Question about Electrolux EOB6630 Ultrafan Electric Single Oven
Oven comes on, heats up to warm, but does not get any hotter. grill works ok.
5 Suggested Answers
abhishek33
  • 1239 Answers
SOURCE: EOU6330 grill doesn't heat-up all the time.
hi Step 1: Check the power cord, the plug, and the outlet. Then look for blown fuses or tripped circuit breakers at the main entrance panel or at a separate panel.
Step 2: If the range is receiving power, set the timer on the range to the MANUAL position.
Step 3: If the element still doesn't heat, turn off the power to the range and test it with a VOM set to the RX1 scale thank u................
Posted on Sep 12, 2008
  • 417 Answers
SOURCE: Main oven light and fan comes on but no heat.
Check that the oven timeclock is not set to 'Auto' as if so this will prevent the oven from working. It should be set to 'manual'.
Try this and then reset oven.
Posted on Dec 23, 2009
SOURCE: Oven is not heating. Fan is working and grill wor...
This would appear to be the ring element around the fan that has failed and will need to be replaced.You will need to power off unit,then remove the back panel inside oven 4 screws in corners,Be careful with Thermostat held in place by clips above or on back panel.You may find 3 or 4 screws holding ring element.Gently pull towards you,being careful that the cables come with it.Check element with multimeter to see if open circuit if its ok then it may be a thermostat fault.If it is a faulty element,
get your replacement element,remove the cables off old one and put onto new one.Then push back into place and refix all.
Hope this helps.
Posted on May 23, 2010
  • 196 Answers
SOURCE: My Electrolux EOB5610 fan oven
Sounds like you element is faulty. You can check it by removing the panel in front of the element which is held on by 4 screws then you can visually check it to see if it has blown. If it looks ok then unscrew the element and carefully pull it towards you a couple of inches, this will allow you to pull the 2 wires off, make sure the wires dont fall back inside the machine or you will need to remove the back panel. The use a multimeter on the buzzer or sounder setting and place a probe on each of the pins on the element and if it doesn't buzz or sound then the element is faulty. Make sure you have the electric switched off at all times. Hope this helps
Posted on Feb 23, 2011
I have chef EGC651S oven with separate grill. On fan assist oven only heats up to a certaain temp and doesnt get any hotter what could be the reason for this
Probably thermostat problem, although some chance you have one side of a 220vac breaker not working. In otherwords oven heating element is "getting" half of the required power. Call electrician!
Mar 08, 2015 | Ovens
Top element not warming but does work when grill is activated
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer?
http://how-2-repair.com/buy-paul-a-beer/ Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 11, 2014 | Smeg Ovens
Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
Main oven light and fan comes on but no heat. Reset clock. Happened after power trip. Small oven and grill works OK.
Dec 23, 2009 | Electrolux Ovens
Teka h e 500 oven wont heat up....
If the fan is working o/k then the oven element is probably faulty, this should be at the rear of the oven behind a removeabkle cover.
Make sure you have the control set to grill , for grilling
Dec 03, 2009 | Ovens
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Oven not heating
You need to replace the fan oven element.
access to it is by removing the rear panel in the oven, there you will see the element.
Plz rate my solution.
Thanks.
Dec 18, 2008 | Whirlpool AKZ159IX Oven
Sep 11, 2008 | Electrolux EOU6330 Electric Double Oven
Stoves 720ef top oven warms but does not reach high temps. element replaced - no fix. thermostat ok as heating light cycles on and off at around 120 deg C, but reluctant to get hotter.
Have the same problem. Went and bought an oven thermometer from Lakeland and found that when the top oven thermostat was set to 160, the temperature only got to 140. I did clean the sensor inside the oven using a cleaner from Lakeland which did improve matters but it is still running cooler that it should. ( It takes at least 20 to 30 mins to warm up)
May 01, 2008 | Stoves 720EF Electric Double Oven
Electrolux EOB6630 Ultrafan Electric Single Oven Logo
19 people viewed this question
Top Electrolux Ovens Experts
ashburton
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
