Question about Toshiba SD-6000
DVD picture flashes on & off
SD-6000 hooked up with HDMI cable to a Yamaha RV661 AV Reviever. The picture on the Sony LCD flashes on & off at one second intervals along with the sound. Tried full reset on the RV661 but still have this problem. The DVD player, when hooked up directly to the LCD works fine.
  • 4 more comments
  • iflyrc2 Dec 16, 2007
    Ok I should proof read! .... RX661 receiver
  • iflyrc2 Dec 25, 2007
    OK went back to store... everything worked perfectly there. Swapped out DVD player and Receiver...still the same so it's the wire between the receiver and LCD that is the issue...arghh!
  • Anonymous Feb 15, 2008
    same problem as iflyrc2, did the cable fix the problem?
  • iflyrc2 Feb 15, 2008
    The flashing picture/blue screen is a "handshake" issue between the two systems. (Differnt versions arghh!!! ) We swapped the HDMI for Component and it worked fine after that.
    Hope this helps... Lesson - buy the same brand equipment and it will work for sure.. er.. well hopefully :-)
  • Anonymous Jun 05, 2008
    I have encountered the same problem. HDMI to reciever to DLP doesn't work. Only Component cables work.
  • Anonymous Mar 16, 2014
    I have tried everything but can't get a picture on the tv. It says NO VIDEO SIGNAL. I am using the Red, Green and Blue cables, plus monster audio cables. There is no port for an S cable on the tv and no port on the dvd for HDMI PLEASE HELP!!
Our problem was because the hdmi on reciever was not compatable with hdmi on dvd player, different versions ex. 1.2, 1.3 , 1.1
ended up using component inputs instead
Posted on Feb 15, 2008
My DVD 958 not showing with the hdmi cable through the television
You first should hook the device up with AV cables, after you uses AV cables , you will get a picture, once you get a picture, you need to go into the setup menu and turn on HDMI, once you do this, then you can switch to the HDMI cable.
Jan 29, 2013 | Coby DVD-958 Theater System
Trying to hook up my wii but have sound and no picture I have HDMI cable from tv to yamaha v373 amp and trying to connect the red white and yellow cables to back of amp
Need to put yellow cable into monitor in and choose a input with video vcr, tv, or dvd. still no luck then yellow directly to tv.
Dec 08, 2012 | Yamaha RX-V373 5.1 AV Home Theater...
I would like to hook up my components without having to turn on the receiver to watch tv from DVR or Cable if possible. I have Scientific Atlanta Explorer 8300 HD Cable DVR w/HDMI out, Samsung TV w/HDMI ,...
You should not lose any picture quality from the DVD player. I am currently having the similar setup with PS3 as the Blu-ray DVD player with HDMI and a Samsung DVD as regular player with component cable to a Samsung LCD TV. Remember the quality on Blu-ray is better than normal DVD so don't expect more than what it is.
Oct 07, 2009 | Yamaha RX-V463 Receiver
I have the LG Dn798 hooked up through my Yamaha receiver
Does it work via component or in a different HDMI port? If it does it sounds like either a bad HDMI input on the tv or a bad HDMI output on the receiver.
I would also verify that the receiver is 100% compliant with the HDMI standard as not all devices are.
Jun 03, 2009 | LG DN798
The Yamaha RX-V463 AV does not playsound from the blue ray player
"I am also having difficulties in try to display the yamaha set up menu on the tv."
According to the manual the display menu for TV will not work with HDMI hook up.
I also have a Panasonic HD TV and can't get TV sound through my Yamaha AVR on "TV Sound" mode.  Trying to use HDMI cable for this also.  Do I need a digital optical cable or do I not have something set right?
Apr 07, 2009 | Yamaha RX-V463 Receiver
How to hookup yamaha rx-v730 receiver to projector & cable unit.
hook up hdmi cable from cable box to receiver hdmi input 1 then from hdmi out to your projector or tv,i don't know what kind of inputs you have on your projector .whatever you have run from projector to receiver input example component red,blue,green then run from both say to the av input 1 then set your receiver to av1 and you should get picture.
Jan 25, 2009 | Yamaha RX-V730 Receiver
Yamaha RX V-663 video output into old Coaxial TV
You need a coax to RCA converter. Do a google search, Belkin makes one, Radio Shack probably has one too.
Jan 11, 2009 | Yamaha RX-V461 AV Receiver
Toshiba SD-6000 Logo
293 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
