Question about Nokia 5800 XpressMusic Smartphone
Cant update ota nokia 5800 need server profile for t moblie nokia 5800 rm428 nokia software updater has only v21 and v31 is out but i cant get it plz help me Thanks
This is up to your network operator. Your Nokia 5800 has a firmware version and product code that will indicate its a T Mobile phone
Once they have approved v31 then that upgrade will be available to you.
You can try to hack and change the product code - but that invalidates any warranties etc etc
Posted on Sep 25, 2009
Testimonial: "thank you"
I REQUIRE LATEST SOFTWARE UPGRADE NOKIA 5800
The latest software version of Nokia 5800 is version 60.0.003.You can do it via OTA (over the air) thru GPRS (mobile service providder's internet gateway) or via wi-fi connection or even via PC suite.
OTA via GPRS:
1. type *#0000#2. the current software version will be flashed on your phone's screen3. select option4. select check for updates5. it will ask you to connect via your mobile service provider's connection.5. select yes6. it will give you the current available updates for your phone7. if it's available for your phone, it will be displayed for the latest version for the version 60.0.003's availability varies per region.8. once available, select update then it will be automatically downloaded to your phone then once done phone restarting, you will have the version 60.0.003, you good to go...
VIA Wifi:
1. type *#0000#2. the current software version will be flashed on your phone's screen3. select option4. select check for updates5. it will ask you to connect via your wi-fi home network connection5. select yes6. it will give you the current available updates for your phone7. if it's available for your phone, it will be displayed for the latest version for the version 60.0.003's availability varies per region.8. once available, select update then it will be automatically downloaded to your phone then once done phone restarting, you will have the version 60.0.003, you good to go...
VIA PC SUITE:
Go to this address and follow instructions (make sure that you have available USB cable for your phone for you will need to connect to your pc to do this):
www.ovi.com/softwareupdate
thanks for choosing fixya.com
Dec 17, 2011 | Nokia 5800 XpressMusic Smartphone
Tip
REMOVE UNWANTED WORDS FROM PREDICTIVE TEXT Using this trick you can remove...
Using this trick you can remove sometimes irritating and unwanted words from predictive text. Open xplore or a similar file manager, go to c:\predic\ directory and delete the .dat file or edit it by transfering it to pc, opening it with notepad and editing.
NOW SEE THEME ICONS N95
In the new firmware on N95 v20 & v21 & also N95 8GB Nokia has removed the theme icons in the menu, but by using this trick, you will be able to see the theme icons.
To do this go to Menu-> Tools Folder-> Utilities Folder-> Device Manager.
Here you will see your firmware version and device updated. press D-Pad right button and you'll see no server profiles defined. Press options and select New server profile, and name the server 'name', server id, host adress and user name 'Themes'. Choose your password and leave everything as it is. exit (if it says profile not saved because you didin't do some configurations, try changing connection type to bluetooth) and press Options and start configurations without connection. then go to Menu-> Applcations and you'll see the themes icon!
Credits to DoucheBag66.
on May 09, 2010 | Cell Phones
When i switch on my nokia 5800 its shows system error message then switches off
try to update its with latest firmware you can download nokia software updater software from nokia website www.nokia.com
Oct 09, 2010 | Nokia 5800 XpressMusic Smartphone
Nokia 5800 express music
Hello Bro this is the software problem update it. Upadation may solve this problem for update ur phone software go to setting /phone management/software upadate or you can also update it from nokia.com from PC or any service center of nokia also provide this for free if in warrenty ok??
Hope this will solve ur problem...
Jul 07, 2010 | Nokia 5800 XpressMusic Smartphone
Cant create profile
hi, try resetting it again if it doesn't work updating the firmwire will repair it through the nokia software updater
Jun 21, 2010 | Nokia 5800 XpressMusic Smartphone
Nokia 5800 v 40 firmware bugs
download nokia pc suite and then nokia software updator that prob will fix it
May 03, 2010 | Nokia 5800 XpressMusic Smartphone
Software update has changed my lock code
The update may have reset the lock code to its default code. The default lock code for Nokia phones 12345.
Nov 25, 2009 | Nokia 5800 XpressMusic Smartphone
Unable to use phone book contacts between Nokia 5800 and Parrot 3100
You need to check that both the 3100 and the 5800 are using the latest software. There were problems with the older software but they have been resolved.
On the 5800: Settings>Phone>Phone mgmt.>Device updates>Options>Check for updates (Assumes your 5800 has a working internet connection). Othewise use software updates from Nokia PCsuite.
For the 3100: Download the software update tool from www.parrot.com to a bluetooth enabled notebook. Run the update tool and just follow the instructions. If you don't have wireless internet on your notebook, run the update tool first while connected to the net to download the update files before taking the notebook into the car. The 3100 must be in software update mode before you connect the notebook via bluetooth. Settings>Advanced settings>Software Update>Activate.
I found that it took a couple of attempts to get the connection to work, but once it was made the update completed fine. The 3100 then resets itself and you need to pair the 5800 again. Once it's paired, the contacts will synchronise.
I did this about 30 minutes ago, so I know it works.
Good luck
Nov 08, 2009 | Parrot Hands-Free Car Kit with LCD Display...
I cannot get my nokia 5800 to upgrade to the latest firmware, it keep telling me that there is none available but there is. any short cut? when i try to ota through the phone, it just brings me to a...
The latest firmware is not available for ALL nokia 5800 phones. It depends on your Product code. By doing this Nokia can control which features make it to our handsets by request of mobile phone operators. Orange for example might not want the Nokia music store on the phones.
The generic product code for the UK is 0552438 (this generic code means it not assigned to a network and therefor will receive all the available updates without restrictions set by the networks)
to change your product code follow the link bellow
http://www.nottinghamjazz.co.uk/blog/?p=66
Sep 24, 2009 | Nokia 5800 XpressMusic Smartphone
Nokia 5800 backlight problems
On a computer install the nokia software updater which is included on the CD in the box. Perform a software update to the most recent version and this should solve the problem.
My phone had this problem (after having it for around 4 months). After performing the update the issue was resolved, hope this helps
Jun 03, 2009 | Nokia 5800 XpressMusic Smartphone
Nokia 5800 XpressMusic Smartphone Logo
246 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
