Question about Apple iPhone Smartphone
Add music without itunes .
My itunes keep saiding that it cant local folder . i found copy trans manager. google ot and download it and install it and then play with it .i love it .no more itunes
Can not get Apple itunes on my PC will not download.
Wich browser do you use ?? In Internet Explorer you Schall accept the download
Jun 05, 2014 | Computers & Internet
Tip
How do I take Music Off on my iTouch
<p>By default iTunes set to automatically sync your library to your iPod. This is useful for a quick sync, but not to manage your music in a more personal way. The settings can be modified to iTunes all the songs on the iPod that you do not want at this time. Alternatively, if you want to transfer music from your iPod to your computer, what can be done using a third-party program? <br /> <p><br /> <p>iTunes manual settings <br /> <p>1. Connect your iPod to your computer, open iTunes if it does not open automatically. <br /> <p><br /> <p>2. Click the name of your iPod in the iTunes sidebar "on the left to access the control panel of the iPod, and then click the" Summary "tab if it is not selected. <br /> <p><br /> <p>3. Check the box next to "Manually manage music and videos" and click Apply. <br /> <p><br /> <p>4. Add music to your iPod by selecting the songs, click and drag them over the name of your iPod in the sidebar. You can also scroll through the list of music on your iPod and remove all the songs you no longer want. Sync your iPod when you're ready to add or remove songs that you customized. <br /> <p><br /> <p>IPod music transfer <br /> <p>1. Download and install a program like Copy Trans download free iPod or iPod Rip Share Pod. These programs are designed to have the media on your iPod, copy it to your computer. <br /> <p><br /> <p>2. Disable iTunes auto-sync. This is very important that the library is empty and does not want their iPod data, which can prevent the return of cleaning. Click "Edit" then "Preferences". Click the "Devices" tab. Check the box that says "Prevent iPods, iPhones and automatically synchronizes Cases", click "OK" to save your settings. After that, you can close iTunes. <br /> <p><br /> <p>3. Open the program you just installed, and then connect your iPod. The program displays a list of drives on your computer, your iPod will be one of them, but may take some time to appear in the list. Select your iPod in the list and the list of contents appears in the program window. <br /> <p><br /> <p>4. Select the option to export / content from iPod to PC. Choose a folder to store the contents of entry. Since there will be many files are moved to consider a new folder on your desktop and copy all information from your iPod from there. <br />
on Aug 05, 2011 | Computers & Internet
My ipod apple usb is refomatted now is not working
By formatting you will have lost everything on your ipod either download iTunes reset your ipod Apple's iTunes serves its intended purpose but for some users the restraints from the Digital Rights Management (DRM) make iTunes a cumbersome application to use. Luckily, there are many alternatives to using your iPod without iTunes. The easiest ways is to use freeware that can easily be found on the Internet. Some of the applications that you can use to format your iPod are gtkpod, Amarok, Banshee, foobar2000.
After experimenting with these programs, foobar2000 was found to be the most user-friendly and the easiest to set up. It is a clean light weight program and does not eat up a lot of your computer's resources while running. The application, however, is designed to only run on the Windows platform.
Install foobar2000. You can download the latest copy from foobar2000.org. http://www.foobar2000.org/ Once you have installed foobar you need to configure the path to your music library. To do so, click the library tab and scroll down to configure. Next, click the "Add" button on the top right and navigate to your music folder. It may take several minutes for foobar to update your library information. Download the iPod Manager (See Below) and extract the compressed folder. http://yuo.be/ipod.php Please note, you may need a program like 7 zip to extract this file if your computer does not support it. Before beginning the next step, close foobar2000. Navigate to your computer's program files typically found by clicking on "My Computer" in the Start Menu and then clicking on the C drive. From the program file folder locate the foobar2000 folder and open it. Next, open the components folder. Now, drag and drop the foo_dop.dll file from the folder in step three to the components folder you just opened. Close all windows. Open foobar2000 and plug in your iPod. From foobar you can click on "File" at the top left and scroll down to iPod to access settings. You can also right click on individual songs or albums in the foobar menu and select add to iPod.
b>
Jan 27, 2013 | Apple iPod shuffle MP3 Player
I cant get my music of my ipod nano onto my new netbook? i HAVE A NEW NETBOOK WHICH IS WINDOWS 7 AND I CANT TRANSFER MY MUSIC OFF MY IPOD NANO 4GB ONTO MY NETBOOK?
iDevices (iPod, iPhone, etc) usually can only be managed through iTunes. So the first thing you should do is install iTunes (you can download it off Apple's website).
