Question about Samsung WF203ANW Front Load Washer
My washer (samsung WF203AMW)does not drain. what should I do?
My washer does not drain. what should I do?
  • 1,531 Answers
There may be something stuck in the drain pump.you need to remove the hoses from the drain pump and look in there and see what is stopping the pump.
Posted on Sep 26, 2009
  • seth adams Sep 27, 2009
    you can use a shop vac and attach it to the end of the drain hose remove all the water then check the drain pump.there maybe something stuck inside the pump.
Samsung vrt front load washer WF218ANB/XA Burned up the drain pump. Installed a new one, now washer will work until the spin cycle. In spin cycle the door lock clicks and it will not drain or spin
Make sure the drain filter is not clogged. Most Samsung have an access door in the lower right hand corner to access and clean out this filter. If this is clogged or the drain hose is clogged, you will have these spin and drain problems.
Nov 10, 2016 | Samsung Washing Machines
Where is the drain filter in a Samsung top-load washer WA400P ??
There is no drain filter on the top load washer. Many of the front load washers have the lint filters.
Oct 21, 2016 | Samsung Washing Machines
Samsung washer wont drain
  • Check drainage pump filter for debris
  • Check drain hose and waste connection for kinks and blockage
Select a spin cycle to drain remaining water. If problem remains, service may be necessary.
Aug 04, 2016 | Samsung Platinum Front Load Washer -...
Samsung vrt nd or nb error code
ND is not draining, the washer probably has water in it and won't open. In which case you need to open the little tiny panel on the front of the washer and pull out the little hose and drain the washer and then clean our the filter next to the hose. NB means not balanced and the clothes have become unbalanced, move the clothes around and start it back up. If it happens a lot the washer is not on even ground and needs to be leveled.
Feb 18, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
Why does it not drain?
It "should drain automatically. If yours does not, please make sure the washer is properly leveled both front to back and side to side, make sure the drain hose is not inserted too far into the drain pipe and that there are no bends or kinks in the drain hose that might cause a blockage. Samsung also recommends cleaning the debris filter on a regular basis (at least once per month). To avoid spillage when cleaning the debris filter, it's important to first empty the rubber drain tube located next to the debris filter into a container. For more information, please refer to the User Manual."
Source: http://answers.us.samsung.com/answers/7463/product/WF330ANB_XAA/samsung-4-3-cu-ft-washer-questions-answers/questions.htm
You can download the "User Manual" and "Troubleshooting Guide" from here:
http://www.samsung.com/us/support/owners/product/WA5471ABW/XAA
I hope that helps you!
Jun 21, 2014 | Samsung WA5471AB 4.7 Cu. Ft. Top Load...
Samsung washer won't drain
pop out that door on bottom right. Get a salad bowl and 3 bath towels.Flip out that little drain hose and drain away/
Apr 04, 2014 | Samsung WF337AA Front Load Washer
Samsung WF209ANW front load washer -- ND error code. I cleaned debris filter and all hoses, however it still will not drain. How can I tell if the drain pump needs to be replaced? Is there a diagnostic...
Hello & Welcome to FixYa
ND error in your Samsung Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Sep 25, 2011 | Samsung WF328AA Front Load Washer
Kenmore 90 washer won't drain
ckd pump traps for debris on kenmore remove front panel on samsung i think a rear approach is best
Jun 03, 2008 | Samsung WF337AA Front Load Washer
Samsung WF203ANW Front Load Washer Logo
890 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
