SOURCE: my mouse won't work, even after I changed the battery. Cordless,
Normal
0
Turn the mouse over and find the small rest/connect button
on the bottom of the mouse and press it. This should connect the mouse to
the receiver and work properly. If not, try pressing the receiver button
and then press the button on the mouse. This should be done whenever you
change batteries or glitch. Hope this helps you. Bud
SOURCE: Logitech wireless usb mouse not working
How do I open the cordless logitech mouse to change the battery. I am about ready to throw it in the river with cement shoes!!!!!
SOURCE: Logitech wireless mouse and keyboard
Normal
0
Press the Receiver button (and the lights will start
flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT
button on the back of the board to connect the keyboard to the
receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button
on the back of the mouse to connect to the receiver. Then they
should work okay.
Hope this helps. Bud
SOURCE: flashing light
It depends on the mouse. Sometimes the red light flashes to signify the processing of a command. If it is continually flashing, then you may want to replace the battery.
3 Turn the mouse upside down to check the on/off switch. Be sure it is switched on.
