Question about Garden
I need to know how to change the trimmer line on a weedeater RT112C
  • 8,197 Answers
REPLACING THE LINE
1. Disconnect the unit from the power
source.
2. Remove the spool by firmly pulling on the
tap button.
3. Clean entire surface of hub and spool.
4. Replace with a pre-wound spool or cut a
length of 30 feet of 0.065′ (1.65 mm) diameter
WEED EATER brand line. Use of
heavier lines could overload and damage
unit.
Also here is the manual if you need it.
http://dl.owneriq.net/5/56bed657-13ad-4194-85f3-2c4890bcfd6d.pdf
Good luck
Posted on Sep 25, 2009
I borrowed a stihl gas weedeater- does is have to have a trimmer line- it not cutting. I got line but dont' know how to put it in??
Yes it needs line. Take the trimmer and line to the owner and have them them show you how to load and advance the line.
May 14, 2017 | Stihl Garden
How do I take apart craftman 25cc gas weedeater to replace the string?
Same problem here......need to replace the trimmer string......some of you guys and probably some ladies know this...Ple Don't know which way to turn the head to get it off, or if I also need a tool to remove it. Please help!
Aug 21, 2011 | Craftsman 25cc Gas Line Trimmer
I just put new fuel line on my trimmer now i cant start it not getting fuel the line never fills with fuel but i can **** fuel out so i know it not pinched it a weedeater brand ght-17
Make sure the little valve under the tank if you have one is fully turned clockwise. Make sure there is nothing clogging the tiny screen inside the fuel tank. Check or test your primer bulb it may be leaky. If carb or intake is leaking, you won't get gas either. If you have a filter on this model, try changing it.
Sep 10, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
I need to replace fuel line in Weedeater trimmer. How can I do it ?
Enter Weed Eater fuel lines in the search field for numerous results and if not, repost here.
Aug 07, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Replaced Poulan 25cc weedeater fuel lines/Now no start
You have/had a fuel filter in the tank.The connector goes to that filter, I think. The length does mean something but I don't know any way to figure it without a manual. You could try to figure from the total length. The fuel filter hold the line toward the bottom. Good luck.
Jul 11, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Weedeater won't starter
I need to replace the gas filter in a featherlite weedeater 18cc. it rotted off and I dont know what line it goes on? is the other gas line a return gas line?
Jun 22, 2009 | Craftsman 25cc Gas Line Trimmer
Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Jun 21, 2009 | Garden
Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
May 07, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
How do you thread a Ryobi 725R Weedeater
If you still have problems withe line spool,try changing it to this after market head,I changed mine and it works great!
http://www.lowes.com/lowes/lkn?action=productDetail&productId=120473-42694-14548&lpage=none&cm_mmc=search_yssp-_-Unassigned-_-060209-_-Shakespeare%20Universal%20Fixed%20Line%20Trimmer%20Head
Apr 06, 2009 | Garden
Garden Logo
251 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
