Question about MGE Pulsar Ellipse 800 (89363) UPS System
My ups is switching off itself immediately the mains goes off.the battery is okay with 13v.
  • 32,281 Answers
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and enviromental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only a float voltage and a true indication of the battery voltage needs the batteries to be tested under a load. there maybe one battery that is faulty and causing the whole battery system to fail.
These lower powered and cheaper KVA type UPS are switch over types (when the mains fail, the UPS switches over to the inverter in milli-seconds to supply mains power). It is a possibility the inverter circuit is faulty and when the mains power fails the inverter does not switch over.
The true UPS type are usually the higher KVA units (over 1500 KVA units) that converts mains power continuously via the inverter circuit. The mains power charges the batteries and the inverter drawing power from continuously from the batteries (therefore there is no switch over time lag from the mains to the battery.
Posted on Sep 25, 2009
The above mentioned is totally true. Bad batteries can register 13.2 volts but have zero capacity to store or deliver energy. I learned this the hard way last weekend when performing a power outage test. There was a bad battery in one of the battery strings, when the UPS needed battery backup, the bad battery prevented the whole string from delivering DC power to the UPS. The whole UPS crashed and all loads went dead.
The best tool is a 500 amp carbon pile load tester. It found the poor batteries instantly. Replaced the bad batteries and the system is 100% again.
Posted on Sep 17, 2012
    Novelist:
  • 169 Answers
Just because the batt measures 13V does not mean that it is ok, this does not tell you the batt will deliver current, suggest try very small load eg 100Watt lamp. Unplug mains see what happpens if lamp goes out then new batteries I think.
Check manual and look at batt with ups sw.
Thanks for asking FixYA, hope this helps.
Posted on Sep 27, 2009
My Samsung LED tv doesn't turn on. No standby light. What do i need to check, to see what board is damage? What components is important to check? What to replace?
The main circuits are check before the TV is turned on. When high voltage was checked, was it 391 volts or more at the large capacitor? A voltage below 390 will shutdown the TV.
Jan 12, 2018 | Samsung Televison & Video
Questions on repairing a television that intermittently turns off on it's own and may not turn on again?
your problem is on your side control disconnect the cable and used your remote control to turn the tv on and off and see what happen
Dec 02, 2015 | Samsung LN40B610 LCD TV
Hi i'm not getting any ac volts to the rectifier, Whats the next step to check. Yesterday on and off I had 13v to the battery.
Did ya check the battery load, as you have said the voltage output to battery is 13V and thats normal! Battery might have been discharging itself! Go to ur nearest battery shop and test load it!
Jun 15, 2011 | Yamaha Ark 50 Paddock Motorcycles
My ups is switching on on battery for few seconds but without AC output, the same thing when I put AC power it switches on normally but also without AC output.What can I Do? Please help
does it have a led display for battery charge? if it is very low battery is bad,when you add a/c no output because bad battery will not provide a/c in power failure
Feb 02, 2011 | Powercom (BNT-1500AP) UPS System
Battery light is on
if they car is charging itself okay, 13v plus, check that single terminal wire going to alternator, corrosion will cause bad contact, wiggle it around and see iff light goes out
Aug 22, 2010 | 1997 Ford F150 Regular Cab
When i drive, there is a light on the panel reading "Power" which remains on all the time.
There's an issue with your alternator...
Take a voltmeter and test the connection at your battery and see if it's charging between 13V-14V... if it's lower than 13V, it's not charging your battery properly. If it's over 14V, then it's over charging and damaging your battery
Aug 24, 2009 | 2002 Suzuki XL-7
Screen goes dim and barely readable
You have it on the battery saving mode. Go to Settings > Phone Settings > Power Save > turn it OFF.
Sep 16, 2008 | LG Shine KE970 Cellular Phone
The PDA turn off and it will turn back on immediately later ......
I get much the same, but it comes and goes. For a week or two it will behave itself, then goes pop for a month or three! Do you find if you have external power (cradle or USB) that it will switch off? I also find that if I switch it off from battery power, it will switch itself back on, but then the power switch is ineffective for 6 or 7 seconds. Then you can switch it off, only to repeat the whole excercise again (and again, and again, and again...)
Sep 08, 2005 | Toshiba e740 Pocket PC
MGE Pulsar Ellipse 800 (89363) UPS System Logo
464 people viewed this question
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
