Question about Whirlpool RBS275PD Electric Single Oven
My oven switched itself off and the fuse wouldn't switch back up, an electrician came to ensure all the electrics were safe. However, about an hour later the oven made a loud banging noise and smoke came out from it, do I need a new oven?
  • 832 Answers
It seems that your oven is dead. Smoke came out of
your oven signifies that the heater plate got damage. However, you may have it checked, before buying one.
Posted on Sep 25, 2009
Testimonial: "Thanks for that, looks like I'll be buying a new oven!"
My oven lamp does not work multi meter tests no power. Bulb replaced does not solve problem
This possibly is a faulty switch. It could be a bad connection within the switch itself, or something in the wireing through to the bulb. Be safe minded when working in this area, 220 vlts will do more then curl your hair. If not sure of the problen, call an electrician.
Jun 12, 2017 | Ovens
Everything electric in my house goes off and I turn my oven on and my electric comes back on. What can I do to fix this problem?
are you saying that all day long you have no electricity? It's only when you run the oven that your house is energized?
Jan 05, 2016 | Ovens
Cannot switch off oven fan.
WARNING
Go back to the switchboard and turn the oven OFF, (Switch the fuse off at the switchboard)
Your Oven sounds like it has shorted out.
DO NOT TOUCH IT
It could be live, Electricity can cause serious injury and even death,
Get a Registered electrician to check this for you. DO NOT use it.
Looks like you might be ordering out for dinner tonight :-)
Take Care
Feb 09, 2014 | Ovens
I have a Simpson electric oven with stove top elements, and one of the burners will only cook at the highest level, I cant figure out how to change it, any suggestions?
You need to change the "Simmerstat", take the model number to your local electrical parts supplier/parts counter at your local stove retail shop that sells Simpson stoves and ask for one for that model, make sure you get the right one for the position as some control a single element and some control dual elements.
*** TURN OFF THE WALL SWITCH AND ENSURE NO POWER IS APPLIED TO THE STOVE BEFORE PROCEEDING ****
Remove the upper back panel of the stove. Swap wire for wire of the old simmerstat to the new one, remove the knob from the old Simmerstat, undo the nut securing the simmerstat in the oven control panel and discard, fit new one, secure, fit knob, fit back panel, turn on wall switch and test.
Some countrys/states require registered electricians perform this task on electrical appliances so you must ensure you can do this legally before you start and take the relevant safety precautions and don't electrocute yourself.
Apr 13, 2011 | Ovens
Hi.my beumatic b151 oven is cutting out my fuse on electic supply when i turn the switch to my oven on.
You sound like you have a short in the electrical system someplace. Be safe and have it checked out!
Mar 28, 2011 | Baumatic B151 Electric Single Oven
HotPoint model# RB787WC4WW : Clock is functioning, all lights are on, but the burners and oven won't function. Is there a fuse or relay on this model ,and if so where is it located. I've taken the...
your oven may be on a 3 phase connection that mean you have 3 supplies to it.
one phase may be running the clock and fan etc.
the other two maybe for the burnters .
check in your house fuse or trip switch box and ensure that all trips are on and or fuses are not blown. this is usually where your electic meter is located.
if this is the case switch the circuit back on, if the fuse goes again this may indicate a fault either in your home or with your oven. if so call in an expert to check.
warning. high voltage electricity is dangerous if unsure call out a qualifed electrician or speak to your electicity supplier for advice.
i hope this was useful
Dec 11, 2010 | Hotpoint Ovens
I tried to fix the wiring in an external light. Did the job, but with bad connections, put in bulb and switched on. Blew fuse and now the switch will not turn off and I am left with a live wire in front of...
Switch contacts fused together
In most external fittings there is a live coming from the switch a neutral going back to the lighting ring main and an earth wire for protection
You are not competant to be rewiring any house wiring , the statement about the earth wire proves that.
No earth is akin to jumping into a lake without a life preserver on
Get an electrician involved before you burn the house down
Dec 31, 2009 | Jenn-Air JJW7530DDS Electric Single Oven
Smeg oven problem
The pop would usually mean a busted fuse. Turn off the oven, disconnect completely from the power supply and then take it apart. See if you can find any toasted fuse or roasted wires. Also the reason for tripping the mains off is due to the fact that the oven is draining more power than it should. I would recommend a thorough inspection of the oven by an electrician..
Jun 18, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Whirlpool RBS275PD Electric Single Oven Logo
144 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
