Question about Dishwashers
We have an Hotpoint FDW70 Dishwasher that for some time has had an A10 fault which although stops the machine some times 70% of the time it does a full cycle. However it is now tripping out the electric at the mains. It is not RCD protected, but does not blow it's own 13amp fuse or that of the fused extention lead it is pluged in to. Tends to blow after about 5 minutes. I know about the fault code A10 being 'Fill Valve Triac' but as not an engineer what is that? and what parts are needed and or reset codes?
    Problem Solver:
  • 11 Answers
Hi the fill valve triac is the plastic vlave that the inlet hose connects to you can get them for about £10 you reset the machine after replacing it by switching it on, pressing the power button leaving it off for about a minute then switching it back on, and the onboard diagnostic unit resets automatically.
Posted on Dec 12, 2009
A10 code Indesit Dishwasher DSG573
A10 is a heater fault check heater or look for poor connection on module normally the pink or blue wire
Jan 24, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Cod. error a04 on the display
Appliances fault A04 has different meanings depending on the type of appliance. Please see below for further detauls:
Also see our video section for help.
Error: A04,
Machine: Dishwasher,
Type: EV02 Module,
Fault: The selected temperature was not reached within a given time.Check thermistor and heater
Error: A04,
Type: Standard Module + FDW70 + FDW75,
Fault: Heating fault.Check thermistor and associated wiring
Hope helps.
May 02, 2011 | Dishwashers
Help my Hotpoint FDW70 iS FLASHING a99...............Many thanks Sarah.
A99 is a communication error. Try unplugging your dishwasher for 10 minutes and then try it again. If you still get an A 99 code that suggests a problem in the control board in the dishwasher. In this instance I recommend an engineer as it can be extremely difficult to fault find this error.
Hope this helps.
Mar 09, 2011 | Hotpoint 24 in. FDW60 Free-standing...
My Aquarius FDW70 keeps coming up with code A10
Dear sir,
If your dish washer is type EV02 Module,
Error A10: means Faulty fill valve.
Check valve and associated wiring.
If your Dishwasher is
E10 means Heater fault.
Check heater and associated wiring.
i think it helps for solve your problem.
if you have any doubt regarding this issue leave a feedback we will glad to assit you.
Have a nice day
good luck
Sep 12, 2009 | Dishwashers
My aquarius hot point fdw70 comes up with error a10
Check out www.selfix-uk.co.uk for all hotpoint error codes and what they mean
Oct 07, 2008 | Dishwashers
Hotpoint FDW80( A10 Appears ondisplay half way through cycle)
here are the fault codes for your machine...
Fault codes for LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water
  • Hope this helps?
    Jan 06, 2008 | Hotpoint 24 in. FDW60 Free-standing...
    I have a Hotpoint FDW70 dishwasher
    Disconect POWER at breaker or fuse panel which should be on a seperate braker. if not find the power sorce and unplug the device. FOR SAFTEY Kneel on a thick doormat if you have to disconect power which has a plug. Wait for a an hour so to let all circuits, timers and motors to cool ... with diswasher in the OFF position, Re-establish POWER. then go ahead and start washer as sugessted by the Manufacturer. Make sure to notice any other codes that may appear. Or any peculiar noises. Most default codes appear if water pressure is too low. Top loaders are natorious for plugged drain lines and can be flushed by the home-ownwr. Make sure to check that water strainer is not cloged or restricted. Hotpoints CODES change from year to year, You can contact a Hotpoint Dealer in your area ... Give him the Make, Model, and any Series numbers to him. MOST will tell you what the CODES ARE FOR THAT MODEL OR EVEN E-MAIL ALL OF THEM TO YOU. Good Luck ... Be Safe Joe Rex
    Oct 09, 2007 | Hotpoint 24 in. FDW60 Free-standing...
    Hotpoint Aquarius+ FDW70 Error Codes
    i have the same on my dishwasher and have just been looking on the net. Found out that the error code A10 means open/short circuit fill value traic. Whatever that means!!! and to book a service engineer. Hope that helps
    May 04, 2007 | Hotpoint 24 in. FDW60 Free-standing...
    Dishwashers Logo
    557 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
