Question about Bosch Washing Machines
Water comes out - Bosch Washing Machines
  • 403 Answers
Bad news. The motor housing under your washer is bad. Replacement is kinda expensive around $150.00 and that does not include labor. You might think about looking at craigslist for another. Hope this helps. Let me know if I can help you with anything else.
JimmyC
Posted on Sep 25, 2009
SM 8525492A whirlpool washer rinse cycle no water comes out, just hums
when the washer goes into rinse cycle it only uses cold water so clothes don't rinkle,so most likey you have a problem with your cold water,do this,shut down the water to the washer,remove the water lines from the back of washer and mark them so you know how they came off,stick the hoses into the washer if they reach or a bucket,turn on the cold water to see if water is coming out of hose,if water does come out of hose good then stick the cold water hose back on the washer and run it only on cold,if it doesn't fill then you know you have a problem with the water valve on the washer and it's not the house water valve that's bad,and usually if you have a problem with the washer water valve it will just hum and no water will enter the washer so if you hear a humming sound it will be the water valve.tried looking up the model number you sent but it doesn't come up on the parts lookup
Apr 25, 2013 | Washing Machines
Water is coming from the back of the refrigerator
Hi
If water comes from the back of the refrigerator then it usually indicates that water is coming from either the ice maker water valve or line or from the defrost drain pan.
If the water is coming from the ice maker water valve, check to make sure the water tubes are attached properly and are fastened tightly.
If the water seems to be coming from any part of the valve itself, replace the valve.
If the water appears to be coming from the defrost drain pan, inspect for holes or cracks, and replace the pan if necessary.
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Sep 01, 2010 | Frigidaire FRT18FS6C Top Freezer...
Water does not come through to the icemaker or the water outlet. Is there a valve some place in side the ***? water is come to the *** but is it.
water comes to a valve1765e9d.jpgIt has a small line and a bigger line. The big line is for water in the door. The small lines goes up to ice maker.
Jul 11, 2010 | Refrigerators
The hot water will not come on intermitently. I
if your on a private well, it sounds as though your loosing enough water pressure to shut the heater off,.(which is right before the water pump comes on),....tankless heaters turn on by sensing water flow, and of course off when flo stops,......water pressure tanks often need to be re-charged with air for pressure to stay even,....does your water pressure fluctuate?
Jan 10, 2010 | Rheem EcoSense by 7.4 GPM Tankless Water...
Rear water leak
Hi
Water coming from the back of the refrigerator usually comes from either the ice maker water valve or line (if there is an ice maker), or from the defrost drain pan.
Here's what to do:
  • If the water is coming from the ice maker water valve, check to make sure the water tubes are attached properly and are fastened tightly.
  • If the water seems to be coming from any part of the valve itself, replace the valve.
  • If the water appears to be coming from the defrost drain pan, inspect for holes or cracks, and replace the pan if necessary.
Please revert for further assistance and Do accept the solution if found useful.
Thanks
Rylee
Mar 18, 2009 | Refrigerators
Water continousily comes out of water dispensor
u need to replace your microswitch and probably the pad depending on make and model
Water is coming out from under the dryer while drying clothes.
only one place water can come from a dryer area and that is if your vent duct comes out top of house or vent housing is pointed up and they catch water if it rains hard ,,, i would check my water for leaks or if you have a hot water tank close check it too ,,, water may be coming from washer and flowing down hill to under dryer and then running out ,,,, your dryer isn't leaking water i bet / larry
Dec 04, 2008 | Dryers
Mavt634 cold water comes out the hot water inlet connection
Need to make sure that the water connections are correct - first that the hot water hose and cold water hose have not been interchanged and then if they are correct try interchanging the electrical connections to the water valves.
Mar 10, 2008 | Washing Machines
Washing Machines Logo
15 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
