Question about Microsoft Xbox 360 Console
360 won't read update disc
I tried downloading the update file from microsoft to my laptop and then burning a cd-r and dvd+r but get "unplayable disc" error message on my 360. I tried the drag and drop method and also used Sonic to burn the discs on a laptop and attempted this on my home computer as well. Is there a particular disc format that works? Games, dvd's and cd's all play fine.
    President:
  • 4,402 Answers
Bad Cdrom/dvd
The laser going bad is a pretty common issue with the drives, since it's a Hitachi that spindle motor could be all gunked up with dirt as well and cause that issue also.
if ya have a Hitachi, if it's a Samsung it could just be the laser.
http://www.llamma.com/xbox/Repairs/xbox_dvd_repair.htm
Posted on Dec 17, 2007
Why won't Xbox update?
To resolve this problem, try the following solutions.
Solution 1: Check your Xbox Live connection
If you're having problems connecting or staying connected to Xbox Live, see I get an error message when I test my Xbox Live connection.
If you still experience the problem, try the next solution.
Solution 2: Clear the system cache
Removing the temporary files on your console might solve the problem. Follow the instructions at How to clear your Xbox 360 system cache. Then, try downloading the update again.
Solution 3: Copy the update to a USB flash drive, CD or DVD
Copy the console update from your computer to a USB flash drive, CD or DVD, and then install the update on your console. Here's how:
Copy to a USB flash drive
Note The USB flash drive must use the FAT32 file system.
  1. Plug your USB flash drive into a USB port on your computer.
  2. Download the update file.
  3. Click Save to save the console update .zip file to your computer.
  4. Unzip the file:
  • If you are using Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
  • If you are using an earlier version of Windows, you need to use a special software program to unzip the file (for example, WinZip).
  1. Copy the contents of the .zip file to the root directory of your USB flash drive.
  2. Unplug the USB flash drive from your computer.
  3. Plug the USB flash drive into a USB port on your Xbox 360 console.
  4. Restart the console.
  5. When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
Burn to CD or DVD
You can also download the update to your computer, burn the update to a CD or DVD, and then install the update on your console. Here's how:
  1. On your computer, download the update file.
  2. Click Save to save the console update .zip file to your computer.
  3. Unzip the file:
  1. Insert a blank, writeable CD or DVD into your computer.
  2. Copy the contents of the .zip file to the root directory on your CD or DVD, and choose to write (burn) the files to the disc.
  3. Once the files have been burned to disc, remove that disc from your computer and insert it into the disc drive on your Xbox 360 console.
Dec 15, 2013 | Microsoft Xbox 360 Console
Need system update
Connect your Xbox 360 to your router via an ethernet cable and download the update from directly from Xbox Live. Alternatively, you can download the update on your computer and either burn the file to a CD/DVD or drop the file onto a Memory Stick and put that into the Xbox to run the update. Most newer games have the newest update directly on the game disc. Direct link to Microsoft: http://support.xbox.com/en-us/pages/xbox-360/how-to/update-xbox-360/system-updates.aspx
Apr 23, 2011 | Microsoft Xbox 360 Console
How to update your xbox360
The easiest way to update your console software is to connect to Xbox LIVE. To update your console by using Xbox LIVE, all you need is an Internet connection.
  1. Connect your Xbox 360 console to the Internet. To learn how, please see Connecting to Xbox LIVE.
  2. On the console, go to My Xbox, and then select System Settings.
  3. Select Network Settings.
  4. Select Wired Network or the name of your wireless network, if you are prompted to do so.
  5. Select Test Xbox LIVE Connection.
If you cannot connect your Xbox 360 console to the Internet, you can copy the console update from your computer to a USB flash drive and then install it on the console.
Note: The USB flash drive must use the FAT32 file system.
  3. Click Save to save the console update .zip file on your computer.
  4. Unzip the file. If you are using Microsoft Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
  5. Copy the contents of the .zip file to the root directory of your flash drive.
  6. Unplug the USB flash drive from your computer.
  7. Plug the flash drive into a USB port on your Xbox 360 console.
  8. Restart the console.
  9. When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
You can update your Xbox 360 console software by downloading the update to your computer from Xbox.com, burning the update to a CD or DVD, and then installing the update on your console. Here's how:
  2. Click Save to save the console update .zip file on your computer.
  3. Unzip the file. If you are using Microsoft Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
    • If you are using Microsoft Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
    • If you are using an earlier version of Microsoft Windows, you need to use a special software program to unzip the file (for example, WinZip).
