Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
I have a power devil PDW5500 digital safe & the battery has gone flat & i can't gain access & i don't have any sort of key - can you help please
lessmith49
  • 5 Answers
SOURCE: Lost combination Safe Guard Digital Safe
I used to work for a safe company.
The solution to your problem is not nice.
You need to find someone with a 9 inch grinder and a metal cutting blade.
Don't bother to try to cut the door off it is the strongest part.
If possible cut the back off. If not possible to get to the back start with the hinges if you know where they are, some hinges are concealed and are not where they appear to be.
This solution is messy dirty noisy and dangerous, that's what safes do to deter criminals.
If safe companies kept generic codes to open any kind of safe they wouldn't be,,,,,,,,,,,,,safe.
Posted on Feb 13, 2009
SOURCE: BATTERIES FLAT CANNOT OPEN MICROMARK SAFE WITH KEY
http://www.rotteneggs.com/r3/show/se/198433.html
:D x
Posted on Jun 02, 2009
  • 13 Answers
SOURCE: SURE SAFE ELECTRONIC CONTROL PAD AND BATTERIES
try default number 159A
Posted on Oct 04, 2009
SOURCE: The wrong number was input and now we can't get
You don't know the combination code, and you don't have a key? Or you know the right combo code, but the batteries are dead? If you have the right code, and the batteries are near-dead, try the jiggle suggestion...put the safe on you lap, put in the correct combo, and jiggle the safe while turning the latch. Might work.
Posted on Feb 17, 2010
SOURCE: i have a cs-2 digital safe batteries dead cant
Try taking a 9 v battery and hold the terminals against the metal frame of the safe. If this works you should be able to enter your code and get her open. Then you can replace the 4 AA batteries on the back of the door. Good luck
Posted on Apr 18, 2010
I have a power devil digital safe, the keys are lost and the battery is flat,
CALL THEM
there is no other way
if there was , the safe is a useless toy
Feb 24, 2017 | Power Computers & Internet
Where is the battery compartment in my ce electronical digital safe?
do you have a round lock pad. This model has 2 9 volt batteries under the key pad
http://bestbatterytips.com/change-replacement-batter/safes-with-electronic-locks-replacing-the-battery/
Lots of info here
  • How to open digital safe when battery is flat and key not ... www.youtube.com/watch?v=aqC9V7SDKdQ
    • BY KHTHHONL
    • 1 MIN
    • 417K VIEWS
    2012-11-09 · How to open a digital safe when the battery is flat and the ... How to open digital safe when battery is flat and ... How Secure Are Electronic Safe ...
  • Locked out of my Digital Safe [Archive] - PPRuNe Forums www.pprune.org/archive/index.php/t-357319.html PPRuNe Forums > Misc. Forums > Computer/Internet Issues & Troubleshooting > Locked out of my Digital Safe. ... CE (Chinese made) electronic security safe ... battery ...
  • LA GARD LG Basic digital electronic safe lock changing ... www.youtube.com/watch?v=M07EpfSmoAU
    • BY DEANSAFE
    • 3 MIN
    • 99K VIEWS
    2009-10-13 · For instructions on this and other electronic digital safe ... How to change the combination and battery on ... Basic digital electronic safe lock changing ...
  • User Manual for Safe EA25 Installation - Tayabally www.tayabally.com/digitalsafe/mannuals/Safe EA25 Installation... You should change the code as soon as possible after opening the ... BATTERY REPLACEMENT. This safe uses ... MAINTENANCE FOR KEY AND ELECTRONIC SAFE.
  • Elektronischer Digitaler Safe Electronic Digital Safe www.produktinfo.conrad.com/...799999/...DigitalerSafe_de_en_fr_nl.pdf · PDF file Electronic Digital Safe Version 12/08 ... (CE). Any usage other than ... Replace your batteries when both the red and green light illuminate. 1.
  • Instructions for an Electronic Digital Safe ' eHow www.ehow.com > Home > Home Safety > Home Safes Instructions for an Electronic Digital Safe By Shawn McClain eHow Contributor Pin Share ... Replace the used batteries with new ones. For most safes, ...
  • Apr 24, 2016 | Locks & Locksmithing
    I Have a Suresafe 20ES and the battries have gone flat. How do I get the door open
    There are two ways you can open this safe. First one is to give alternate power supply for which generally a devise is provided which I do not think you have the access to. Second Option is that you must have manual override keys. With this manual key you can open the safe and then change the batteries.
    Jul 10, 2014 | Safe International Digital Electronic Safe...
    Will I be able to start and use my car if the key fob/plip isnt working?
    everything should be ok as long as u got the key to start the car
    Jul 07, 2014 | 1999 Renault Megane
    Power devil safe PDW5500 electronic digital
    Take apart the unit if it appears to have an internal battery with no access hatch and replace it with a new one that is compatible. If you cannot find a replacement, you can always build your own battery pack.
    Use the same battery type and voltage and solder them together if required. Make it clean with no potential for any short circuits. Do not mix old batteries with new ones. If you can find higher capacity batteries than what the vaccum came with, those will be fine to use as well. Just make sure they are rated at the same voltage level so that charging them wont require any modifications. Don't burn yourself!
    Most middle schoolers and highschoolers can help you with this if you have any younger folks around you.
    Apr 24, 2014 | Vacuums
    Battery gone flat and have not got key how do i get in my safe
    Try heating the safe, raising the temperature will help the batteries recover enough to open the safe. Good luck
    Feb 08, 2011 | Safe International Digital Electronic Safe...
    Digital safe. combination isint working. key was lost years ago. urgent that get open grocery money is inside.
    I assume you have been able to open it with the key code up till now?
    Its possible the batteries are flat. Most digital safes only have access to the batteries once it is open.
    If you can access the batteries from outside try replacing them.
    If the safe is only a cheap model use an angle grinder to cut it open, or take it a locksmith.
    Good luck,
    Steve
    Oct 12, 2010 | Computers & Internet
    No key and forgot numerical code
    all electronic safe's come with a key,,,,pull off the center cover in the dile and put the key into the lock to undo it
    Jul 28, 2010 | Safe International Digital Electronic Safe...
    Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
    526 people viewed this question
    Top Safe International Locks & Locksmithing Experts
    Jim London
    Jim London
    john h
    Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
