Question about HP PhotoSmart 7260 InkJet Printer
When putting paper in paper tray, paper not loading
    Scholar:
  • 97 Answers
Could be many things. Try this first. Make sure you have your word processor set to load from the tray instead of from the top eeder.
Posted on Sep 25, 2009
Printer won't pick up paper to print or copy. paper is loaded put registers as 'out of paper, load paper face down in main tray'. this has all been done. What's wrong
If it's in the 1st paper tray, pull out the tray and check if theres a sensor. Check if it's out of position, if it is, place it back in position. If the printer still says 'load paper' the sensor is most likely faulty.
Dec 18, 2015 | HP Photosmart C6100 All-In-One Printer
Tip
PROBLEM - OUT OF PAPER
If many people are waiting for printouts, and nothing is actually being printed, the printer may be out of paper; the printer will indicate this on its display. To load paper into the N4525 printer, simply pull out the tray #1 or #2 located at the bottom of the printer in the front, and put the paper in the bin. Put the tray back into the printer. To load paper into the N24 printer, locate the tray in the front of the printer. <br />Pull the tray out, and locate the bin indicated by the large arrow in the lower left-hand corner. This is the side where you put the paper. Then, push tray 4 back in to the printer<br />.Make sure you put the paper on the correct side of the tray. This is the most common error. There are usually diagrams on the inside of the trays indicating how to put in the paper.
on Jan 06, 2011 | Office Equipment & Supplies
Paper is in paper tray, however copier says "load paper in tray
The paper is not loaded correctly, push it in there all the way to the back. Also put in a reasonable amount of paper, not to little or too much. Good luck!
Aug 27, 2012 | HP Photosmart C6180 All-In-One InkJet...
Paper in tray won't load
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Have a nice day and do not forget to rate please...!
Feb 15, 2010 | HP Photosmart C5180 All-In-One InkJet...
Dell 3000cn keep getting load mpf when i try to print but there is paper in the tray. how do I get it to recognize the paper. I've changed nothing on the computer but this just started to happen! please...
I have a Dell 3010n myself, and a few times I did run into that "Load MPF" issue.
1.) Before printing a document, please check and see the properties. i.e. Kind/type of paper, which tray, or if printing envelopes or any other document than a regular 8 x11 paper. Putting all the tray and paper type selection on "Auto" can be very helpful.
2.) On the printer itself, there is a menu button where you can configure the type of paper, i.e. regular 20 llb. copy/print paper, glossy photopaper, thicker paper - after you place a fresh load on the paper tray and slide it in, usually it will ask you which type of paper you just loaded. Make sure it is the same settings as the document that you are trying to print: i.e. if document settings on computer was set to print on photopaper and you have regular paper on the tray, the printer will do a "Load MPF".
The paper sensor on it is amazingly (for a Dell, that is) sensitive and it can differentiate across a lot of paper types/thickness. If you have several computers and user across a network, and there are several paper-type settings done on the printer itself, this "Load MPF" issue will present itself more often.
In my case, it's simply because the person who recently changed the paper-type to glossy cover paper from some user who previously printed to a transparency forgot to revert MPF/Tray 1 to regular copy/print paper. Most cases, the printer setting on the PC has been left to print on to a transparency by default, so even if I stack the tray with copy paper to the hilt, it still will do "Load MPF".
Jul 25, 2009 | Dell 3010cn Laser Printer
Load paper error message when using legal paper. Paper tray is full and still get message. Loaded feeder tray and got clear paper jam. Yet letter size paper worked in the paper tray.
you have to program the paper size anytime you change the size of paper you use in a lot of panasonic machines. This is done through the
function" feature... go intofunction... general settings...scroll down to key operator mode...the code will be "00000000" (8- 0's) and it will be in one of the first screens up
Jul 06, 2009 | Panasonic Workio DP-1820E Copier
I have a T620 that won't print from the trays because it continues to show ''Load MP tray'' on the display. When I drop down the tray and load the multi-purpose feeder, it will print what's in the queue....
Turns out that the paper tray was damaged - the tray was unable to determine the correct paper size, despite fooling with the green paper stop. I had to compare it with a known-good tray to see the problem.
Apr 28, 2009 | Lexmark Optra T620 Laser Printer
HP Photosmart C 7280 paper feed problem
check the feed tray is good, if so.
Clean the feed rollers,
Lint free cloth, distilled water.
Should be good.
Regards
Richard.
Apr 18, 2009 | Office Equipment & Supplies
Loading paper
is the tray going up when you put the paper in and close it? is the sensor there? there has to be a lever that is free floating in the tray, when you put paper it goes up and shows has paper, when out it goes down for add paper.
Jan 14, 2008 | Canon FAX-L1000 Plain Paper Laser
Fax does not know paper is loaded. says load paper
When you load your paper, you must press the Stop/Reset button for it to reconize you have loaded paper.
Nov 17, 2007 | Canon FAXPHONE L80 Laser
HP PhotoSmart 7260 InkJet Printer Logo
217 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
