Question about Air Tools & Compressors
I have broken tube between compressor and tank
I have broken tube between compressor and tank and need repair parts
  • jandj_homepl Sep 26, 2009
    have recieved your solution and will give it a shot. I will post a later note to let you knowq if it worked. Thanks
  • 832 Answers
You can fix it. Take the broken tube off, using an adjustable wrench. Take the tube to your nearest hardware, so you can have the right replacement size.Using the old broken tube as sample, you can copy it with the tube you just bought from the hardware. Don't forget to place the fittings to the tube
before having the tube ends flared. Then, you can install the replacement to your compressor. Please send your comments and vote so I will know.
Posted on Sep 25, 2009
Supply tub to tank
That is really not a hard part to find. You should be able to remove the broken one and take the whole tube into a hardware store and they can replace it for you. It should be a copper tubing with flare nuts on the ends. If not please post the model number of the compressor
Apr 27, 2013 | Magnum Air 2 HP 5 Gallon Twin Tank Air...
I need a part number for a check valve on a Campbell Hausfeld model WL506201AJ
there is a check valve on the compressor! it connects to the tank. if it is hissing all the time it wont allow the compressor to turn over due to the back pressure from the tank... Can anyone answer what check valve to get? Tank thread size on one side and the feed tube connection side... Here is the parts diagram but the check valve is not described... http://www.chpower.com/IMAGES/pdfs/manual02/224902_0201.pdf
Feb 19, 2011 | Campbell Hausfeld Air Compressor Check...
Need repair parts and repair diagram for Francis Francis X!. Water tank tube broken
Call Empire Fullfillment, they have parts lists and manuals they can email to you. You can also order parts.
http://www.empirefulfillment.com/
Feb 11, 2011 | FrancisFrancis! X1 - Stainless Steel...
Compressor will run, but only builds to 20 lb pressure. Line to tank gets hot.
Very hot air is an indication of leaking /broken head gasket or reed valve. Before you remove any parts, with compressor running, check all fittings for leaks with soapy water. If no leaks, remove head and examine parts. If reed valve is broken replace as needed or do creative repair. Some valve plates have multiple reeds and only one reed is broken. Depending on your skill level, you can thread the hole and seal with piece of bolt (finished repair must not be any thicker than the plate). Good luck
Jan 29, 2011 | Craftsman 1 hp Air Compressor, 4 gal. -...
The manifold which holds the Air Hoses and control valve and gauge is broken and I need a new one ,dont know the part number
We repair lots of compressors with broken manifolds. Most compressors now use a manifold with a built in pressure regulator. We are not able to find exact matches so we use a manifold from porter cable or make one out of pipe fittings. If your compressor was made in china, most likely the thread and tubing sizes are almost impossible to match. To use porter cable parts, go to dewalt service center or to porter cable dealer and find close match then use that model number for ordering your part. Check closely that parts/thread/fittings will work.
Jan 29, 2011 | Hdc Homer Hdc 2 Hp, 4 Gallon Pancake Air...
My compressor builds to 125 psi then shuts off like it should then when the pressure is released the compressor wont start back up. Sometimes it will attempt to start and it sounds like the motor is...
When a compressor reaches set pressure, there should be a release of air from discharge hose thru the unloader. This release of air unloads the compressor head pressure. The unloader is usually located within the pressure switch. Easy to check. Follow discharge hose from compressor head to tank. There should be a brass/steel checkvalve at the tank. The checkvalve allows air to enter tank, however not allow air to be released back into discharge hose. If this valve is leaking, air will be released from the unloader constantly. Follow 1/4" tubing from checkvalve to unloader and listen for leaks. Repair as needed. If air is not leaking from checkvalve then check unloader mechanism with-in pressure switch. Parts are available at www.toolpartsdirect.com Good luck
Aug 25, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My compressor runs but is not filling the tank. Sears wants more to repair it that it will cost to replace.
Take the exhaust tube from the compressor and run it for a moment or two with your finger over the exhaust port--it should try to blow your finger away. If no pressure, remove the cylinder head from the compressor and inspect the valves in the head assembly. Reeds or discs, if any are cracked or broken, replace same from: Seardpartsdirect.com Make sure the valve seats are in good condition--if not, you may need to replace the cylinder head from the same source. Make sure the piston(s) move up and down when turning the compressor pulley. Inspect the piston top(s) and cylinder wall(s) for excess wear or other damage. The only other problem would be a hissing leak from some tank component. Hope this helps!
Aug 17, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Mastercraft 2.0 hp air compressor will not build up over 25 psi
sounds like a bad or broken valves in the head. crankcase needs a vent which is sometimes a small hole drilled into the oil fill plug and will normally blow some air out the vent while it runs
Mar 22, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
175 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
