Question about Powercom (BNT-1500AP) UPS System
My ups shuts down after ac power goes off - Powercom (BNT-1500AP) UPS System
  • 832 Answers
1. Open the UPS housing using a screwdriver.
2. Check the fuse. If is busted, have it replaced.
3. If the fuse is alright, check the battery terminal
for the stored voltage. It must be at least + or -
10% of the rated voltage of the battery. The rated
voltage is located at the battery. (12 volts). If the
voltage is below, 8 volts or only 30% of the rated
voltage. It must be replaced.
4. If the battery
Posted on Sep 25, 2009
  • rolando ingking Sep 25, 2009
    4. If the battery is Okey, plug the UPS to the electrical outlet, and read the voltage at the battery terminals with the power on. This must be higher than the battery rated voltage to charge the battery
    of your UPS. If the voltage is the same, as that of the battery when it was not yet turned on. Then,
    you have a defective trickle charging IC.
    5. If the trickle charging IC is defective., your option is to buy a new unit or have the IC replaced.
    Note: To take the voltage reading, use the multi tester, set it at DC volts - 25v.
    You may take the AC voltage reading coming from the power outlet, set it at AC volts - 250v
    To have a continuity test, set the multitester at R x 1 Ohms.
    6. Send an e-mail to me if you get it working, thru fix ya.
  • Akoni M. Mar 22, 2013
    I tried your suggestion above because my ups turns off also after ac power fails, I measured the battery when the ups is off and it is 10V DC,when i plug the ac power i measured again the battery using tester and it reads 13V DC, what might be the problem of the ups
  • 742 Answers
It is supposed to stay UP beeping for a couple of minutes before going down. When it abruptly turns OFF when AC power is cut off, then your UPS battery is dead not holding charge anymore
Why does it work for a few hours, then shut off?
Sounds like you may have ice build up on the coil. This will cause the refrigerant pressures in the AC to go out of desired range and cause the unit to shut down. Ice build up can be caused by a dirty filter or blocked coils in the front of the AC or a fan not running up to speed. There could be another problem with the AC refrigerant charge, but normally the homeowner can not fix that. If the unit shuts down, it will not start again until the pressures equalize.
Jun 07, 2015 | Frigidaire FRA144HT2 Air Conditioner
Screen goes off
On battery the laptop will shut down and dim display to conserve battery, by tapping any key or touchpad it should come to life. That said, Open Control Panel, Power, Advanced Power settings, Change to High Performance, monitor shut down to never on AC , Select/Adjust advanced power settings to your preference.
Dec 29, 2012 | HP Compaq Presario CQ70-120US Laptop
Just got cq56-115dx laptop this morning. turned it off after setting it up. Turned it back on and only have blank screen. Power shows lit up.
Hi.
Remove the AC power (charger) and then take the battery out. Plug in just the AC power supply and turn the laptop on, see if it boots up and shows a display on-screen. If it boots let it boot up and then shut it down as normal. Reinsert the battery and try as normal.
If you still get a blank screen can you then tell me if you get any post (splash) information like the Compaq Presario logo before it goes blank.
Good luck.
Jun 28, 2011 | Compaq Presario CQ56-115DX Laptop
Computer was on AC power. Left unattended it shut down. Would not wakeup. Shut down fully, it would not come back up. Get a 2 short beep code. Invites an F1 to go to setup. Won't go to setup. Screen then...
Can you tell if your AC power cord is working? (Is there a light on the computer that comes on when it's charging?) If the power pack went dead, your battery could've died and now you get no power to the PC which is why it won't boot up.
To test, take out the battery and plug the AC cord in and try to boot up. If nothing at all happens without the battery, then your power cord or power pack is dead, and you just need to replace it.
May 29, 2010 | IBM ThinkPad T21 Notebook
Compaq Presario R3000. Push power button and lights come on then goes dead before booting. Occassionally Windows will start booting the it goes dead. Any suggestions?
Either the power supply is putting out too low voltage or the power jack is bad.Try moving the ac adapter tip around while its starting up to see if it keeps it running or shuts it off.If it makes no difference try another ac adapter that does work for sure and see if thats the problem.If neither approach works,then the HDD may be seizing or one of the ram sticks may be bad.Some sort of hardware conflict can cause shut downs.You would have to take the bootstrap approach to narrow it down to one pacific component.
Aug 02, 2009 | Compaq Presario R3000 Notebook
Electronic AC shuts down during power outage.
When I read this...this only tells me that some people are only as bright as a 15 watt light bulb.
You know they have these things on there to keep you alive, instead of catching on fire and killing you with smoke.
Leave it alone and follow the directions. You will live longer.
May 15, 2009 | Frigidaire FAH106N1 Wall/Window Air...
Toshiba laptop reboots when on AC Power
I have the same problem with my Toshiba too, prima facie, it looks like Toshiba and Vista don't make a good combo. I suspected this to be a pure hardware problem, but was disproven when I booted in safe mode. It does not have any problems with the AC Power on in Safe mode.
Jan 12, 2009 | ASUS G1S-A1 Notebook
Battery
need new batteries.
Jul 24, 2007 | Tomtom GO 300 GPS Receiver
Powercom (BNT-1500AP) UPS System Logo
755 people viewed this question
Top Powercom Computers & Internet Experts
vimal
vimal
Shekar Avadhani
Are you a Powercom Computer and Internet Expert? Answer questions, earn points and help others