  4. Insert a blank, writeable CD or DVD into your computer.
  5. Copy the contents of the .zip file to the root directory on your CD or DVD, and choose to write (burn) the files to the disc.
  6. Once the files have been burned to disc, remove that disc from your computer and insert it into the disc drive on your Xbox 360 console.
  7. Restart the console.
  8. When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
Feb 04, 2011 | Microsoft Xbox 360 Console
The x box says system update stopped..what has happened? how do i fix it?
Came across a link that might be of some use to you, here's what it says:
Get Updates for Your Xbox 360 Console There are three ways to get updates for your Xbox 360 console:
Update through Xbox LIVE. Copy update to a USB Flash Drive. Burn a DVD or CD. Update through Xbox LIVE
Getting the update free on Xbox LIVE is the best option because your console will be automatically updated as new system software is released.
To update your Xbox 360 console on Xbox LIVE, you must have an Xbox LIVE account with either a Gold or Silver membership, and a broadband Ethernet connection.
To update on Xbox LIVE: Connect your Xbox 360 console to your broadband connection. If your console is not connected already, see Connect to Xbox LIVE. Note Your console will be restarted when you join Xbox LIVE, so be sure to save your game progress. Create an Xbox LIVE membership or add one to your offline profile, if you haven't already. Go to the Marketplace area of the Xbox Dashboard and select Join Xbox LIVE. Follow the steps for creating a profile. You can also add an Xbox LIVE membership to an existing profile by selecting Join LIVE from the Xbox LIVE area of the Xbox Dashboard. You may be asked to update the software on your console. Select Yes and wait for the update to finish. Future updates will be installed automatically, as long as you are signed into Xbox LIVE. Copy the Update to a USB Flash Drive
If you don't have an Xbox LIVE account or have a slow Internet connection, using a USB flash drive is a good option.
Update using a USB flash drive:
Connect your USB flash drive to a USB port on your computer. Click here to begin downloading the update folder. Save it as "$SystemUpdate9199.zip" anywhere on your computer. Unzip the File. Copy the contents from the unzipped folder onto the root of your flash drive. Safely remove the flash drive from your computer and plug it into a USB port on your Xbox 360 console. If your console is on, turn it off, then back on. The update program will start automatically. Select Yes, update now. When you see the new dashboard, you're done. Burn a DVD or CD
Your other option is to download a file from Xbox.com and burn a DVD or CD. Use this method if you don't have your console connected to broadband, or if you use a dialup connection to the Internet. You could even do this at a friend's house who has a broadband Internet connection and a DVD or CD burner.
To create an update disc you need the following:
A DVD or CD burner. A blank, writeable DVD or CD. The update file from Xbox.com. This procedure involves burning the DVD or CD by using Microsoft Windows DVD or CD burning software. If you're using third-party CD/DVD writing software, follow the instructions for creating a data disc.
The same steps apply whether burning a CD or a DVD.
To create a DVD or CD:
Click here to begin downloading the update folder. Save it as "$SystemUpdate9199.zip" anywhere on your computer. Place a blank disc in your burner. From Windows Explorer, select Open Writable CD Folder Using Windows Explorer or open the CD drive icon. Open (double click) the zipped $SystemUpdate.zip folder and drag the contents of the zipped folder to the root of the CD Folder. If the CD write window doesn't open by default, drag and drop the folder onto the CD/DVD RW drive. Note If you are using an earlier version of Windows you will need to open the file using a separate utility (for example, WinZip). In the Explorer window, click Write files to CD from the CD writing tasks or right-click the CD/DVD RW drive and select Write these files to CD. Caution The update filename and folder structure must be intact for the update to run properly. Follow the steps in the CD wizard. When you are finished with the wizard, the CD will eject. Your CD is ready. To update the console:
Place the CD in the Xbox 360 console.
Power cycle the Xbox 360 console. The update program will start automatically. Select Yes, update now and press A. Wait for the update to complete. When the console reboots, you're done. If this does not work then you need to sand your xbox in to microsoft.
Keep Checking Daily for the new update.
Jan 01, 2011 | Microsoft Xbox 360 Console
I haven't updated my xbox in a while, and now that im trying to test xbox live connection everything checks and when i agree to update it loads for about 10% then it tells me it update failed.(cannot...
