Question about Kenwood Audio Players & Recorders
How many hour can i reord video on 350 gigabyte
    Sergeant:
    Novelist:
  • 183 Answers
Hello there timiss35.
Here's your GEEK-steer ...
There's no exact answer to your question. That's because it all depends on the quality of the video contained on the files in which you'll be adding the your 350 GB drive.
WHY: When you record [(re)encode] a video file, you can choose and adjust its quality based on what's known as "bitrate". In simple terms, this is the amount of bits (detail) added to every frame/second of the video. The higher (more) the bitrate, the better the quality. Also, the bitrate of the audio may be adjusted for quality, resulting in a variance of its portion of the file size.
EXAMPLE: You can achieve acceptable quality video at approx 775 kbps (Kilo-Bits Per Second) for video, and 128 kbps for audio. This is a fairly standard choice based on the fact that you fit a standard 120 minute movie onto a 700 MB CD disk (approx 6MB/minute).
CONCLUSION: Assuming every file was encoded at the aforementioned bitrate levels, you could fit approx 1,000 hours of video onto a 350GB storage device, .
TIP: Get yourself a bitrate/codec analyzing applet. It's an invaluable must-have little tool for every videophile. There are many freeware choices to choose from, but here's a couple I use often ...
Good luck, and thanks in advance for posting back ...
  • to let me (and others) know how things worked out.
  • if you have any further questions.
  • to provide clarification or feedback.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Craig
Posted on Sep 25, 2009
  • Craig The Geekinator
    Craig The Geekinator Sep 25, 2009
    @timiss35
    I just now see that you submitted your question in the "MP3 and Digital Media Players" section of FixYa.
    Therefore, I'll assume your 350 GB storage device is a portable player/PDA. If this is the case, my 775/128 combo example would still substantially apply. Why? A very common bitrate standard for small screen portables is 640/96. Therefore, as you can mathmatically figure, they are not so dramatically far apart.
    RECOMMENDATION:
    I also presume you're maybe fairly new to this territory. In which case I'll give you my recommendation for which video related software to help you with your video chores:
    That would be AVS. I've evaluated more apps than I could ever hope to count, and AVS is the best overall combination of capability, ease-of-use, reliability, and value. I do use several other apps, but AVS is the workhorse I use at least 80% of the time.
    But don't take my word only, it's agreed by TopTenReviews.com. There are many very good apps out there, but there are far many more that are CRAPware. I hope this advice can help you avoid getting stuck with the latter.
    Once again, good luck, and thanks in advance for posting back ...
How do I record on a TCL Model L32E330, using a USB stick
Use the timer record function in the tv guide or timer reord in menu on unit
Jun 02, 2014 | LG Tcl L40fhdf11ta Tv Part Main Board...
350 service
That's plenty of power. You only need more if you have a lot of hard drives or a really big graphics card.
Oct 27, 2013 | Gigabyte Computers & Internet
I have a problem with my Gigabyte GA-8TRS350MT motherboard. I started my PC up, but the monitor didn't switch on. Later that day, I tried again, and it worked! Then after about 1-2 hours, it switched off...
It sounds like a power supply problem not the mother board, you have some bad electrolytic caps in the power supply that need to be change, or just replace the power supply.
Mar 25, 2011 | Gigabyte GA-8TRS350MT Motherboard
What power supply do I need for the Gigabyte GA-MA790GPT-UD3H Motherboard. I will be using an UPS to keep power on for 10 minutes if the mains fails.
At an average PC with 17"CRT Monitor consumes 200-350 Watt. Allied peripherals and accessories etc. add to the overall power consumption. Hence, it is alway better to keep a buffer while estimating power consumption. So, It is recommended that UPS of atleast 500W may be used. (UPS of higher Power Output /Wattage would allow to keep up some other devices as well in case of power failure)
Also, CPU Power Supply (Internal) generally should be 350-450 watts.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 18, 2011 | Gigabyte GA-MA790GPT-UD3H Motherboard
I have gigabyte GA-G41M-ES2SL rev 1.1 motherboard with 2 GB RAM, 350 GB SATA HD, and SATA DVD-ROM. My PC die yesterday. i check it. there is no electricity to my pc, i think my Power supply (380W) was...
hey yo, i think your problem is quite similar to my problem. Because after I've installed it properly and after 5 hours working the screen suddenly become blank and not detect the connection. I think the mobo already broke down.. T_T
Dec 20, 2010 | Gigabyte GA-G41M-ES2L Motherboard
I have a DISH Network ViP722 DTV Receiver / 350-Hours Video.... Whenever I have my brightness setting below 40 on my LG TV, my Dish DVR will no longer respond to its Dish issued remote control. If I turn...
Hello! Daniel Busa with Dish Network. That would be a case of remote interference. You'll need a model 6.3 or 6.4 remote. You can set it to a uhf frequency instead of an ir that will correct the issue.
Aug 26, 2010 | DISH Network ViP722 DTV Receiver /...
Canon mv 600 not reording only sound
Looks like another case of damaged CCD. Once replaced the problem can be solved.
Apr 17, 2008 | Video Cameras
MOTHERBOARD GIGABYTE 915
Check your power supply - it could be providing too much current. There could also be a faulty VRM on the board, but there is nothing you can do about that.
A little thermal epoxy and ramsinks (video card ram modules sized heatsinks) might help.
Dec 05, 2007 | Gigabyte GA-8I945P-G Motherboard
99 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
