Question about Canon imageRUNNER 3300 All-In-One Laser Printer
E002 and E003 comes in my 3300 and some times E007 coming what is the problem
  • 23 Answers
These codes indicate problems with the fuser. You may have to have it replaced.
These codes will only reset from the service mode.
Posted on Sep 25, 2009
I REALLY NEED SOMEBODY TO TELL ME WHATS AN E000 IS
You need to formulate your post into a sentence that makes some sort of sense instead of a cryptic error code. You know something like
"I have a Canon MG7120 al in one printer. I was printing, it stopped printing and the display shows E000. Can you tell me what the error is and how to fix it please"?
WHAT DOES SYSTEM ERROR E000 MEAN? - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting
  1. Cached
The error is a system fault error that can sometimes be reset: Follow these steps to reset the error: Press Additional Functions key. Press # Press > to #7 Printer Function Press Set Press > to #4 Printer Reset Press Set Press < Unplug printer and repower it. Ask Your Own Printers Question ...
I have an MF4350d. It is showing SYSTEM ERROR E000. What does ...
  1. Cached
I have an MF4350d. It is showing SYSTEM ERROR E000. What does that mean and what do I need to do? Thanks! - Answered by a verified Technician.
Technology Time: Canon Error E000, E001,E002, E003, E007
www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
  1. Cached
  2. Similar
I described in a previous post that E000, E001, E002, E003 and E007 are fixing unit temperature error codes. Lets go into more detail now. .... I have A problem canon 2002 when i power on the machine then show error E002-0000 pls advice me what i do ? ReplyDelete · Lizpeth G. ... What's prize of cannon copier E354?
Mar 08, 2018 | Office Equipment & Supplies
How to reset canon ir 2204 error e000-0000
https://www.youtube.com/watch?v=xm6oU-h7mYc
or
Canon imageRUNNER 2200, 2800 Reset Fuser Error Code Want to know how to clear the E000, E001, E002, E003, E007 messages on your Canon imageRUNNER 2200, 2800 series machines. Below is the instructions to for the 2200, 2800 reset fuser error code procedure.
For safety reasons lots of copiers and printers turn off AC power to the fusing unit when temperature errors occur. This allows for a service technician to come in and evaluate the machine before it is turned back on. The fuser heats up to to 350 and 425 decrees. Due to the nature of the high heat is why these parts are shut off. No manufacture wants to be blamed for their machine burning down a company. It sounds scarier than what it is. These machines have multiple safety features to keep this from happening. The reset feature is just one safety feature found in the machine
The E000, E001, E002, E003, E007 are all related to high or low temperature readings and the 7 is due to fixing film rotation issue. Below is the procedure to reset these errors. Occasionally, the fuser will run too hot or cool. Sometimes, this is a freak occurrence like when the power flickers on and off or just a faulty reading. Whatever the case, the first thing a tech usually tries is to reset the error and see what happens.
1. If the machine turns back on and starts making copies then you inspect the fuser for possible problems and wear and tear. If it checks out then you let it go and see if it comes back.
2. If the error comes back right away then you know you have a more serious problem and it's time to find out what needs cleaned or replaced.
Service Mode Entry
1. Press the User Mode key. (Looks like a little man head. Some people call it the function or additional function key.)
2. Press 2 and 8 on the keypad at the same time.
3. Press the User Mode key on the control panel.
If done correctly the display will read
COPIER
FEEDER
SORTER
FAX
BOARD
Press the Copier Icon
Press the Function Icon
Press the Clear Icon
Press the Err Icon
To exit service mode : Press the Reset key twice to end service mode and return to the User screen
Mar 19, 2017 | Canon Office Equipment & Supplies
E002-0000 on canon ir2202
Reset
COPIER
FEEDER
SORTER
FAX
BOARD
Press the Err Icon
Nov 07, 2016 | Canon Office Equipment & Supplies
How can repair an error of canon 2202 E000-0000 error code?
The E000, E001, E002, E003 and E007 are temperature error codes. Fixing these errors are necessory part of every
photocopier and printer. It is usefull to apply high temp and pressure to melt toner into the fibers. follow these steps
to reset E000, E001, E003 and E007.
Enter into service mode by clicking on key "2" and "8" the SSSW will display
Change bit switch 1 to bit 0
Press OK
http://canonprintersupport.us/
Sep 05, 2016 | Canon Office Equipment & Supplies
How do i solve an error e000-0000 canon ir 2202 please
Dear
Its related to the fixing temp. do the error clear on service mode. then check the fixing film assy. heater circuit contact points for corrosion. Replace it.
Thanks.
Dec 12, 2014 | Canon Office Equipment & Supplies
How to resolve e00002-0000
E002
The main thermistor (TH1) has poor contact or an open circuit. The thermal
switch has an open circuit (TP1). The fixing heater has an open circuit. The
AC driver PCB is faulty. The DC controller PCB is faulty. The door switch
is faulty.
E002
0000 The temperature of the fixing film is as follows:
1. has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
2. has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
3. has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
Main cause: The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact,
or the fixing heater is faulty). The main power supply PCB is faulty.
Caution: To clear the error, execute the following in service mode:
COPIER>FUNCTION>FCLEAR>ERR.
Action See the description for E003.
E003
Action
1. State
Turn on the power switch, and clear E002/E003. Thereafter, turn off and
then on the power switch. Does the fixing heater operate?
NO: See "The fixing heater fails to operate."
2. Wiring
Is the wiring from the DC controller PCB to the fixing film unit normal?
NO: Correct the wiring.
3. Fixing film unit, DC controller PCB
Try replacing the fixing film unit. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Feb 12, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
E000007-0000 error in diplay
The Canon imageRUNNER 3300 System error e007 code means that the fusing film is out of Home Position or the film is ripped. You will need to most likely have the fixing film replaced. You are probably going to have to get a service to repair it.
fixya.com/support/t6195187-cannon_ir2018_system_error_e007
November 7, 2002 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
E007 code is occurring for the IR 2200 / 2800 / 3300
Solution :
In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000). Canon USA, Inc. Systems & Technical Support Division
you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS...
Nov 02, 2010 | Office Equipment & Supplies
Code error of Cannon IR3300 E000006-0000
getfile.asp?rid=1258 November 7, 2002 getfile.asp?rid=3215 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
Solution :
Apr 29, 2009 | Office Equipment & Supplies
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
131 people viewed this question
old marine
old marine