Hi miraya666,
This normally happens because of your internet connection or not enough space on your hard drive.Verify you have some space on your HD, if you do - I would recommend updating a different way. Here are some ways:
Copy the Update to a USB Flash Drive The USB flash drive must use the FAT32 file system.
  1. Connect your USB flash drive to a USB port on your computer.
  2. Go to the Xbox download page to download the update folder.
  3. Save $SystemUpdate_ Fall08_7363.zip to your desktop.
  4. Unzip the File.
  5. Copy the contents from the unzipped folder onto the root of your flash drive.
  6. Safely remove the flash drive from your computer and plug it into a USB port on your Xbox 360 console.
  7. If your console is on, turn it off, then back on.
  8. The update program will start automatically. Select Yes, update now.
  9. When you see the new dashboard, you're done.
Copy the Update to a CD or DVD To do this, you need a blank CD or DVD (either will work) and a computer that can burn files to the type of disc you have.
Burn the Update to a CD or DVD:
  1. Go to the Xbox download page to download the update folder.
  2. Save it as $SystemUpdate_ Fall08_7363.zip anywhere on your computer.
  3. Place a blank disc in your computer's disc burner.
  4. Unzip the file.
  5. From the Windows Explorer, double-click on the CD or DVD drive that you're using to burn the disc.
  6. Drag the contents of the unzipped folder into the root of the CD or DVD drive.
  7. In the windows explorer window, right-click the CD/DVD RW drive and select Write these files to CD. The NXE update filename and folder structure must be unchanged for the update to run properly.
  8. Follow the steps in the CD wizard. When you finish, the CD or DVD will eject, and your disc is ready.
  9. Put the CD or DVD in your box 360 console.
  10. Turn your console off, then back on.
  11. The update will start automatically. Select Yes, update now.
  12. When you see the new dashboard, you're done.
Before giving me less than a very help full rating, please give me a chance to be very help full! Thanks!
Mar 30, 2010 | Microsoft Xbox 360 Console
Update Failed Message on Xbox 360
SoulSlinger to_post_off.gif Mar 27 2009, 08:09 PM Post #7
X-S Enthusiast
Group: Members
I had change of heart, the guys over at 360mods prevailed on me to release this for free.
So for all to see , here is how you fix the update failed error in all cases:
The error seems to happen when the 360 is unable to read from the update source during the update. The only time I have actually seen it occur was when updating from a backup, which is a common cause Ive read about. The other common cause is an onset of RROD during the update. Im not sure what causes the hard drive error. Either way, the solution is simply to supply the 360 with the correct update file either on a CD or a USB stick. Now here's the rub, it has to be the exact same update file as the one that failed. Not a problem since I've made a nice torrent file with all of the updates to date here:
Google
The version number is shown at the bottom of the error screen. PV is for previous version and CV for current version. Just put the file matching the current version (the one you are updating to) on a USB stick, (i.e. E:/$SystemUpdate) put it in your 360, and power up. If you have the right one it will finish updating and boot to the dashboard. Voila.
This has worked for me on 7 consoles so far. 3 of them said they couldn't detect the hard drive and the other four the update disc, so this seems to work in all cases. I hope this can help some people out.
Oct 03, 2008 | Microsoft Xbox 360 Console
Unplayable disc
have you tried cleaning your Disc.
Jul 16, 2008 | Microsoft Xbox 360 Console
Unplayable disc
I've had similar problems and I got myself a CD lens cleaner.
Its a cd/dvd sized disc that has a few small bristle on it so when u put it into your drive, it spins and cleans the lens.
They are pretty cheap and you can get them in any electrical store and I've seen them in a few supermarkets.
Also check that your disc's are clean too.
Mar 23, 2008 | Microsoft Xbox 360 Console
My xbox 360 says update failed
Go to microsofts website.
You need to download a patch-file. it,s a free download, which you can either burn to a cd. and load into the 360.
or download online connected through xbox live.
i,m pretty sure it,s a small xdm file.
if you struggle doing it, mail me here and i,ll send you 1 through the post.
Mike @ Compurepair.
Feb 24, 2008 | Microsoft Xbox 360 Console
Unplayable disc
Open up the console and open up the CD Drive. Clean the lens of the CD Drive with some rubbing alcohol and a q-tip. Then put the console back together.
Dec 24, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
389 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
