Question about Fisher and Paykel Fisher & Paykel Washer
Mw511 wont empty water to allow the spin cycle
  • Fisher and P... Master
  • 7,482 Answers
Could be a belt problem, check the belt first.
Or could be your control switch problem check your belt first as it is the easiest way to go and the cheapest.
Posted on Sep 25, 2009
Doesn't dry clothes properly after spin cycle clothes are wet when cycle finishes It empties water
Bad belt will not allow drum to reach full rpm during spin cycle, not spinning all water out of clothes
Sep 15, 2015 | Washing Machines
My mastermind 708 dosen't spin after wash cycle.It spins fine in the wash cycle but dosen't drain water or spin in the spin cycle.Pease help
Your empty pump filter is blocked with debris. If it can't evacuate all the water then it wont allow the spin cycle to start. Locate the filter (probably behind a little door at the botton of the front of the machine). Remove, clean and remove the debris, re-fit and all will be well
Jul 01, 2011 | Westinghouse Washing Machines
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
Jun 29, 2011 | GE Washing Machines
Mw511 Fisher and paykel washing machine does the cycle fine but now won't empty the water. How can I take the back of the machine to see if something is blocked?
You don't need to remove the back, tilt the washer back in the front right corner is the pump. Try to turn the impeller if it wont turn its either blocked or failed. Bail the water out of the washer push the tab on the pump and twist the pump will come out so you can clean the debris inside.
Good luck with your repair!
http://www.appliancerepairlesson.com/
Mar 05, 2011 | Fisher and Paykel GWL11 Top Load Washer
Wont spin
Probably down to the water not emptying from the machine in the empty cycle and the machine won't spin because there's still water in the drum. If this is the case, the root of the problem is almost certainly a blocked filter, restricting the draining of the water and not allowing it all to pump out in time during the empty cycle. You probably need to find and clean your filter.
Feb 02, 2010 | Washing Machines
My MW511 model is not spinning , slow motion wash cycles, noisy
Hi blow down the hose that the waste water comes out of, it may be blocked
Nov 29, 2009 | Fisher and Paykel (IWL12)
Wont drain, wont empty, wont go onto rinse, drain or spin during
The filter on this machine is behind the flat at bottom right of machine. Tilt machine back before unscrewing to avoid spillage. If filter is clear get back to me and will explore other possibilities.
Nov 16, 2008 | Washing Machines
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fills washes rinses but wont spin properly or empty out washer, ends cycle half done, wont pump water out or spin out. i can hear the machine hum while trying to do so. Please any ideas. THanks
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Oct 19, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Washing Machines Logo
427 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
