Question about EliteGroup K7SOM (K7SOM W/CPU) Motherboard
I try to connect external HDD hatachi 160 cannot detect.System used xp.
    President:
  • 267 Answers
Go to start and run. In the command box type
diskmgmt.msc
Click Ok
In the Managament Console you should see your disk. You may need to format
it, or assign it a drive letter.
OR
UPDATE YOUR WINDOWS XP TO XP3
Posted on Sep 25, 2009
Shows up as "Initio Combo Device Class" not a "Disk Drive"
RESOLVED the ISSUE...!!
Hi, Yesterday I get into similar problem of having my USB Drive ( WD passport Elite 320gb ) not being detected by my PC and as soon as I connect to it, Initio Combo device class drivers gets loaded and Drive do not show up in the device list...!!
I tried several options.1. Freezed my hard drive for 12 hrs in the freezer. It did not help me today.2. I have opened the USB drive shell ( becareful, I have damaged it.. see the instructions before you try t ). You can find the 2.5' HDD inside and there will be SATA to USB bridge adapter. I was having doubt on this bridge unit as I read through several blogs.3. luckily I have a unused 2.5' Laptop HDD. So I have removed this bridge unit carefully and tried to connect to my HDD. If the bridge is good, my HDD must be detected right away..But it is the same problem.. It did not work.. Hence I have confirmed that it is the bridge problem..
4. I bought a Rs. 250/- ( 5$ ) 2.5 SATA casing that is available in the market to use the 2.5' SATA HDD through USB. ( actually I do not know where I can buy only the bridge..hence bought the entire unit..which is still cheaper )
5. From the new unit, I have the USB to SATA bridge, which I have connected to my WD HDD SATA USB hard drive... Bingo.........It is detected by OS and I have started copying my important data immediately...
6. This Unit comes with a casing ..hence you may continue using this case... But some units may not fit well..still the bridge is usable..!!
I GOT all my data..with just Rs.250/- ( $5 ) ..I am happy to try this on my own..!!
Good luck with your drive..!!
Jan 01, 2012 | Western Digital My Book Essential 500GB...
My new portable hdd is not getting detected on my xp
Your USB ports may be version 1.1
You need a USB "Y" cable.
The USB Y cable uses two USB ports on your laptop and the third plugs into the external HDD.
Check RadioShack or maybe the vendor has a USB Y cable.
This will work!
Sep 08, 2009 | Computers & Internet
My western digital Passport 320Gb usb drive is not detected
hi ,
looks like u primary hard drive is inside the laptop and so should be displayed as c : drive ,
and the reason , the external hard drive is not displayed seperately is csue ., the external HD  may be added as slave to the internal HD .,
can u tell me ,make a right click on c:/ drive and choose properties : and tell the totalsize dispalyed
Jul 23, 2009 | Western Digital Passport WDXML800UE...
I formatted the drive and erased all content now i dont have the start up software for it to run when i plug it in
My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
What is the problem? & what to do to get back my necessary files stored in the 500 GB HDD.
Can any one help me, please? URGENT.My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
Jun 27, 2009 | Western Digital 320GB MyBook External USB...
Ihave purchased a SeagateFreeagent 500 gb USB external HDD.It was working very well till I tried to create partitions by using Paragan Disk Management software. In the middle of formatting the partition...
After plugging ur HDD, verify the device is detected or not in Device manager and Try Partitioning Again GUI mode (means in XP).. or follow the steps..
1- Go to Computer Management, Click Disk Management
2 - You will find you External HDD in the Right side
3 - Just Right Click the Drive, if it asks Initialize HDD, just Initialize and Create Partition as u like.
Have Fun
- Rajkumar
Mar 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
HDD needs urgent recovery
If the drive is corrupted the data is useless.
May 05, 2017 | Computers & Internet
System can detect Fujitsu MHY2160BH : 160GB HDD, but cant install
it seems that your computer might have a SATA hard drive which could not be detectable by windows xp, try to install vista it will detect it easily.
otherwise use dm (disk manager) for detection and partition.
Dec 17, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
My external harddisk is not detecting
hi kiran,
If you are using Windows 98 then you have to istalled driver for your external USB HDD.
If you are using Windows XP/Vista then the masstorage drivers for USB HDD is allready installed in your system, as it comes with the OS.
Some time due to conflict or bad contact your system might not read the USB devices:
  • Be sure that switch is on (if there is any switch in USB HDD).
  • Try to check the connection.
  • Try in different USB port.
  • Also check the USB cable is good.
If still no success try to use in another system and let me know your feed back.
Thanks
Iqbal
May 21, 2008 | Seagate Barracuda 7200.7 200 GB Hard Drive
EliteGroup K7SOM (K7SOM W/CPU) Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
