Question about Casio EXILIM Zoom EX-Z150 Digital Camera
When I switched on the camera, "Lens error 2" appeared on the screen. What is it? Please help. Thanks!
  • rsiu_092007 Sep 25, 2009
    What's the error, can it be solved?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
Hi there, i have a problem with my GZ-MG21u. error in HDD and always says"please remove lens cover".i tried to switch in sd card but still black screen appears.please help me to resolve so that i could...
On some cameras the lens cover engages a small censer that gives the message remove lens cap. fit and remove the lens cover a few time this may work , if not the censer may be at fault.
Dec 20, 2014 | Video Cameras
I cant use my camera it appers system error how can i fix this?
Please check if the lens can move free. If there is any obstruction, it will stop and the camera will give an error. Also never try to stop the lens from moving.
Start over again. Remove the battery, charge it. Place the battery and the memory card when you are sure the memory card is not in the locked position. Then close the battery door carefully, so the door is locked correct. Then switch on again.
If the error comes back, perhaps the lens is blocked inside (broken gear or something like that) you have to contact the service centre.
Jan 10, 2014 | Sanyo Xacti VPC-S770 Digital Camera
When we turn on our Sanyo VPC E1090 digital camera the lens does not appear to come out completely & we get an "lens error 0x0311" message on the screen then it turns off. WHAT IS WRONG!! ...
If lens does not appear to come out completely and camera gives error that means lens mechanism got broken internally and lens assembly will be replaced to solve the issue.
Lens replacement is not user level repair and local camera repair shop[ will do this job for you if camera is out of warranty.
Thanks.
May 28, 2011 | Sanyo VPCE1090 Digital Camera
The words "Lens Error" appears on the viewing screen
The lens does not fully extend, that's why it tries again. The lens probably does not extend or retract because of debris or a misaligned gear box. The lens can in about 50% of the cases be repaired without having to replace it. Try to return to manufacturer first. If you're out of warranty, there are third party place that fix them such as camera lens repairs. If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Jul 07, 2010 | Nikon Coolpix S210 Digital Camera
Error reading on screen on 1000e
Hello :
Here is what Canon said according some forums :
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
I hope this will help .
please don't forget to rate !
Apr 06, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Canon Rebel XT wont fully come on
Hi
Error 99 is usually a lense error and gives the only real clue as to what is going on with your camera. You can try this simple fix which comes straight from Canon. Follow the steps to help isolate the issue. Note the fact that you are currently not getting the Error 99 is probably a good sign according to the troubleshoot.
To isolate the cause of the issue, we suggest that you do the following:
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
Hope this helps. Please do rate my answer. Thanks.
Aug 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
E 18 problem
I dont know what error E18 means, check cannon support for that, but welcome to the world of DISPOSABLE CAMERAS, I have replaced 3 cameras in 3 years, 2 because of lens and shutter issuses.
Jan 26, 2009 | Canon PowerShot S2 IS Digital Camera
LENS ERROR 2 on my Casio Ex-V7
I read on the Casio website that this is due to an impact, meaning, the camera must have fallen or hit something really hard and strong.
Lens error 2 indicates that there is something wrong in the lens assembly. One possible damage concerns the image stabilization mechanism.
I also own a Casio EX-V7. My sister dropped it so hard that a dent has appeared on one of the front corners. Everytime I switch on the camera on record mode, LENS ERROR 2 appears for a few seconds.
Despite this, I can happily use the camera as usual. However, it's just annoying to see the Error.
I'm planning to bring it to a service center within a month from now.
May 26, 2008 | Casio Exilim EXZ75 Digital Camera
Reading lens error on nikoncoolpix l12
Hitting camera on desk once has partial fix.
When camera's batteries taken out & then put back in and the power on button pressed to switch camera on, the lens extends out & the camera now works.
BUT when the power button pressed to switch camera off the lens retracts AND a "Lens Error" msg appears on the LCD screen.
Just have to take batteries out to remove msg & start again as above but WITHOUT hitting the camera.
Thanks
Feb 07, 2008 | Nikon COOLPIX L4 Digital Camera
Casio EXILIM Zoom EX-Z150 Digital Camera Logo
99 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
