Question about GE JVM1440 Microwave Oven
Microwave Lights won't work
  • dotsie Dec 16, 2007
    G emicrowave light won't work
  • dotsie Dec 17, 2007
    Everything has power and works except the to bulbs. We were changing the one bad bulb when ti made a loud sound and both bulbs went out
  • 833 Answers
Dotsie...you're not telling me if anything else works. Do you get the clock? Do you get power? If it is just the light, it is likely the bulb. If it is everything, start with the outlet...does it have power? If yes, then we can go inside and check around. See some of my other similar comments.
Posted on Dec 17, 2007
  • Robert Hirst Dec 17, 2007
    dotsie, first check the bulb that also stopped working...It may be bad, too. Not that? I'm guessing that there is an internal fuse in the unit which blew. You're going to have to take off the panel and locate it. Always pull the plug! Get a multitester and check each fuse. You may even be able to see it visually.
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
Range lights on a over the range GE mirco wave won't work. The touch pad works and says the lights are on but no lights
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
Or you can buy and install a new control circuit board (smart board) from the Pros here, our favorite supplier.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
Oct 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
When changing the lightbulb under the over the range microwave oven I heard a pop sound and now neither of the lights or the fan won't work but the microwave and the clock on it still works, it is just...
probably caused a short while replacing the bulb(s) and, causing damage to the circuit board. pull the board out and carefully check for burned foil traces; and rebridge with solder. it may or may not work. always unplug the microwave when replacing the range lamps.
Aug 06, 2011 | Hotpoint RVM1435 Microwave Oven
Microwave still lights up and timer still works but it won't heat anything up
The magnetron is the most likely cause, "heats food" this part is the heart of the microwave and expensive. The other two parts to consider is the high voltage capacitor and diode, but repairs will run high depending on the nature of the problem.
Jul 09, 2011 | Emerson Microwave Ovens
My GE JVM1540 microwave appears to run but it won't heat. The lights and turntable work but it does not heat at all.
you will have to replace the microwave, sounds like a burned out magnetron, replacing the magnetron is almost as expencive as a new oven...
May 05, 2011 | GE Spacemaker JVM1540 Microwave Oven
Night light won`t work.Was changing bulb and heard a pop.Replaced bulb,still won`t work.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 14, 2008 | Kenmore 62702 Microwave Oven
GE JVM1440 Microwave Oven Logo
26 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
