Question about Dell Latitude D630 Intel Core 2 Duo T7250 2M L2 Cache, 800MHz Dual Core 80GB/512... PC Notebook
Dell Latitude D630 screen flahes then it lockup or shutdown. Must try a few times to startup again. Loaded new display drivers, but problem started again
  • 1,472 Answers
Swartj864
The first thing I would do is run the onboard diagnostics for the computer. You do this by hitting f12 on your keyboard at startup. Then you will see the boot menu. The last option should be the diagnostics. After you run this if you get any errors I would call Dell support about them as you have a hardware problem.
If you do not get any errors then most likely you have a Windows problem. The first thing I would do is boot the computer into safemode. You do this by hitting f8 on the keyboard when you first turn on your computer. Once in safemode then open of the properties on your C: drive and go to the Tools tab. Next click the Check Now button. Make sure both check boxes are check and click start. Note you may need to restart your computer.
After this runs you need to boot your computer into Windows. Note if you still have trouble you may need to go to safemode again. Once you are in Windows put in your Windows CD and exit out of the installer if it pops up. Next go to Start and Run, then type "SFC /scannow". This will run a repair on the system files. If you still have trouble after this you may need to look at reinstalling Windows.
Hope this helps
Issken
Posted on Jan 10, 2010
Laptop powers on and in a few second powers off.
Have the DC jack in the laptop checked, this is a common problem from no power, to intemittent, and startup and shutdown issues, the laptop must be taken apart in order to get at the DC plug on the motherboard, it may need to be replaced or resolded.
Jun 26, 2012 | Dell Latitude D630 Notebook
I have dell d630 it turn on but not display anything what is the problem
If the unit powers up and it seems to work except for the screen, hook a external monitor to the video output usually on the back, if picture is present! the laptop has issues. But if both screens show the same symptom the problem is in the video graphics card.
Apr 08, 2012 | Dell Latitude D630 Intel Core 2 Duo T7250...
D630 screen is black once it starts up it illuminates but stays black
You must detect what parts is failure
Screen display, inverter board or lamp
Follow these step.
1.- Connect an external monitor (at VGA port) and check the image in external monitor
If show clear image. The failure may be the inverter board or the lamp backlight
Inverter boars is more easy to replace.
You can buy an used cheap price on
http://www.ebay.com/itm/Dell-Latitude-D630-Inverter-Board-K021048-00-/260809995144?pt=LH_DefaultDomain_0&hash=item3cb97cb388
Replace and your screen will work again
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Dell Latitude D630 PC Notebook
I have a Dell Latitude D630 and the display, even on the BIOS screen, looks like six small EGA displays displays on the screen. The display is duplicated once across and three times down the screen. ...
Try booting in safe mode with networking (press and hold F8) after pressing power button. Once in safe mode check display drivers are up to date, and try again.
Another way to check might be using any linux bootable CD. TO do this, download any liveCD image of any flavor of Linux, burn on a CD and boot off of it from this laptop. If the same thing happens, then its a hardware issue
Hope it helps!
Mar 07, 2011 | Dell Latitude D630 PC Notebook
Dear all, My computer has a similar problem as "Dell Latitude D630 screen flahes then it lockup or shutdown. Must try a few times to startup again." . I try to check disk but nothing happens, I...
if you have the windows cd that came with your laptop, you can try repairing the Windows installation. to do so, insert the disc, turn your system on. as you progress, you will see a screen that give you an option to repair windows without formatting the system of affecting your files.
Nov 02, 2010 | Dell Latitude D630 Notebook
My Dell Latitude D630 will power on but the screen is black....nothing will show not even the startup page for windows. What do you think the problem may be
I would suspect either the video card or your LCD screen.. A good test is to hook up an external monitor and see if that works. Be aware that when you start it up, you will have to hit the function key and special function key combo to switch it to the external display.
On the latitude, that is the Fn key plus the F8 key.
Mar 22, 2010 | Dell Latitude D630 Notebook
Dell Latitude D630 ,when battery down, display issue
Update Video Driver & BIOS, Are you having NVIDIA graphics on this system,then its better to call DELL and inform that,so that they will replace Motherboard Note:If you have any graphical or video issue on the system,then call DELL
But still call Dell you have Life time phone support
Jan 11, 2010 | Dell Latitude D630 PC Notebook
Dell Latitude D630 sceen flashes and PC lockup or shutdown.
HOW DO I RESET MY DELL LATATUDE D630 BACK TO OUT OF THE BOX SETTINGS?
Sep 25, 2009 | Dell Latitude D630 Intel Core 2 Duo T7250...
Display distorted
Install Proper Driver for VGA
Download and install from www.dell.co.in
Jun 24, 2009 | Dell Latitude D630 Intel Core 2 Duo T7250...
Dell Latitude D630 Intel Core 2 Duo T7250 2M L2 Cache, 800MHz Dual Core 80GB/512... PC Notebook Logo
352 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
