Question about Microsoft Xbox 360 Console
Error message no73 and a red line - Microsoft Xbox 360 Console
  • sharon474 Sep 25, 2009
    Many thanks but the machine is 18 months old so it may be out of warranty so would that mean purchasing a new machine?
  • 490 Answers
This is what your error means it cant be fixed but should be covered by the warranty..... E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
Posted on Sep 25, 2009
Testimonial: "MANY THANKS THOUGHT THAT WAS THE CASE"
  • marley mcelhinney Sep 30, 2009
    ok unfortuneatly you will have to get a new one unless you can find a quick fix for it on the net
Cant get on line keeps asying undefined error happens lots sort this mater yours faithfully hilly
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured or click start type in event viewer press ENTER you might be able work your way through the problem if you need more help with this post a reply with the error message details Hope it helps.
Dec 07, 2012 | Computers & Internet
I have a BlackBerry Pearl 8100, and every time I try to send a sms text message I get a Protocol Error
Hi, go to your wireless provider web site and got their proper number "SMS Message Center Numbers".
On the phone, go to Options/SMS Text, move down to the Service Center line and put in the proper number remembering to put the + plus sign in front of it. So if you get a Protocol Error and a Red X when trying to send SMS text, check this to fix it..
Feb 10, 2011 | RIM BlackBerry Pearl 8100
Xbox-360 elite lower right hand red flashing led light code error E73
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 17, 2011 | Microsoft Xbox 360 Console
Xbox 360 one red light bottom right
Nov 05, 2010 | Microsoft Xbox 360 Console
On line error
red line error problem
May 03, 2010 | Samsung ML 1610 Laser Printer
One red light on xbox 360
In most cases If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages.
HERE IS THE RED LIGHT REPAIR MANUAL: http://docs.google.com/viewer?url=http%3A%2F%2Fpdftown.com%2Fpdf-ebook%2FXBOX%2520360%2520Repair.pdf
Oct 19, 2009 | Microsoft Xbox 360 Console
When I text it won't send the text and I get a red box shape with a diagonal line in it instead of a check or an envelope.
It is indicating that text is pending, may be pin number is wrong or the email id is or etc you may also get the error message, please let us know the errror message
Aug 17, 2009 | T-Mobile BlackBerry 7105t Cellular Phone
Switch computer on and the light is red but on the screen it says system error contact xbox customer support
SYMPTOMS loadTOCNode(1, 'symptoms'); You receive the following error message in multiple languages: System Error. Contact Xbox Customer Support. CAUSE loadTOCNode(1, 'cause'); Typically, this error message is caused by a hardware failure. THINGS TO TRY loadTOCNode(1, 'whattotry'); Note If you receive an error message and see one flashing red light on the front of the console, see the following article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/) Xbox 360: One red light flashes on the Ring of Light and you receive an error message 1. Turn off the console, disconnect and then reconnect all cables. Turn the console on again. 2. If an Xbox Hard Disk Drive is attached to the console, turn off the console, and then remove the Hard Disk.
For more information about how to remove the Hard Drive, click the following article number to view the article in the Microsoft Knowledge Base: 906204 (http://support.microsoft.com/kb/906204/) Xbox 360: How to attach or remove the Xbox 360 Hard Drive Turn on the console, and then test for the error message. If you do not receive the error message, turn off the console, and then reattach the Hard Disk. Alternate testing with the hard drive connected and removed to see whether the error message occurs only when the hard drive is attached. If the on-screen alpha-numeric error is E67 in the error message, see the following article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/) Xbox 360: One red light flashes on the Ring of Light, and you receive error E67, E68, or E69 3. If an Xbox Memory Unit (MU) is plugged in to the console, turn off the console, and then remove the Memory Unit. Turn on the console again and test for the error message. If the error message does not reoccur, turn off the console, and then reinsert the MU. Alternate testing with the MU inserted and removed to see if the error message occurs only when the MU is inserted. 4. If you continue to experience this behavior, contact Xbox Customer Service.
Jul 17, 2008 | Video Game Consoles & Games
Toshiba
your convergence ICs need to be replaced. There are two of them they are both STK392-110 you can get replacement Ics and free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
Jun 05, 2008 | Toshiba 50H81 50" Rear Projection...
TOUCH FOCUS ERROR on Projection Toshiba TV
My 57H81 won't converge, plus I get the "touch focus error" message. I could get manual convergence of blue, but not red. Plus, during touch focus the red would not move horizontally
Nov 25, 2007 | Toshiba 57H81 57" Rear Projection...
Microsoft Xbox 360 Console Logo
56 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
