC-620CN multifunction Color...
Printer will not print
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
  1. Check for foreign objects, such as a clip or ripped paper, inside the machine.
    Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
  1. If the error continues to appear, the machine may have a mechanical problem.
    If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine
  2. User's manual:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc420cn_us&type2=5&flang=English&dlid=
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 11, 2008 | Brother MFC 420CN All-In-One InkJet...
Cleaning troubleshoot needed
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model. This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue. 1. Check for foreign objects, such as a clip or ripped paper, inside the machine. Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely. 2. If the error continues to appear, the machine may have a mechanical problem. If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine:
Jul 28, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother DCP-110C All-In-One InkJet Printer Logo
131 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
