Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Rewind a recoil starter spring. I've spent many hours trying to get the recoil spring put back in its place with no luck.
    Sergeant:
  • 302 Answers
I DID THIS SAME JOB BY WINDING THE SPRING UP IN MY HAND AND THEN TOOK 2 TWIST TIES AND WRAPPED THEM AROUND THE SPRING TO KEEP IT IN THAT CONDITION. I THEN INSTALLED THE SPRING WITH THE LONG END OF THE TWIST TIE EXPOSED AND AFTER GETTING THE ROPE HOUSING IN PLACE I PULLED THE TEWIST TIES OFF WITH SOME NEEDLE NOSE PLIERS. HOPE THIS HELPS
Posted on Sep 26, 2009
Husky power washer 2600 Tried fixing starter
I'll send you a link to a great video of how to recoil a starter spring, so you wont lose and fingers or eyes. :)
Aug 01, 2013 | Garden
The starter cord jammed on recoiling, after attempting got release it the recoil spring rewound, now the cord and spring are interlocked. I'm looking to strip the recoil mechanism but I believe I
Its an easy opperation to undertake if you know how. Take note of where everything goes during the stripping down of the recoil assembly. Use eye protection when trying to recoil the rewind spring, they have a tendency to jump back out at you while coiling them back in. easiest way is to start by putting the hooked end into the plastic housing and work your way inwards coiling it back in. Then place the starter cord roller in on top, adding the one or two black sliders, the washer and the spring clip to hold it all in place.
Feb 16, 2013 | Stihl Trimmer Oe Rewind Starter Spring 36...
Fs44 whipper snipper recoil spring unwound, cord jammed and when tried to release recoil spring released
http://rapidlibrary.com/source.php?file=ulztcbvqczi89on&url=http%3A%2F%2Fwebweevil.co.uk%2FPublic%2FInfo%2FStihl%2520FS36%252C%2520FS40%252C%2520FS44%2520parts%2520list.pdf&sec=a0a080fc8669d51a
The link is for the breakdown manual and parts list
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    How do you re-install recoil spring
    Possible answer 1 (a very good description of tension adjustment is on the video in answer 2; about 1:20 into film):
    Recoil Spring Rewind
    I invert and secure the starter housing and rewind the spring large coil to small (need eye protection and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely rewound. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
    Possible answer 2:
    R² Starter Rope by SmallEng.com
    http://www.youtube.com/watch?v=eRyy3MlsjVo
    If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
    Lou
    Thank You for using FixYa.
    May 07, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
    How do you rewind the starter spring / cordand wheel back into the saw housing?
    wind the spring in your hand to a size that will fit back in the housing then fit it. then fit the pulley back making sure the spring fits in the slot for it.
    you should then botl the pulley back in place.
    to tention spring you shuld notice a notch in the pulley that is for the rope to sit in while you turn the pulley to re tention it
    Apr 03, 2010 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
    Starter recoil spring reload, How?
    If the spring is unwound.
    If the starter cord needs a pretension, this works quite well.
    If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
    Lou
    Mar 26, 2010 | Homelite Garden
    THE STARTER REWIND SPRING IS BROKEN
    you can not fix recoil spring all you can do is replace it.never said what the recoil is on so cann't help till you tell what it is on........
    Dec 25, 2008 | Garden
    Spring repacement
    Hi fwadden
    Remove the housing-fan. Remove the screw and detach the pulley- starter and the spring -starter.Put the new spring-starter(it usualy comes with a support).The spring-starter"spires are counterclockwise oriented.Put the puley starter back and the screw.Wrap up the rope clockwise on the pulley-starter until the starter works propperly.Hope this helps you.
    best regards savumihai71
    Dec 12, 2008 | Poulan Pro Chain Saw 46cc 20"
    Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
    1,592 people viewed this question
    Top Poulan Garden Experts
    Roland W VanLue
    Roland W VanLue
    Phil Walker
    Phil Walker
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
