Question about Moulinex DG6 Food Processor
Electric scheme i want to connect the wires
Motor will not start
Check your power cord and power supply, check the plug is clean and free from corrosion or dirt.
Plug another appliance into the same socket to check there is power at the socket.
Note: Electricity can cause serious injury even Death.
Isolate your power supply from the mains switchboard.
Switch off and Unplug your appliance from the wall socket before attempting any repairs.
If its still under warranty, take it back to the store or manufacturer for replacement.
Call a serviceman to test the appliance for you,
If not you could...
Check your fuse in the device, you will have to dismantle the appliance. Some of them have a fuse to protect the motor.
Get your Multimeter and do some tests...
Test the flexible cord connections
Electrical tests included, visual inspection, Earth continuity, Polarity and Insulation resistance.
Examining cord for Damage
Disconnect flexible cord from power supply.
Check cord along the whole length for obvious damage
1: Visual Inspection
A visual test is necessary before using test instruments to ensure that all specific safety requirements are meet.
Check the general condition and safety of the cord, plug, cord anchorage, terminations and of the appliance itself.
2: Earth Continuity.
The earthing system of an electrical installation must be installed in a manner that will allow circuit protection devices to operate if there is a fault between live parts (other than Neutral) and the mass of earth.
What to check: For class (one) 1 protectively earthed appliances only, test for very low resistance between exposed appliance metalwork and the earth pin of the plug. this resistance should be as low as possible and must not exceed 1 ohm. Note: the Exposed metal parts of a class 2 double-insulated appliance must not be earthed.
Equipment requirements:
A Multimeter (Digital or analogue) Set on a ohm scale or an insulation tester that also has a continuity scale.
A set of leads.
3: Polarity
Why is this test necessary:
An incorrect connection of phase and neutral conductors to fittings and appliances is extremely dangerous and has been the cause, either directly or indirectly of many shocks and fatalities.
What to check:
Polarity tests are carried out to ensure that every single-pole switch operates in the active conductor or the circuit in which it is connected.
A Multimeter (Digital or analogue) Set on the resistance scale when the SUPPLY is NOT connected.
or a voltage indicator set on a suitable voltage rating when the supply is not connected.
4: Insulation Resistance
Why this test is necessary:
All live conductors (including Neutrals) and live parts must be insulated to prevent - Electric shock hazards from inadvertent contact.
- Fire hazards and equipment damage from short circuits.
What to check:
Insulation resistance tests must be made between:
- Active conductors of a poly-phase circuit
- Active and Neutral
- Active and Earth
- Neutral and Earth
The insulation resistance between appropriate components shall be not less than 1 mega-ohm minimum
An insulation resistance tester which maintains an output of 500 volts when loaded with a 1 mega-ohm resistance.
A set of leads.
Different countries adhere to spicific Electrical (safety) Regulations and standards
This information is only intended to enlighten the novice, guide and remind someone already in the field of electrical installations.
DO NOT attempt any electrical repairs unless you have the appropriate background or training.
Feb 10, 2014 | Cuisinart DFP14 Food Processor
Black and decker fp2500 food processor won't turn on
Could be a defective switch or broken wire connection
Dec 24, 2013 | Cuisinart DLC-10S Pro Classic Food...
I need to know the connections for the switch on the Braun 4250 Food processor. Took it apart a while back and now cant remember the connections! HELP PLEASE
If it's just a single switch and two wires that go to it, it doesn't matter which way it goes. One is normally open not allowing electricity to pass, and when the switch closes it completes the circuit. NO/NC may be listed on the switch. If theres only two terminals, it doesn't matter which way the wires go.
Nov 22, 2013 | Braun Food Processors
How to connect wires to the switch
One wire is the neutral wire which attaches to all the White wires and the other is the Hot Wire in which the LINE IN from the plug goes to one side of the switch and the other goes to what ever you are connecting to I.E. a light bulb, a motor or anything like that.
Sep 22, 2013 | Food Processors
Can you tell me what to check on my food processor?
It sounds like the safety mechanism is fussy. It may be broken. Or, sometimes a connection within the unit itself might come loose. I've seen wires get so hot the solder melts and the wires detatch. The little tab that engages the safety mechanism might be chipped or broken off. If the outlet is working, the unit is getting power. The power is just not getting to the motor inside the device.
There could be an internal fuse that blew. If you unplug the device, set it up as if you are going to use it, activate the the device while holding an ohmmeter to the plug prongs, you should get a reading over 10 ohms.
If you get 0 ohms, there's and internal short circuit. If you get nothing--overload--infinite, it's a loose connection or a blown internal fuse.
Jul 27, 2012 | Bosch MCM5200 Food Processor
Kenwood FP460 food processor, can it be opened up to replace a damaged power cord? If so how?
Yes. First, unscrew all the screws from the bottom, then, gently, pull it out. Please note that you need to have basic electricity knowledge in order to properly disconnect and reconnect the power cord.
Jan 19, 2011 | Kenwood Food Processors
The micro switch has apparently burned out and I can't find another that will fit. Without it, the motor won't run. Any ideas? My husband even went to an electrical store and of course they don't have...
I just replaced the microswitch in mine with a Radio Shack (Source here in Canada) part, works great. I belive it was part number 2750016, or something close to that. Just take your old microswitch in and compare to find the right one. Two wires to solder, it bolted right up and is working again.
Nov 01, 2010 | As Seen On TV Magic Bullet Food Processor
Repaired cord is not working
make sure the plug is wired correctly .. the colors of wires depend on what country it came from .. in the US it would have a black, white and green wire ... the black wire would be connnected to the small flat prong (thats the AC hot wire) .. the white wire would be connected to the wide flat prong (thats AC return) and the green wire would go to the round grouund connection .. if these are not wired correctly then it may not work and could be dangerous .. have it checked by anyone that is familiar with electronics .. make sure the pup didnt chew another spot on the wire ... ..
Jul 02, 2010 | Cuisinart DLC-8S Pro Custom Food Processor
I plug it in, turn it on, the red light goes on but nothing happens. same thing when i hit pulse. Any ideas what could be wrong?
hello,
the problem is from the connection i.e power connection
that supply electrical force on your processor
this means that there have been a power fail on the propeller ,
what you need to do tofix up this problem is to unscrew the processor then trace the wire down to the propeller you will fine the disconnected wire from the propeller then fix back to the propeller unit but if there is no sign of disconnection from the connection then it means that the wire are weak ,
it will need to be replace with a better one which you can get in the store.please note before you can do this assignment you will have to put off all source of power supply to your processor
thank you.
Jun 13, 2010 | Cuisinart DLC-2014 PowerPrep Plus Food...
Moulinex DG6 Food Processor Logo
26 people viewed this question
Top Moulinex Food Processors Experts
Colin Stickland
Colin Stickland
Ross Keen
Are you a Moulinex Food Processor Expert? Answer questions, earn points and help others
