Question about Maytag HAV3460AWW Top Load Washer
My washer filled with water and now wont do anything. ... If I leave it on it smells like it's burning. Can you help? ...thank you
  • 403 Answers
I'm sorry to let you know that your spin motor is out. This probably happened from over loading it. The repair on this is costly as everything is on the bottom and quite a few things are attached to it. The motor will run about $150.00 and if the unit is over 6 years old will probably only be found at a specialty store. Best bet go to craigslist and find one. There are some really good deal there. Let me know if I can help you with anything else.
JimmyC
Posted on Sep 25, 2009
Burning smell while washer fills
Sound like something else isn't turning because it's jammed
the the motor is trying to turn.
May also be the starting capacitor.
Oct 16, 2013 | Maytag Washing Machines
Kenmore 70 series washing machine filled up with water today but wont spin it just humms. smelled a little burning smell
check the belt/coupling for failure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2010 | Kenmore 24032\24036 Top Load Washer
Washer won't do anything but fill.
It is very likely that the motor has burned out. What happens is that the water solenoid allows water to fill to a certain point where a fill sensor stops it. The program then moves on to activate the motor which will agitate the wash. So when power is supplied to the motor, it tries to start, overheats because of a break down of insulation in the windings, and you smell burning. Replace the motor.
Nov 18, 2009 | Maytag Atlantis MAV6260AWW Top Load Washer
Foul water smell coming from washer after using machine.
Check the hoses to make sure there are no leaks or standing water behind. Try running a cycle or two of vinegar water and baking soda water to kill any mildew that might be in the tub.
New washers often give off an odor described as a burning match or electrical smell. This is normal and is caused by the "wearing in" of clutch shoes and the heating of new paint on the motor windings.
Older washer odors are usually caused by leaving the washer lid closed when not in use. This does not allow air to circulate and dry out the moisture remaining in tub area. The air and moisture mixture becomes stagnant and creates an odor. When washer is not in use, leaving the lid up/open for air circulation will help prevent odor.
To get rid of odors inside of washer follow the steps listed below:
  1. Fill the washer with hot water; set at regular speed & longest time.
  2. Add 3/4 cup of Calgon Clothes Detergent. (Baking soda can be substituted) .
  3. Allow washer to complete entire wash and rinse cycle.
  4. If odor lingers, repeat entire process.
Oct 18, 2009 | Washing Machines
Whirlpool Ultimate Care II washer went dead during fill cycle
Start with the capacitor. It has a funny smell when they go bad. The motor will smell bad as well when it burns up.
May 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
MY WASHER FILLED UP WITH WATER, BUT THEN IT JUST QUIT WORKING.
I believe it is your lid switch. I have replaced 3 this week. If you get me the model number i can tell you for sure. Another thing that caused this is the motor to go bad. Do you smell a burning smell when it is trying to run after the fill up? If not get me the model number and i will get you the part number for the lid switch.
Nov 21, 2008 | Maytag PAV2300 Top Load Washer
Whirlpool noise
Ok can you take the front panel of the washer off easily?
If you can look for the motor pump assembly. Start the washer with no load, turn the water level down to the small and fill with water when it goes into agitation does it make the noise? if not turn timer to spin and see if motor makes the noise.
One other thought, maybe the smell is coming from the dryer?
Let me know. I wont be on line again until Friday Sorry
May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
My maytag washer has a burning smell.
What model do you have.?It doesn't sound like it was spinning.A frozen pump would make the belt burn and it would leave some water in the tub .
Oct 18, 2007 | Fisher and Paykel GWL11 Top Load Washer
Maytag HAV3460AWW Top Load Washer Logo
133 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
