Question about Sony Cameras
My battery charger's orange light starts flashing after a while when charging batteries. What does this mean?
  • 374 Answers
SOURCE: Battery Charging Problem
First of all I would make sure that the battery is in correctly. There should be an arrow on the battery that should line up with a plus sign on the battery door. Once the battery is installed correctly then place the camera on the charger and the light should be a solid red. If that still doesn't work then I would be more inclined to think that you may have a defective charger. I would call Casio repairs and see what they can do to help you.
Posted on Jul 17, 2007
SOURCE: problem charging battery
it your batter light is blinking a red light then you should call up casio's technical service and they'll send you a new one:)
call 1-800-435-7732 for technical support! :)
Posted on Dec 31, 2008
SOURCE: Battery charger light flash
Its pretty simple to fix. The lithium battery has just depolarized. Just buy a 9V battery.... put them end to end... the 9V and the lithium and touch the metal parts of them. hold for 20 seconds... if it doesn't work, lick the 9V to conduct the electricity better.. hold for 20 seconds and put directly on the charger... I just did this, and it is charging as we speak! good luck!
Posted on Feb 18, 2009
zohail
  • 1223 Answers
SOURCE: When charging my camera the charger light flashes
battery issue try changing the batt they are not taking the charge pls replace if they got weaken or aged
pls rate me fixya if it helped
Posted on Mar 09, 2009
vortash
  • 431 Answers
SOURCE: My battery wont charge.
Hi I am Vortah The red light is usually an indicator that the battery is charged however in this instance as you are saying it isn't the battery has possibly gone short and you will need to replace the batteries . They have a type of internal memory and only charge a certain amount of times before they no longer accept charge and merely overheat during charging .. But I have to say it may be possible the charger is faulty as if the internal rectifier that charges the battery has gone short that may also bring the red light on in some chargers .. so try the battery or as I would do take it along to your nearest dealers and get them to check it . it may save you money in the long run you could be buying a battery you still cant use when you actually need a charger .. Hope this helps regards Vortash
Posted on May 29, 2009
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Lenovo g550 orange flash 3 times
3 orange flashes means flat battery. If you have a faulty charger or charger socket on the laptop then the battery wont charge or power up with just the charger connected.
Look here:Lenovo
Feb 01, 2012 | Lenovo G550 Notebook
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
Battery indicator flashing red when running on battery or on main supply and battery is 75% charged
When your battery indicator is flashing Red, it usually means that the charger is defective.
Dell also had a recall on some of its batteries. To see if you qualify for a free replacement click here: http://www.dellbatteryprogram.com/
If you want to reset your battery utility follow these steps:
1. Let the battery run completely dead. (Make sure all your work is saved)
2. Fully charge battery (You may still have flashing lights but if you turn your computer on and enter BIOS you can see the charge level)
3. Once again run battery dead.
4. Remove battery and wait 5-10 minutes.
5. Replace battery and use in normal operation.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Feb 03, 2010 | Dell Latitude D600 Notebook
Nikon MH-53 Lithium Battery Charger - help?
download the manual here
http://www.retrevo.com/s/Nikon-MH-53-review-manual/id/605ag014/t/1-2/
Jul 30, 2009 | Cameras
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Ds is plugged into charger. But when i try to
What is the orange charging light doing? If it is just flashing on, or only staying on or a minuet, that means you need a new battery. The orange light foes on when the battery has been charged to its maximum capacity. After each charge, the capacity is decreased. So if the orange light is on for only a short time, get a new battery.
Feb 28, 2009 | Nintendo DS Lite Console
MAKITA LXT BATTERY CHARGER
hey
flashing orange=cooling abnormality.
you need to wait for the battery to cool.
see my mod page, it has all light explanations in it.
Have fun
Avi
Jan 09, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Cameras Logo
156 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
