Question about BenQ Scan to Web 4300U Flatbed Scanner
Scanner is not found! Please check if 1. Scanner power is on 2. Cable is firmly connected
  • solan_2006 Sep 25, 2009
    scanner is not found! Please check if 1. Scanner power is on 2. Cable is firmly connected
SOURCE: MEM48U Flatbed scanner
My done the same way, but it just stop working one day after doing a windows download. At that time they was a download that work fine and it is still working, I forgot what web site I went to, but it was a Memorex site.
Hope this helps.
Posted on Jul 24, 2008
SOURCE: when select scanner, it says "scanner is not found".
Scanner Model ?
Posted on Apr 27, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: I have a scanner ACER PRISA 620P by LPT1
uninstall the photoshop restart you pc then install it againg. Restat the pc and try to use it.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Posted on Feb 01, 2010
  • 713 Answers
SOURCE: I have an Acer Scanner
go to devices and printers then you will see your scanner in there right click scanner then trouble shoot.
Posted on Feb 18, 2011
  • 332 Answers
SOURCE: I'm getting 2 error messages
I have many years experience repairing Canon scanners so here is my suggestion for you.
This is a common problem with all Canon scanners. If you do a lot of scanning or leave your computer on all the time and never shut it off. What is happening is the memory fills up with all of the images and it needs to be cleaned out. If you reboot (restart) your computer it will clean out the memory and your problem will go away. I always recommend that if your going to be scanning a lot then do it off a fresh reboot and you should be able to your hearts content.
I hope this helps you out.
Posted on Apr 01, 2011
Hplaserjet3005 52.00 error what could be the problem ?
52.00 ERROR A scanner motor error has occurred. Scanner motor rotation is verified at the initialization of a print job.
1. Verify that the scanner motor connector
and the ribbon cable from the ECU are
firmly seated on the laser/scanner assembly.
2. Verify that the scanner motor connector
is firmly seated in connector J402 on the ECU. You might have to remove the main cooling fan to see this connection.
3. Verify that the ribbon cable installed in
connector J403 on the ECU is fully seated. You must remove the ECU in order to verify this connection.
4. If the message persists, replace the laser/scanner assembly.
Sep 09, 2015 | Office Equipment & Supplies
1.scanner power is on 2.cable is firmly connected
When the scanne: 1.scanner power is on 2.cable is firmly connected what to do?
Dec 02, 2011 | BenQ Scan to Web 3300U Flatbed Scanner
HP M3027X - has 52.00 error code. We replaced the scanner but the error is still there. Any suggestions?
1. Verify that the laser/scanner motorconnector and the ribbon cable fromthe ECU are firmly seated on the laser/scanner assembly.2. Verify that the laser/scanner motorconnector is firmly seated in connectorJ402 on the ECU. You might have toremove the main cooling fan to seethis connection.3. Verify that the ribbon cable installed inconnector J403 on the ECU is fullyseated. You must remove the ECU inorder to verify this connection.4. If, after checking the cables, themessage persists, replace the laser/scanner
5. If, after replacing the laser/scanner,the message persists, replace theECU
Replacing the ECU isn't pretty. If you haven't done it before, you probably should get someone that has.
Sep 30, 2011 | HP LaserJet M3027x MFP Printer
I need the driver for Windows 7
scanner create an error when i used it.the error is no.1 scanner power is on & 2.cable is firmly connected.two objection are correct according to me
Sep 19, 2011 | BenQ Scan to Web 3300U Flatbed Scanner
My HP LaserJet P3005n, is not working properly whenever I want to print it initializes and then show Error 52 message.
52.00 ERROR
1. Verify that the scanner motor connector and the ribbon cable from the ECU are firmly seated on the laser/scanner assembly.
2. Verify that the scanner motor connector is firmly seated in connector J402 on the ECU. You might have to remove the main cooling fan to see this connection.
3. Verify that the ribbon cable installed in connector J403 on the ECU is fully seated.You must remove the ECU in order to verify this connection.
Jul 26, 2011 | HP LaserJet P3005 Printer
I have 2 Epson V500 Scanners, 1 of them I just have on standby. The one I use daily does not turn on. I tried using the cables of the standby unit already. I checked the fuses on the plugs of both...
  1. Check that the power socket switch is on Make sure your scanner's power cord is securely connected to the scanner and a working electrical outlet.
  2. If your scanner is supplied with a power adapter, make sure your scanner's AC adapter is securely connected to the scanner and a working electrical outlet.
  3. Make sure that the power outlet works. (If necessary, test it by plugging in another electrical device and turning it on.)
  4. Check that the power switch is on at the mains socket. If this is on, carefully check the power cable to ensure it is not damaged and remove then reseat it before attempting to turn the scanner on again. If your scanner has a power button, make sure that the button is depressed so it is turned on. Also, make sure that your outlet works and is not controlled by a wall switch or timer.
  5. Power off the scanner at the mains socket. Unplug the power cable from the socket, then remove and reseat the power cable from the scanner's power cable port. Plug the scanner back in at the mains and ensure the socket is switched on.
  6. If your scanner has a power button, does the power button depress when pressed? Press down firmly on the power button, if it is stiff and does not depress then there may be a problem with the button.
  7. Connect the scanner directly to the mains - not via a surge protector or extension lead. If your unit is connected via a surge protector or a power strip/extension lead, connect the unit directly to the mains socket.
  8. Try another suitable power cable. Check that other electronic devices connected to same power socket have power and try another mains socket and another power cable if necessary. Failing this try another suitable and known-working power cable. Depending on your scanner, a standard "kettle lead" or "figure of eight" power cable is used. If there is power to the scanner (indicated by an illuminated Start light), when a different power cable is used, then the fault is with the original power cable.
If the unit does not power on after following the checks above, contact Epson for support. If your scanner uses an AC adapter, then this may need to be replaced. If your scanner is over 12 months old, you can purchase a replacement AC adapter directly from Epson.
Nov 13, 2010 | Epson Perfection V500 Flatbed Scanner
I have a scanner ACER PRISA 620P by LPT1 connection and my OS is windows 7. When I run the software (photosop), i push the option "File" and then Import and then MiraScan 3.42.... The answer of Mirascan...
Feb 01, 2010 | AcerScan 620P Flatbed Scanner
Benq scanner type S2W 4300U does not have a driver with W Vista
May 19, 2009 | BenQ Scan to Web 4300U Flatbed Scanner
When I scan back screen comes up blue and words and numbers are
http://fixunix.com/hewlett-packard/101142-scanjet-5400c-dead.html
following this link i've found resetting instructions for this scanner:
1.. Disconnect the USB cable and the power cable from the
scanner. Make sure the power cable is still connected to the
power source.
2.. Press the Scan and Email buttons at the same time, while
plugging the power cable back into the scanner. The scanner will
enter a Demo Mode.
3.. Press the Cancel button on the scanner to start the test.
4.. To end the test, disconnect and reconnect the power cable
without holding the buttons down.
I've had exactly the same problem with my scanjet 5400c (blue distorted images) but after resetting the scanner (see instuctions posted above) the problem was fixed
Dec 18, 2008 | HP Scanjet 5400c Flatbed Scanner
BenQ Scan to Web 4300U Flatbed Scanner Logo
677 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
