I have the same problem, when i turn the camera on the lens makes a funny noise and the lens tries to come out 4-6 times however appears stuck (i.e. gears aren't working or something internally is stopping it) so it turns itself off.
Any suggestions?
SOURCE: camera lens
spounds like theres a problem in the lens gearing system. if theres a jammed gear and you try to force it you WILL cause 3 times the damage to the mechanism.I fyou know how and only if you know how to dissassemble the front case as well as the lens cover then see if when yoiu loosen the drive motor if you can move the unit or lens assy. if you can then the gear system inside the motor its self is bad and the whole motor assy has to be replaced. if I were you I would contact number800-488-7669 and find out what they charge to repair the camera. Good Luck
SOURCE: lens error
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
SOURCE: olympus fe170 lens stuck
SOURCE: IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
SOURCE: When I turn the camera on it makes a few noises then shut off
i called the company (1-888-553-4448) olympusamerica.com and they told me to send it in and they will repair it for 70.95 plus a 6months warranty because i cant find my reciept. they also said what eva is wrong with it they will be able to repair it, but if u have ur warranty u can send it to them it wont cost u anything because u have ur reciept.
