Question about Samsung Televison & Video
Hi i have a samsung 61 inch rear projection tv SP-61J5HF When TV is switched into the power an orange standy light turns on and after a few seconds this light turns off and a quiet clicking noise ocurs. TV screen still doesn't turn on. what can it be?
  • harrouk_refr Sep 25, 2009
    hi is it a costly problem?
    thaNKS
  • 404 Answers
Hi Harrouk_refr! That kind of behavior is a power supply problem, there is a possibility that there is a problem with the power ic of your samsung projection tv. The tv is not getting the right voltage in order to poerr up the tv system. pls call the samsung tech support for repair or replacement if the tv is still under warranty, if not pls bring it to the nearest service center..
Posted on Sep 25, 2009
  • Dennis Kierulf Ordinante
    Hi Harrouk_refr! I don't think so, Its only a power ic chip. if the problem is from the projection system thats possible. It will be expensive for a repair but not that much.. I suggest, if possible you could bring it to the nearest service center for diagnose and estimate and they will give you an estimate cost for the issue..
What is the problem of samsung sp-46l6hv if i turn on the tv after a few second it is a automatic off and the display the button 3 lights is time lamp and standby mode is blinking when i can turn on t
Sounds like lamp inverter board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Oct 03, 2014 | Samsung Rear projection TV Lamp for...
56 inch rear projector Samsung tv keeps switching on and off continuously help!!!
Know how to solders?Take the tv aparts.Check the power board for those Capacitors puff up or burst open.Replaced these capacitors,well get ur power back.Or buy a whole refurbish power board at Shopjimmy.com,Ebay.com for replscement.
Jan 22, 2010 | Samsung SP 56 K 3 HV 56" Projection...
Power switch doesnt work. It blinks for a few seconds then turns power button goes off all together. Tv wont turn on at all.
Hi jenna;
We need a little more info like Brand, Model # and how many times the light blinks.
Good luck
Buck
Nov 14, 2009 | RCA D61W20 61" Rear Projection Television
Samsung projection tv
change lamp change fans
and replace color wheel.
make shure to remove jumper when replacing samsung color weel.
the jumper is black on the back panel of dmv modual.
jumper needs to be removed due to the new air cor motors thay are yousing, i had this same situation at one time.
Dec 16, 2008 | Samsung HLP6163W 61" Rear Projection...
Toshiba Rear Projection TV Problem
common problems on toshiba are the stk ic and it is not ease to replace them you will need a technician
Sep 15, 2008 | Toshiba TZ50V51 50" Rear Projection...
BLINKING POWER LIGHT AND TV DOES NOT POWER ON
I have a toshiba 61 inch projection tv the power light flashes with no picture any easy fixes?
Jun 24, 2008 | Toshiba TP61G90 61" Rear Projection...
Televison & Video Logo
Henry  Thomas
Henry Thomas
