Question about Western Digital Passport 320GB External USB 2.0 Hard Drive
Hi, I have just bought a 320GB WD passport and i would like to know if there is any software out there which will let me back up the contents of my WD Passport to my mac at home. I plan on doing a lot of work on the move at different computers at saving it to the passport, so i would like a back up of my passport incase i lose it. any help would be great. Thanks
SOURCE: Hooking up the WD Passport to a USB enabled CD/DVD player possible?
The WD is on USB 2.0 - if it's reading the 2GB drive, could it be that the 320GB one is just too big to read...even though I hardly have much on it? Or maybe I just need to reformat the 320GB drive?
Posted on Mar 12, 2008
SOURCE: dropped a WD passport drive, now it won't load. HELP!
Unfortunately, these drives are not made to be dropped.
It sounds like it was damaged by the drop which could have rendered the read/write heads inoperable or mis-aligned.
Contact Western Digital for a warranty replacement.
Posted on Apr 29, 2008
SOURCE: 320GB WD passport essential works with XP os but not with vista
both of my vista machines worked perfectly... i am not using the software that came on the drive. as a mass storage device it works perfectly.
Posted on Feb 01, 2009
bob_computer
  • 3153 Answers
SOURCE: 250gb wd passport contents not visible in my computer
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
Posted on Nov 10, 2009
  • 109 Answers
SOURCE: How to format WD Passport 1TB to FAT32
Plug the drive into your PC.
Right Click on My Computer (or Computer in Vista/Windows 7) and select Manage.
Click on Disk Management.
Right Click the Volume in question and select Format. Select FAT32 in the options.
Posted on Dec 24, 2009
Passport essential, how do I recover the backed up files? I can't get them to open, don't know how.
If you used the WD software, I would recommend installing it on the destination computer if it's not already installed. Once the software is installed you will want to look for the retrieve tab. You normally have an option to retrieve all data to original directores, or you can manually select/choose the data you would like to recover.
Mar 11, 2011 | Western Digital Passport® WDXMS3200TN...
How to remove the wd smartware software on the passport essential
Open "Windows Explorer".
Select the 'WD SmartWare' folder.
Press DELETE to delete the folder, and its contents.
May 18, 2010 | Western Digital Passport 320GB External...
Can only see one WD Passport 320GB drive at a time.
This is most likely a classic case of them trying to occupy the same drive letter. If you open disk management Start > Run > type 'diskmgmt.msc' and you should see them both there - One with a drive letter and one without, simply right click on the drive which doesn't have a drive letter and select 'change drive letters and path...'. Change the drive letter to something you know doesn't really get used and they should both appear in my computer.
Hope this solves your problem.
Jan 12, 2010 | Western Digital Passport 320GB External...
I accidentally droppped my brand new 320gb WD Passport now it isn't working it lights up & it has a tick sound then stops spinning...pls help.. :(
Most likely you have damaged the actual harddrive, the ticking sound is NOT A GOOD HARDDRIVE SOUND! Contact western digital and tell them that your NEW harddrive is making this sound out of the box DO NOT MENTION DROPPING IT. They should RMA it as long as you really did just buy it.
Oct 04, 2009 | Western Digital Passport 320GB External...
Cannot sync from Western Digital Passport 320gb HD
try and format using your vista or xp tools,right click on the hard drive go to format and format it as a ntfs drive.
May 28, 2009 | Western Digital 500GB My Book Pro-External...
WD passport 320GB Can I use it as storage, not backup?
You can use it as storage if you would like. You can also delete files once they are put on the passport. When it is connected to the computer open my computer and it will be listed there. You can use it as storage by copying files into this way rather than syncing it. Syncing it could cause you to lose files.
Apr 29, 2009 | Western Digital Passport 320GB External...
Jan 29, 2009 | Western Digital Passport WDXML800UE...
WESTERN DIGITAL 320GB PASSPORT USB PORTABLE
Doh
After posting the above, I found the answer on another forum about 10 minutes later. The WD drive is formated in FAT 32. My XP PC HDDs are formated in NTFS. FAT 32 has a 4Gb file size limit.
Answer. Format the WD drive in NTFS. It takes about 10 sec to do a quick format, but of course you lose all the content. Then You can copy anything you like to it. I have just copied a 33Gb video to the disc.
May 09, 2008 | Electronics - Others
hmmm...it may just be a capacity and interface issue, with the flash drive being more 'accessible' through the USB interface than the wd passport.
Big issue..is the WD on USB 2.0, and the CD/DVD on USB 1.0?
Mar 10, 2008 | Western Digital Passport WDXML800UE...
Western Digital Passport 320GB External USB 2.0 Hard Drive Logo
29 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