After installing iTunes and connecting your iPod, you must open My Computer then double click your iPod's icon. Then, click on Tools, Options, and in the View tab check the "Show hidden files and folders" option. You should then see an "iPod_Control" folder. Inside it there'll be a "Music" folder, with all your songs. Just drag them back to your computer.
But remember: you can only manage your iPod's music through iTunes. If you add or change songs on your iPod without using iTunes, these songs won't be recognized.
Mar 22, 2011 | Apple iPod nano
How do I download my 7GB iTunes music to my new Sansa 8G clip? Mac G3 OS 10.3.9.
As itunes will not or rather cannot see the Sansa clip you will need to do this manually.
Locate your itunes Folder
Example: Music/Itunes/Itunes media/Music
Once there simply copy and paste or drag and drop each album or artist folder into the clips Music folder
You could also install Windows Media Player for Mac
Once you have it installed
Clik on
Tools
Options
Clik on the Library Tab
Clik on Montitor Folders
Clik add and locate the Itunes/Itunes Media to add that path
Now whatever you add in itunes it will come across to WMP and in turn this player will see your Sansa Clip.. and you can manage it a lot easier using WMP.
Make sure to explore all the settings.. and remember if you want the album to come over from itunes to WMP you can go into these same settings and force it to update simply cliking OK in the Monitor folder settings.
If you want album art.. some may come over.. some may not.. If you must have album art.. prepare to use Amazon to copy and paste.. it's relatively quick and easy to do.
Good luck.. enjoy
Feb 22, 2011 | SanDisk Sansa Clip MP3 Player
My Ipod nano contains all my music. Unable to transfer to laptop
Unfortunately iTunes doesn't let you transfer anything other than your iTunes store purchases from your iPod.
Totransfer all your iPod content, all your music, playlists, videos,podcasts and photos to your new iTunes library you will need todownload software like TouchCopy.
Here is how to use TouchCopy
  1. Download and Install TouchCopy. Downloads are free and are available for both PC and Mac.
  2. Start up TouchCopy by double-clicking the TouchCopy icon on your desktop
  3. Connect your iPod or iPhone to your computer. TouchCopymay start iTunes - don't worry, TouchCopy has fixed it so that iTuneswill not sync music or video with your iPod while TouchCopy is running.These changes are restored when you quit TouchCopy.
  4. Now select which songs you want to copy into iTunes, if you want toselect all your music, select "Music" from the list on the left andclick on "Copy to iTunes" button in the TouchCopy control bar. In a similar way, you can also use TouchCopy to copy your playlists, videos, podcasts, photos, contacts, calendars and notes.
  5. Whenyou are satisfied that all your iPod content is safely in iTunes, useiTunes to re-sync your iPod which will enable you to add new content toit.
Jan 11, 2010 | Apple iTunes
Itunes file twice the size as library
when you add music to your itunes library, it copies them to the itunes music folder for itunes to manage it or itunes has every song twice in its library, to check whether itunes has not copied your music twice, view your music in LIST VIEW in itunes and if you see some songs has been copied twice delete on of them.
You can also delete the songs on your music folder to save disk space or you can leave them if you use another music player other than itunes.
But I think you should delete the files in your music folder.
Nov 04, 2009 | Computers & Internet
I cant open my itunes on yt desktop
Backup your "My Music" folder to a DVD-writable disk or to an external hard-drive.
Use 'Add/Remove Programs' to uninstall iTunes.
Download the newest version of iTunes from http://www.apple.com/itunes
Install iTunes -- it should find all your music in your "My Music" folder, and import the music.
Oct 22, 2009 | Microsoft Windows XP Home Edition
Need to download music from iphone to itunes on computer
I think it works on sharepod
getsharepod.com/download
Mar 14, 2009 | Apple iPhone 3G
I cant get the music from my pc to ipod.
If you have itunes loaded on your pc and your are updating the music from itunes to your ipod it should be okay, unless you have moved the folder which contains your music. If you have you will need to open itunes go to file>add folder to library and add your music folder, It will update your library with your music files. Then plug your ipod in and it should automatically update your ipod if you have already created a playlist for it. hope it helps. theres is a new version of itunes out now. If you haven't got it already then download it (its free) and take it from there. You need to add the music to itunes, just go to add folder (or file) to library and choose the path where your music is. Good luck
Oct 26, 2008 | Apple iPod nano
Apple iPhone Smartphone Logo
53 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
