Question about Air Tools & Compressors
I have a Husky electric air compressor that will NOT build pressure, piston moves and motor runs but will not pressure up and there doesn't seem to be any leaks anywhere
I have the same problem, it built up to 80 psi, and no more. Let it run for 1/2 hour and it would not build any more. Also noticed it was sort of noisy, blew air out the back of the piston after pulling the cover off. Tore it apart, checked check valve, it was O.K., pulled head off and noticed seal around piston kinked. I do not see that I can just get the seal and so far, the piston is discontinued, it tells me I have to order a new pump for 255 bucks, if I can't find a seal or piston, I'll have to throw it away.
Posted on Aug 01, 2012
    President:
  • 1,167 Answers
Piston rings gone valves gone blown gasket i need more info buddy
Posted on Sep 25, 2009
Compressor won't build more than 50psi
Check all connections with leak detector or a soapy water mixture for any possible air leaks.
Mar 30, 2014 | Husky Electric Portable Air Compressor:...
The air pressure won't go above 40psi on my Husky Y1010. Read suggestions it might be a broken reed valve. How do I fix that?
Hi Joanne
Here are a few things to check, you may have already checked some of these.
Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
But it should not have air leaking out of it all of the time. If so then it is faulty and in need of repair/replacement.
Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
Gaskets...Check to see if your gaskets have failed.
You could have a gasket failure between the pistons and you will never know it because it shows no external air leak.
If this situation happens then the air will only cycle between cylinders and never build up the correct air pressure.
One way to check the gasket is remove the air filter, then put your hand over the intake.
If correct then it will suck you hand against the intake.
If the valve or valves have failed then you will feel the air sucking in and blowing out.
Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
A worn cylinder will also contribute to the problem of pressure build-up.
Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Bud
Oct 16, 2013 | Air Tools & Compressors
Having a problem with my husky air compressor model #vt6315 not building pressure...it is a belt driven unit & motor will run but belt is not moving to run compressor pump
Remove the belt and try to turn the pump pulley by hand. It should have a little resistance on compression strokes but otherwise turn fairly easily and smoothly. If you have to really lean on it or it won't turn at all you have bearing problems inside the pump. The most common proplem is after running the pump with low, old or no oil, the piston con-rod(s) seize to the crank shaft.
Nov 24, 2012 | Air Tools & Compressors
I have a husky scout 1.5 gallon air compressor. It only builds pressure to about 38 psi. It doesn't build up any more pressure.
You have either warped or broken reed valves on the valve plate or a broken piston ring and/or a damaged cylinder. Any of these will allow a small amount of air compression but as the tank gets pressure in it, it gets harder to push more air into it. If the reed valves or piston to cylinder seal is compromised more and more air will leak past the bad reed or the piston as the pressure goes up in the tank. You'll have to disassemble the air pump to find out what's damaged and needs replacing.
Mar 03, 2012 | Air Tools & Compressors
My coleman air compressor won't turn on and I am trying to ghet the top off to see what the problem is. A) How do I get the top off? and B) Why doesn't it turn on?
Hi
Sound like your pressure switch is faulty or maybe a faulty motor but:
If correct then it will **** you hand against the intake.
Please take time to rate me
Aug 28, 2011 | Coleman CL0551509H 15 Gallon Portable...
Husky 202900 when i turn it on motor runs but it but will not bui
when i turn it on motor runs but it will not build up air pressure
Apr 13, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Have a husky 19 gal 1.5hp it kicks on when first start to work and when it builds up air and i use it and when it wants to kick back on it wont i have to wait till it cools down.
Is there an option for you to run this compressor on 220 volts vs 110 volts??? If so, you may want to convert it by following the re-wire instructions on the motor or wire access plate/instuction book. The reason your compressor won't fire up again after building pressure is the head pressure is to great at restart and 110 household current is not enough to give the power needed to turn the piston. You'll need to replace the plug and have someone run a 220 volt circuit once the conversion is completed.
Jan 18, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have a Husky model Y6010 air compressor.
First remove the valve using probably about a 1/2" wrench but make sure there is no pressure in the tank before you do so. check the cone and seal by loosening the valve by hand and check for debris. If there is no debris then the problem is either the pressure relief valve or weak pressure regulator but may also be a bad piston seal if it is a direct drive unit.
Apr 28, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
200 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
