Question about Clarion DXZ545MP CD Player
G'day, I have owned and looked after my DXZ735 MP since 2004 and have recently had a new pickup fitted and a full service, along with some new firmware. The Title 'tags' have never worked properly and I have decided to do some mp3 cds with the full readout displayed on my deck. So far I have burnt 1 Mp3 cd with ID3 version 2.1, 1 with version 1.1, next I will try version 1, maybe!? I was using windows media player 10, now I am using Itunes program for windows. Can you please tell me the exact program, ID3 tag version and anything else I need to know to burn a disc that will enable my deck to do what it is supposed to do. Thanks, Glenn. The only thing I get at present is ROOT.
  • 315 Answers
I don't think there is anything wrong with how your doing the ID3-tag..
Have you tried pressing the [D] button while playing one of these disc's..
It sounds to me like it's reading the CD title as the ROOT (main) folder.
I found this in the manual:
Displaying CD titles
This unit can display title data for CD-text/MP3/ WMA disc and user titles input with this unit.
1. Press the [D] button to display the title.
2. Each time you press and hold the [D] button for 1 second or longer, the title display changes in the following order:
User title (disc) ? CD-text title (disc) ? Artist name ? CD-text title (track) ? User title (disc)... Folder ? File ? Album TAG ? Artist TAG ? Title TAG ? Folder...
For more info have a look at the online manual:
http://www.clarion.com/us/en/MungoBlobs/89/552/DXZ735MP(Manual).pdf
You will find the info on page 12 through to 13.
Regards
Mike
Posted on May 27, 2010
Would full dashboard have to be removed to fit new fusebox Vauxhall vivaro 1.9 2900 reg 2004
Without the factory service manual I would need to look at the fuse box and how it is connected, but based on my past experiences with GM products I would say no.
Jan 27, 2017 | Vauxhall Cars & Trucks
1990 Yamaha DTR 125
Hi, Jonathan after careful deliberation 4 out 5 Yamaha Gods give this one a thumbs up, but just to be on the safe side you should give your local dealer's parts/service department a call to confirm. Good luck and have a nice day.
Yamaha dt 125 1988 Service manual Download service repair owne
Yamaha Owner Manuals
Yamaha DT parts book list and service manuals free download
Yamaha DT 125 1991
Feb 07, 2016 | Yamaha Motorcycles
CL radio/cd not working
If the battery was installed crossed it could blow the system. There is a fuse in the radio itself that should be checked.
Feb 10, 2014 | 2004 BMW R 1200 CL
2004 hyundai sonata starts getting hot and will overheat in 100 plus degree wheather with airconditioner on. water pump, radiator, thermistat, temp sending unit and cap all new. fans and relays all working...
Timing Belt jumped a tooth or two.
Old Spark Plugs --change every 3 years
Front Oxygen Sensors-change at 100,000
Use full synthetic fluids in that kind of temp
Better be changing your trans every year or two
or that won't last in 80 degree weather
Look at data on those hot days with a professional
scan tool along for the ride
Aug 08, 2013 | Cars & Trucks
New engine fitted on my grande renault scenic 2004 but it has trouble starting and cuts out when going round corners
Are you low on fuel? Try running around with a mostly full tank.
Usually if a motor cuts out when going around a corner it could be low on fuel, or the pump pickup lines are shot...This also could be an electrical issue with a wire that has gotten into trouble when the engine was swapped in.
Jun 28, 2011 | 2005 Renault Sportwagon
Fuel filter replacement
S10 Pickup, Sonoma 2000-2004 Fuel Filter - Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Properly relieve the fuel system pressure.
  3. Remove or disconnect the following:
    Negative battery cable Fuel filler cap Quick connect fittings from the filter Filter feed nut and the clamp bolt Filter and the clamp from the vehicle
    Fig. Fuel filter location along frame rail-2.2L engine
    Fig. Fuel filter location along frame rail-4.3L engine
To install:
  1. Install or connect the following:
    NOTE The filter has an arrow (fuel flow direction) on the side of the case, be sure to install it correctly in the system, the with arrow facing away from the fuel tank.
    Filter and clamp with the directional arrow facing away from the fuel tank, toward the throttle body
    Fuel feed nut Filter clamp assembly bolt Fuel quick disconnect fittings to the filter Fuel filler cap Negative battery cable
  2. Check for fuel leaks as follows:
    1. Turn the ignition ON for 2 seconds.
    2. Turn the ignition OFF for 10 seconds.
    3. Turn the ignition ON .
    4. Check for leaks.
Hope this help.
Apr 09, 2010 | 2002 Chevrolet S-10
Ink absober is full error 2 and 7 canon MP 160
it looks like you will need to take to a service center to get it replaced. You probably have used your machine a lot and the waste pads are full.
Apr 17, 2009 | Office Equipment & Supplies
Starting
Sometime all of the small engins will only run on high octain gas. Try that first. Also check to see if there is any obstruction in the air way of you air breath, also make sure that it is clean. A dirty filter will file a spark plug out fast and make it hard to crank. The small motor are such low compression, that it takes the high octains gas, plus help the spark plug run cleaner. Also better fuel mileage.
Jan 30, 2009 | 2004 Sym Husky 125
Clarion DXZ545MP CD Player Logo
144 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
