Question about Sony Cyber-Shot DSC-F828 Digital Camera
Cyber shot f828
Flash stopped responding under any setting
SOURCE: Cyber-shot DSC-W80
The camera is probably is "Burst" mode where you hit the picture button and it contineously takes the picture. Hit menu and look to see if you have it set to burst mode if so take it off and it will work..I just found the answer on here :)
Posted on Dec 25, 2007
SOURCE: Sony Cyber-Shot DSC-F707 ...No flash.
Mine started to do that too. I charged the battery and then played with it taking the battery out and placing it back in and it just started to work again. Try placing it in manual mode as in shutter or appeture, rather that automatic and see if it makes a difference. These are things i played with before it started to work again.
Posted on Apr 16, 2008
SOURCE: Sony DSC-F828 Faulty Flash
Cost me 350 bucks to have same problem repaired at Sony. At the same time the hot shoe would not flash an external flash.
Posted on Aug 18, 2008
SOURCE: sony cyber shot DSC-H3 flash
The same problem just appeared to us. We decided that it is a software bug and we reset the camera with the following combination:
Home ->Settings(the toolbox) -> Main Settings 1 -> Initialize.
This fixed the problem.
Have in mind that all your settings will be lost (but not the pictures).
Posted on Sep 19, 2008
marked
  • 6487 Answers
SOURCE: Where can I download Sony Cyber-Shot DSC-F828 manual?
You can get the user manual from this link http://www.retrevo.com/support/Sony-DSC-F828-Digital-Cameras-manual/id/200ag902/t/2/
Don't forget to rate the solution FIXYA thank you......
Posted on Oct 23, 2008
The flash on my Sony dsc f828 does not work
Hi, mine was doing the same, no flash, after I dropped. I reset it with the little hole next to where the memory goes and it worked!
good luck!
Mar 27, 2012 | Sony Cyber-Shot DSC-F828 Digital Camera
Sony Cyber-Shot DSC-F828 Digital Camera won't flash
Make sure Flash Shoe option is Off in setup menu then check flash light.
Does camera give any blinking error code when flash fails to fire?
Does flash pop up when you press shutter button to take picture in low light?
Let me know to find out possible cause of problem.
Oct 13, 2010 | Sony Cyber-Shot DSC-F828 Digital Camera
Sony F828 flash is not openening
There dirt or particle is sticking the cover flash, try to cleaned around the cover.
May 09, 2010 | Sony Cyber-Shot DSC-F828 Digital Camera
My Sony Cyber-Shot DSC-F828 Digital Camera has pink pics
CCD FAILURE
Call Sony they will do it FREE it is a known manufac fault dont worry just call them and ask them about BAD CCD
Pls rate me WELL
Aug 10, 2009 | Sony Cyber-Shot DSC-F828 Digital Camera
Try resetting the camera. It is next to the battery release. I had a similar issue and posted help. No remedey. So, after praying about this issue, I was lead to power it down and eliminate all the power by taking out the battery push the power button and many others. I found the reset button pushed it and it is all working now. The praying for a solution was key. Praise Jesus. DRD
Aug 08, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
Error
is there an error # behind it?
Jul 21, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
PROBLEM: F828 & external flash
I think this is due to the TLL preflash of the 828 internal flash. Each time it actually fires 2 flashes. First one for metering and second one for actual exposure. First "fake" flash probably trigers your external flash which is too early. Slution... hmm i think there are afordable slave adapters out there which detect the TTL preflash, ignore it and fire the external flash on the right timing along with the main flash. cost.. about few tens $ i think. they can detect also infrared light so you can mount IR filter on your internal flash to prevent interfering with the exposure...
Sep 12, 2005 | Sony Cyber-Shot DSC-F828 Digital Camera
F828 32x Flash conx probs
Do you have the camera set for flash? If it were set for no flash (diagonal bar thru lighting bolt) the F32X and the camera do not communicate.
F828 Is there a remote control available?
Yes... I don't remember the code I think is HC-VC1 or something like that, go to http://bhphotovideo.com and look for F828 accesories. It is around 35 USD and it is, after the flash, the best gadget for the camera I had found.
Sony Cyber-Shot DSC-F828 Digital Camera Logo
19 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
