Question about Hobart Dishwashers
We have a hobart top tech 500 and have prices for
We have a hobart top tech 500 dishwasher and have prices for the following 143194 1/4 hose, 143219 detergent hose inside punp and drain hose 127086 total price $260, is this right. regars
kerry
Greenvale Electrics
zeusfaber
  • 247 Answers
SOURCE: blowing the electrics
You need to get to the drain hose (always a bit fiddly with a built-in model). Look at how it is routed (the position of the highest point is important for later), then extract it from its connection to the mains drainage, and use it to empty the machine into a shallow container placed lower than the dishwasher. As soon as the whole hose gets below the water level in the machine, it will start to drain. Because shallow containers tend to fill quickly and are then hard to move away, you may want to take several bites at this: Every time you want it to stop, lift the free end of the hose above the water level and secure it there so it doesn't fall off when your back is turned. When the machine is empty, put the hose back where you got it from, paying particular attention to where the highest point in the hose goes. In terms of what's blowing the electrics: Unless you know the machine has suffered physical damage from some external mishap, the usual culprit is pinhole corrosion in the jacket of the heating element letting water in to compromise the insulation. To prove the fault: Disconnect electrical power. Find the electrical connections to the element and pull off the two that go to insulated spade terminals (the one that goes straight to the body is the earth, and should be left on). Tie the bare wire ends off with insulating tape so they don't touch anything they shouldn't. Reconnect the power and try to run a cycle. Even though the cycle is unlikely to complete properly in this condition, you will know the original fault lay with the element if the machine manages not to blow the electrics any more. New elements are not usually difficult to fit - expect to pay about £40 for the one for your machine. A.
Posted on Aug 01, 2007
SOURCE: bosch 3000 dishwasher
Don't. Just attach your hose and the end of the Bosch hose together. Just wind up the Bosch hose and tape it to the back of the machine.
Posted on Jan 15, 2008
rylee_smith
  • 8619 Answers
SOURCE: dishwasher says delime on screen, how do i do this?.
Hi!
You need to buy a calcium lime remover/lime remover and if you can see a bad lime deposit then please buy a stronger delime.You need to put the delime in the unit and run it through a cycle.Repaet this procedure more than once to get optimum results & get rid of the scale. Also try and delime it once in a month or two so that this doesn't happen in future.
Please rate this solution.
Thanks
Rylee
Posted on Feb 13, 2009
SOURCE: E5 error - need to know where drain hoses are
tried to take off the drain hose, but could not get it off the back, only by the disposal. I turned if off and on about 6 times and ran the delime cycle with lots of limeaway. It got the E5 error on the delime cycle, but it worked the next time I tried to run it.
The manual does say to turn it off and on as it drains out the water. Takes a while as it has to heat up the water each time.
Posted on May 20, 2009
  • 39 Answers
SOURCE: Dishwasher not draining, not getting dishes clean.
sometimes this drain motors get stuck..you have to turm them a couple times with your hand, make sure you shut off power....also sounds like you have problem with cycling...i wish a can take a look on it....turn you drain pump...and try to start again see what is goning to happend....please let me know you results totalcarefl@yahoo.com
Posted on Aug 25, 2009
Hobart dishwasher
Contact the "Repairclinic.com"
Have model & serial number avail usually inside door
They have tech support and part reasonable priced
May 26, 2016 | Hobart Dishwashers
Ecomax 500-10
Hello. Have you find a wiring diagram for Ecomax 500-10 dishwasher ?
Jul 15, 2013 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Pipe leakage inside where can I get a new pipe
Goto hobartcorp.com,create a user name.Then on the left side tabs you will see smart parts.
Find the model and ml # on the data plate on the dishwasher and you will be able to find your part # and the price.I'm a hobart tech and repair these dishwashers often,any questions let me know.
Nov 21, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart sr24h dishwasher won't get up to temp.
the water level is low (should cover the bottom of the tank about a 1/4")and the pump is starving - therefor probably not washing very well.
three things to check
1. check braided fill hose for kinks (you will have to pull the machine out if under a counter). run the machine while pulled out if possible to ensure its not kinking when you push it in.
2. pressure reducing valve-prv (if installed) on the incomming water line before the braided hose (probably under a sink). turn the screw on top clockwise to increse pressure.
TURN THE BREAKER OFF TO DO THE FOLLOWING!!
3. flow regulator (if installed) - installed under the bottom pannel at the end of the braided fill hose (about 2" long and silver). turn off water. you can simply remove it, drill out the centre or just remove the rubber peice inside.
inrease the temp by adjusting the thermostat on the right side under the bottom pannel in front of the booster.(dail is hard to see and breaker must be turned off)
remember - the machine must be turned on for several minuets to truly get up to temp.
Jul 20, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Rinse probe
If standing in front of the dishwasher,look to the right in the back on top you will see a valve and guage.You will see the rinse/fill pipe and the probe screws into that.I'm a hobart tech--Any questions let me know.
Mar 04, 2009 | Hobart AM14-253 Free-standing Dishwasher
Rinse arms
Sorry for the late reply, did you solve your problem?i'm a hobart tech and give you some things to check.
Feb 16, 2009 | Hobart AM14-253 Free-standing Dishwasher
E-2 Error on LX30 Hobart Dishwasher
E-2 error is a fill problem. Water did not reach the lower probe within the time out. (innitial fill only
1- Is the bottom probe clean?
2- No fill water (check valve, hose,fill screen in end of hose, and fill source.)
3- low water pressure, should be 20 PSI flow.
4- Fuse 1FU blown.
5- Check wiring to fill valve.
6- Check relay board function.
Feb 15, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Incorrect wiring on a heater element for a hobart am14
Is this single or 3 phase? What happened?I'm a hobart tech.
Jan 24, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Hobart dishwaser
hi,i just read your issue.im a hobart service tech and fix these units all the time.what model do you have and are you sure the error is bof?let me know,i can tell you all the info,error codes about hobart dishwashers.
Jan 14, 2008 | Dishwashers
Dishwashers Logo
77 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
