Question about Dell Optiplex G240 (OPTIG240) PC Desktop
What type of ram goes into a d 240 optiplex - Dell Optiplex G240 (OPTIG240) PC Desktop
  • 119 Answers
400MHZ PC3200 DDR its up to you if you use 256mb or 1g up
Posted on Sep 25, 2009
  • 3,267 Answers
The RAM requirement are as given below
RAM installed: 128 MB Number of memory slots: 2 RAM capacity: 1.024 GB RAM type: DDR SDRAMYou can check it out youreslf too by visiting this site:
http://reviews.zdnet.co.uk/hardware/desktops/0,1000000973,10001560,00.htm
............................................................sodeep
Windows 7 has been installed in my optiplex gx 240 pc but this is no drivers for sound , lan drivers to fix the problem
Go to the Dell support site on another computer,and look for drivers for you computer model. Download them on a usb drive or on an SD card and install them on you Optiplex computer.
Sep 22, 2013 | NEC Black Nec/dell Optiplex Gx-150/240 Ide...
Put in new ram but only ses 256k?
The new RAM most likely not compatible with the existing RAM.
Use RAM from the same manufacturer and type/speed.
This model Dell uses DDR2 SDRAM memory and can only support up to
4 Gb of RAM
Mar 21, 2012 | Dell OptiPlex GX520 PC Desktop
Sx280 upgrade 2mb ram blank screen
If you are referring to computer RAM always put the largest ram module closest the CPU central processing unit
try to keep the same brand and type of ram the same ie: ddr ddr3.......
you will be able to read the ram type on the ram already inside
make sure you secure the ram modules by pressing the levers down firmly at both ends of of there sockets
make sure your computer is turned of before you attempt this
be sure to wear an earth strap before touching anything inside your computer
the ram modules sockets are located near your cpu
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope this helps you
Mar 09, 2012 | Dell Computers & Internet
I have problem with how to identify Ram type E.g DDR1,DDR2
DDR1 RAM: Has 180 pins, typically a double sided memory module. DDR2 RAM: Has 240 pins, only fits one way opposed to DDR3 RAM. DDR3 RAM: Has 240 pins, voltage is 1.6V and only fits one way.
Jun 29, 2011 | Computers & Internet
I am installing a 64-bit OS in my dell optiplex 960 desktop and i want to max out the memory on my PC.What is the maximum memory it can support and what is the best memory i can put in it and what can i...
You have 4 slots and each slot can support 4 gigs so you can have 16 gigs of ram total. I like corsair or Kingston ram the best. And when you are buying ram you want to look at three things. First is the type of ram which your type of ram is ddr2, second is ram speed which is measure in mhz you want the highest mhz you can get and last is latency, which you want the lowest latency you can get :) hope this helps. Visit newegg.com they have great deals its where i buy all my computer parts from :)
Dec 30, 2010 | Dell OPTIPLEX 960S Desktop Computer
When i switch on my computer, after showing the dell optiplex at the start, it goes off. What could be the problem and possible solution.
There may a problem with ur ram. Remove the ram and bios battery and place it again. If your problem again exists, replace the ram and try
Sep 27, 2010 | Dell OptiPlex 210L PC Desktop
When you switch on the pc(dell optiplex gx 260),
Pop the case and make sure the video card, RAM, and CPU is all seated correctly in their slots, and then make sure all fuses you can see inside/outside the case are in good shape (if applicable)
Jun 15, 2010 | Dell OptiPlex GX260 PC Desktop
Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
Feb 09, 2010 | Dell OptiPlex GX260 PC Desktop
NMI:parity check /memory parity error
In my experience, you get a memory parity error when one of your memory sticks has gone bad.
I don't know how many sticks of memory you have or what size they are, but you can try removing one and see if the error goes away. If not, remove another and try again.
You're probably looking at buying some new memory. If so, use the opportunity to increase your memory within the limits of your operating system.
Win XP, 32 bit, will see up to about 3.2MB of RAM
64 bit can see over that up to about 8MB
Jun 16, 2009 | Digital Audio Labs CardDeluxe Sound Card
Type of RAM for Dell Optiplex gx110
the easiest thing to do is go to crucial.com and click scan my computer, and it will tell you which type of ram your motherboard takes http://www.crucial.com/
Jun 22, 2007 | Dell Optiplex GX110 (2909T) Motherboard
Computers & Internet Logo
131 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
