Question about Mitsubishi WS-55809 55" Rear Projection Television
Convergence problems I have been having repeated come and go problems with convergence.  What part do I need to replace on my 2001 unit?  Mitsubishi WS-55809 thanks, Kristen
If you know how to solider you can fix this yourself with no new parts.
The convergence chip is becoming desoldered from the board. If you check hometheaterspot.com's Mits forum they have very detailed info on how to fix this.
Posted on Dec 20, 2007
Projection TV Convergence problem
go to the Mitsubishi service center to solve your problem
Jun 20, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Three colors bleed on screen and shadows reduces to portion of top screen model mitsubishi 60'' 2001 how to fix
** Caution! Hazardous voltages inside. Technical experience required.
This is a convergence problem. You will need repairs done. likely will cost $200-$600 depending on parts, service call, labour, etc. The convergence ICs are not particularly hard to change but you need good solder skills.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi TV VS-55601S Convergence Problem
Convergence it dead.Must replaced convergence,know how to solders?Tries these websites for convergence kit.Tv repair World.com,or Tv Repair Kits.
Nov 17, 2009 | Mitsubishi VS-55601 55" Rear Projection...
My Mitsubishi vs-5061 isn't working properly. The red crosshair wont line up with the white ones going horizontally. The red is bowing. Causing most writting to have a double vision look. HELP!
Hi, this will occur when the convergence unit has failed . you will need to replace the convergence board in this unit in order to restore proper convergence functions. This is just below the optical assembly in the PCB main area next to the signal board and terminal block.
Jul 26, 2009 | Mitsubishi VS-50611 50" Rear Projection...
Convergence Problem
Unfortunately you will have to replace the convergence board in this unit. it has failed. this particular board regulates the alignment procedure that you are having issues with. replacing this board will fix this issue.
May 21, 2009 | Mitsubishi VS-5047 50" Rear Projection...
My Mitsubishi VS-50705 has an all over 3-D effect.
Yes it sounds to be convergence issue .
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
Convergence ICs
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Hope this helps .
Mar 03, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Convergence on kdp-65ws550
Good Day, s_d_duncan;
The board for this 2001 Model is no longer available. Now, if you can solder, you can repair yourself. The parts you will need are two STK 392-570 (HIC), convergence IC's, part number 270P150010.
If you can't replace yourself, please call an authorized service center to give an estimate....
Good Luck, big IRISH.
Aug 03, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi ws48511 convergence problem
Your model uses one convergence IC its a STK392-110 you need to replace that IC. You can get a replacement at the following link with free instalation instructions with pictures so you can do the repaair yourself. Here's the link.
http://servicemanuals.vstore.ca/
Jun 26, 2008 | Mitsubishi WS48511 48" Rear Projection...
Mitsubishi WT42413 Convergence Problem
I have a Mitsubishi rear project. TV. Model #42413. I have a problem with the convergence problem where I am seeing double???
May 25, 2008 | Mitsubishi WT-42413 42" Rear Projection...
Is this a calibration, convergence, or lens focusing issue?
Did you Change out the Ground Resistors,220 Ohm,3.3Ohm Even if they look Good Change Them
Jul 20, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
199 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
