Question about Canon iR 2016i Black and White Copier
Canon 1r 2016 toner out indicator even after puting fresh toner,replaced dp unit still same problem
    Habit-Forming:
  • 71 Answers
Try to change the drum. (drum unit yield 50k)
can you tell me the total page number?
Posted on Sep 26, 2009
How do install toner IR 400 canon
Open machines front door,
pull down developer-units (DP),(toner cartage) handle,
remove DP fill New toner ....
simple
Mar 09, 2015 | Canon imageRUNNER 400S Copier
What is the problem when my canon ir-2016 says out of tonner
magnet roller poor contact on roller bush connector... other wise roller blade ya roller stick clean properly Nd cheek board connector.. otherwise the magnet roller is damaged... clean the full toner unit...
Aug 01, 2014 | Canon iR 2016i Black and White Copier
Canon ir2016 show
PROBLEM WITH CANON 1R 2016 PHOTOCOPIER
SHOWING ADJUSTING WAITING FOR SCAN
PLEASE HELP ME HOW TO FIX THIS
Mar 22, 2012 | Canon iR 2016i Black and White Copier
What's your problem?my problem is canon np4050 machin err cod (e020)
just clean the hopper and dp unit then refill the toner ,or remove the dp connector (do not connect it)but after that the hopper dose not work and refill toner directly into dp
Oct 11, 2011 | Canon NP 6050 Copier
E019 in canon copier 2016 j.the machine runs n at last error comes E019, may be toner censer has problem how can i solve this.where would be the censer pls help me .
You need to replace the drum unit. The E019 error code means that the Waste Toner is full, but the problem with this model is that the waste toner cartidge is built in the drum unit so you have to replace the whole drum unit.
Nov 11, 2010 | Canon iR 2016i Black and White Copier
DP thoroughly cleaned. Fresh toner inserted, still showing out of toner, change toner.*28* pressed and Clear all. Still problem persists.
May be toner not supply.If you fix this problem you try to clean toner supply gear or brush.some times it very jam than can not toner supply.
Oct 07, 2010 | Canon iR 2016i Black and White Copier
Services manual canon 4050 copier keep getting e020
E020 is a toner code,
just clean the hopper & DP with blower.
then install the toner.
Your code is gone now.
Apr 28, 2009 | Canon MF8180C Color Laser MFC Printer
Canon ir 2016 problem E019
Product : imageRUNNER 2200/2800/3300(i)/2220N(i)/3320N(i) Title : E019
Error :
E019-0000 is displayed on the control panel.
Workaround :
This error code is the indication of the waste toner container being full or a problem with the detection mechanism. Actions to be taken are:1. Turn the machine off and check the waste toner container. If the container is full, empty the container. Clean the inside and outside of the container's neck with alcohol. Be sure that the neck is clear and not soiled with toner before placing it back into the machine. Turn the machine on and check to see if the code went away.
2. If the container isempty and the code is still displayed, check the neck of the container. Turn the machine off and check the container,if the neck is dirty, clean the inside and outside with alcohol before placing it back into the machine. Turn the machine on and check to see if the code went away.
3. If the machine still displays the code after the bottle is emptied and the neck clean; check the sensor, the sensor connections to and from the DC controller PCB for continuity, and the proper positioning of the sensor. Replace the sensor if it is damaged or excessively soiled with toner.
Apr 26, 2009 | Canon imageRUNNER 2000 Copier
Canon iR 2016 copier problem E019
Error :
Workaround :
Apr 25, 2009 | Canon iR 2016i Black and White Copier
Imagerunner 2016, waste toner full error message
hey, wel if the copier is showing a message saying that the waste toner is full it means the waste toner deposit is attached to the drum unit.
so, open up the frotn cover, pull down the (drum)-lock lever, it should release the left cover, then pull towards you the drum unit, and there you go.
the black case with a small trasparent cap is the waste toner deposit.
you have two ways to go.
1 you may remove that rounded transparent plastic cap and be able to vaccum the waste toner (dont even try reusing that toner, it wont work ok) or
2 you can go the other way wich allows you to easily vaccum it: remove the drum (the roller itself) then the charger roller, then the cleaning blade and there yo go again, but now you got more space to vaccum and believe me it is easier this way.
an additional choice would be to buy a new drum unit gpr18 i think (check please) and forget all about vaccum-ing.
Jan 23, 2009 | Canon imageRUNNER 2016 All-In-One Laser...
Canon iR 2016i Black and White Copier Logo
243 people viewed this question
old marine
old marine
