Question about Euro-Pro Fast and Easy 420 Mechanical Sewing Machine
Bobbin Can't get the bobbin to work or for the thread to come up
  • 1 more comment
  • Anonymous Dec 24, 2007
    same problem - please help!
  • oldleatherbo Apr 20, 2008
    HELP - the bobbin thread won't come up
  • Anonymous Jun 02, 2008
    I can't get the thread to come up through the bobbin.
Me too!
help me?
Posted on Dec 31, 2007
Why does bobbin knot up? Was working fine until changed thread & boggin
try changing the needle--make sure the needle is the correct one for the thread and fabric being sewed
make sure the top thread has not come off the thread take up lever
try a different bobbin--just in case bobbin is damaged
make sure the bobbin is turned counter clock wise in the bobbin case
Mar 21, 2016 | Simplicity Sewing Machines
Bobbin not working.
The symptoms sound like it could be the incorrect bobbin. Even if it is tiny bit different, it may not work properly. If it is not an authentic bobbin for your machine, but rather a clone from another source, it may not be suitable. Some machines are very finicky.
If it is in fact the correct bobbin, then there may be a problem with how the thread is wound on the bobbin or how the bobbin has been inserted and threaded in the bobbin case. Be sure the thread is wound very smoothly on the bobbin and that the thread does not extend beyond the outer edge of the bobbin or that no loose threads are poking out from the bobbin. Also verify that it is inserted (and turns the right direction) in the bobbin case and that the bobbin case is threaded properly.
Feb 24, 2016 | Sewing Machines
Bobbin winder not working
none I have ever had CATCH the thread . you have to thread to the bobbin and hold the end till it gets a good start .
Feb 12, 2016 | Sewing Machines
While threading my bobbin, the thread slipped under the bobbin seat and got stuck. I can't dislodge it, and my bobbin won't thread. How can I fix this?
can't figure out what you mean, what bobbin seat, do you mean on the bobbin case? maybe on the post where the bobbin case goes? I guess you just have to work on getting the thread off and start over.
Jun 18, 2014 | Brother 130-stich Computerized Sewing...
Trying to wind the bobbin on my Pfaff hobby 1132. The thread keeps coming off the bobbin thread guide. The bobbin winds, but the thread is loose and uneven. I've pushed the bobbin holder to the right and...
Check to make sure the thread path from the spool to the bobbin is correct. The thread should make a loop around a little post that is actually a tensioner that helps the thread wind smoothly onto the bobbin. If something is wrong with that tensioner or the thread is not following the correct thread path, it could cause the thread to not wind smoothly. It appears that your machine has two locations where the spool can be placed to wind the bobbin. You might try using the other option, if one doesn't seem to be working.
Also, you might try slowing the machine down during the thread winding process. It it goes too fast the spool begins bouncing and pulls the thread akilter. Also, some threads will stretch if the winding is too fast causing the thread to "shrink" when sewing your garment and creating puckers.
FWIW, I found that a "SideWinder" stand-alone bobbin winder is a handy gadget. It is available for ~$30 from JoAnn's Fabrics, Amazon, etc and is battery or electric compatible. It saves wear and tear on a machine and can wind multiple bobbins one right after another. Just be sure to verify that your bobbins will work on the SideWinder as some Singer bobbins will not.
Nov 16, 2017 | Sewing Machines
Brother 1100 threading the bobbin
rethread the machine top and bobbin
make sure to use every thread guide
lever--this can cause the sewing machine to jam
if it's a top loading bobbin--take the bobbin out of the bobbin case
and turn it around and reinsert the bobbin
if it's a side or front loading bobbin take the bobbin and bobbin
case out and make sure the bobbin is inserted correctly into the
bobbin case and that the bobbin case is inserted correctly into the
sewing machine.
Nov 14, 2012 | Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
I have a ce 100 and the bobbin thread comes up and gets into my embroidery pattern. how do i loosen the top tension to stop this from happening. my purple flower has white in it from the bobbin :(
Just an FYI-the bobbin thread needs to match your top thread. The majority of the thread that appears in the top of your embroidery actually IS the bobbin thread. The machine is working correctly. Don't use a bobbin full of white thread-instead, thread a bobbin with the color your doing the embroidery work in to match and you will have a perfectly beautiful embroidery.
Nov 11, 2010 | Singer CE-100 Futura Computerized Sewing...
Bobbin thread is coming to top when embroidering. I have changed needle and re-threaded several times
Feb 16, 2010 | Singer CE-100 Futura Computerized Sewing...
Using Singer 7470 for the first time, and my bobbin thread is bunching terribly. There is a loud sound from the bobbin chamber, as if the mechanism is bouncing around??? How can I fix this bobbin issue?...
1. Take bobbin out and re-insert and thread.
If that dosen't work, try:
2. Take bobbin out and bobbin case, clean area and re-insert bobbin case and bobbin.
3. Re-thread the top thread that goes to the needle. (Sometimes the thread dosen't hook to the "Thread take-up"(page 6 on manual). It pulls the bobbin thread and the bobbing becomes loose inside the bobbin case.
4. Wind a new bobbin (Sometimes a bobbin might wind thread to lose) Do not wind thread to the edge of bobbin.
If that dosen't work, you should take it in to be serviced...Somenthing might become loose that only a technitian can correct.
Also check manual for troubleshooting.
Good luck.....
Chickiefl
Apr 15, 2009 | Singer 7436 - INGENUITY
Euro-Pro Fast and Easy 420 Mechanical Sewing Machine Logo
62 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
