Camera turns on zooms in out etc makes some noises then goes off
SOURCE: My pentax optio M30 turns off after it's on...
Pentax Tech Support will have the remedy- this is where to answer lays- there is no user remedy.
SOURCE: Pentax Optio WP
This suggests the lens motor/gearing has failed- I guess other aspects of the system wait for the lens to extend before coming active - possibly due to the waterproofing system. You can only go back to Pentax with this problem.
SOURCE: Pentax Optio 50 Digital Camera Lens Error
Not really, it sounds like the lens has been bumped while it was extended. Unfortunately, the "buzz" you hear is the gears stripping one another. The only fix is to have the lens assembly replaced, which usually costs upwards of $200. I see this problem at least 3 times a week in my shop.
SOURCE: Pentax Optio M30
Make sure your battery is charged and if so, take it back to the place you bought it from.
SOURCE: Pentax Optio M20: won't work.
ok have same problem press the power button and and the play> button at the same time. your screen will come on but not lens. then hold the play button down untill lens come out. this will work for you , you may have to do it a couple of times but it will work
