Question about Roxio Easy CD & DVD Burning
NO USB 2861 DEVICE DRIVER WITH SET UP DISK - Roxio Easy CD & DVD Burning
  • jnb85741 Sep 25, 2009
    I BOUGHT AND INSTALLED roxio easy VHS to DVD, I GET MESSAGE CAN'T FIND DRIVER FOR THE USB 2861 DEVICE. I HAVE WINDOWS VISTA HOME PREM. MY SOFTWARE INSTALL WIZARDS REQUWST INSTALL DISK, I INSERT DISK AND THEY CAN'T FIND THE DRIVER.
  • julie25sh May 11, 2010
    Don't know this driver but why would you need a USB device driver with this program? What are you trying to do?
2 Suggested Answers
  • 4 Answers
SOURCE: video choppy when capturing. Using video to
I will need more info on your PC setup to be able to help you.
Posted on Jul 22, 2010
Tip
How to install Windows Vista/7 using bootable USB storage device
How to install Windows Vista/7 using bootable USB storage device Requires:
- Windows Vista/7 DVD 0r installation source (setup backup files)
- A 4GB USB 2.0 Storage device (Its recommeded to use USB 2.0 device for optimal performance)
  • Plug your USB storage device.
  • Run CMD and execute the following commands one by one.
  • Diskpart
Run Disk parition utility
  • List disk
To get disk index that is used to pefrom disk paritioning.
  • Select disk 1
Selects disk to pefrom disk paritioning.
  • Clean
Flush your existing all USB drive's partitions.
  • Create parition primary
Creates a parition as primary parition.
  • Format recommeded
Format your USB drive w/ recommeded parameters. (No need to worry about file system format)
  • Active
Set the parition as active to hold bootmgr.
  • Exit
To quit Diskpart utlity
Now copy all Windows Vista/7 files to USB storage device... thats all.
  • Boot your PC w/ it, you can install Windows Vista/7 via bootable USB storage device.
Note: If you face any trouble to boot w/ it or unable to boot, try this
FIX.
I:\Boot\Bootsect.exe /NT60 I: Where I: is the drive letter of USB storage device
on Aug 29, 2010 | Computers & Internet
Tip
My USB 'Whatever' will not work
This not is not for USB flash drives, microphones, mice, anything that does NOT have an install disc at the time of purchase.
Most USB issues are caused by installing a USB device BEFORE you install the driver disk.
In all cases, if there is a driver disk, insert the disk first and wait for the install program to ask for the device. Then plug it in.
If you have done the faux pas above, all the installs in the world will not fix it. You MUST remove the USB driver. Use Device Manager. In XP, this is found by right clicking my computer and selecting properties. In properties select the hardware tab and choose 'Device Manager'.
Stop here. If you have no idea what I wrote, review 'Device Manager' on the Windows Website or ask a KNOWLEDGABLE friend for help. See http://support.microsoft.com/kb/310123.
Now, select the USB device, while it is plugged in to the USB port, and right click. Select 'Uninstall'. Remove your USB device when device manager is done.
Close Device manager and all the other windows. Start your USB install from scratch, without the USB plugged in untill the install asks or completes.
I have ALWAYS had succesfull installs with this method.
on Mar 20, 2010 | Computers & Internet
I have a Tevion High Speed DVD Maker. After installing the software for it (ShowBiz DVD2) it says to set the video to USB 2861 and the audio to USB EMP Audio Device. These choices are not available to...
Go to:
Start>Search
When the search comes up, on the bottom left, you'll see "Click here to use Search Companion"
Click that, and on the left side when it comes up, click "All files and folders."
For the search criteria, type in tsbyuv.dll and "Look in" should say "Local Hard Drives (C:)"
Click search and you should be able to find it.
If it doesn't find it, change the search criteria name from "tsbyuv.dll" to "*.dll" Without quotes of course, then do the search again....once it finds all the .dll files, you can just find it by looking for the name.
Right click and delete.
Hope that helps and don't forget to rate!
Dec 20, 2010 | Computers & Internet
Tip
My USB 'whatever' does not work
The disk driver will not auto run the set up disk
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jun 30, 2010 | GE MiniCam Pro HO98756 Webcam
How do you get the simpletech external hard drive to store information, and how do you know when it is stored?
Plugging in a USB device before installing the driver disk is the most common USB mistake people make.
An external hard drive, driver properly installed, looks just like a normal hard drive in 'My Computer'. Use it like a hard drive.
If you cannot see it in My Computer when it is plugged in (Go ahead, unplug it and reconnect while My Computer is open) then the driver is loaded wrong. A wrong driver needs to be removed with 'Device Manager', the USB drive DISCONNECTED, the driver reinstalled and the device plugged in at the end or when it is asked for by the installer, not windows (unless it does not have an install disk)
Poof, you can see the disk as a hard drive in My Computer.
See 'Device Manager' on the Internet for help with this.
Mar 20, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
I am running Vista and trying to istall easy vhs to dvd into my computor It has accepted all but says usb 2861 device has failed and to check with you to solve this problem Bruce e mail
If you are using more than one USB devices at a time - especially on the same USB physical port (through a hub, say), then there may be insufficient power for the device. If you unplug the device and plug it back in again (preferably on a physical port to itself), if the device is working ok, windows should pick it up and search/ask you for appropriate drivers or manufacturers disk.
Btw give the device at least 10 seconds after unplugging it before plugging it back in again.
Allan
Dec 09, 2009 | Roxio Easy VHS to DVD for PC
My laptop is ibm thinkpad 2861. my internet cannot run because my driver is no longer working
You need ti install the LAN driver again, If you have not got it then
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model computer, Use this link :-
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
Jun 18, 2009 | IBM Computers & Internet
Roxio Easy CD & DVD Burning Logo
877 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
