Question about HP P5750-69001 - System Board/P4 Motherboard
No light on the display , i have checked fuse wiring everything but nothing coming up on screen
  • 105 Answers
Check to see if power gets to the motherboard, youl know if the cpu fan spins when system is powered on. if not the power pack may be faulty and needs to be changed. confirm by trying anothe rpower pack
Posted on Sep 25, 2009
82 f250 taillights not coming on. Brakelights and all other lights working...checked fuses..checked wiring.replaced light switch just for good measure nothing.
For your tail lamps, the brown wire shows to be voltage, should go hot when you turn on headlamp switch. The black wire is ground. Use a test light, if you haven't already, check voltage and ground.
The tag lamps use the same voltage as tail lamps.
Nov 05, 2017 | Cars & Trucks
Radio quit working
Sounds like someone shorted the wires...you need to look into the entire butcher job and see what wires were touched. Disconnect everything the butcher did and then see if your battery is still drainning power.
Dec 03, 2013 | 2006 Chevrolet Malibu
Toshiba Satellite Ultrabook U945-ST4N02 Windows 8,
Check with the moniter by connecting the VGA Cable. is there any display on moniter if yes then laptop;s screen faulty otherwise motherboard issue.
Oct 11, 2013 | Computers & Internet
2001 Sequoia rear brake lights not working
Check the trailer hitch tap connector in the frame near the rear bumper for corrosion. Use dielectric grease and reconnect the connector
Jun 18, 2017 | 2001 Toyota Sequoia
Battery is brand new, connection is good at the battery. All fuses are good. Turn key on and nothing happens. We ran a wire from the postitive side screw on the fuse box to the pos lead off the battery and...
You've checked the connection from the fuse to the batterie but have you tried to bypass the keyswitch, it could be the switch doesn't connect inside or the key doesn't turn the switch inside.
Jun 11, 2011 | 1987 Suzuki GV 1400 Cavalcade GT
Wifes Acer laptop screen went black, power light is on, fan is running, but nothing comes up on the screen.... We're stumped...
If you reboot it and everything seems normal except there is no display, get a flashlight and examine the screen for a display with no backlight. Maybe it is just the back light power supply that has failed?
Hope that helps.
Jan 15, 2011 | Acer Computers & Internet
Engine stalls at stops and inst cluster goes off w/headlite on
check the alternator charge level .
check the battery + and - are not lossing
if nothing then you have wiring short
Sep 15, 2009 | 1989 Pontiac Grand Prix
Turns on but nothing displays.
it sound like the memory wire is hook up wrong, check the yellow wire first then the red wire if still the same problem, connect the red and the yellow wire together to see if it come on it should come on you might have to run a hot wire from the battery in the dash then hook the yellow wire to it so your memory stays on
Apr 11, 2009 | Dual XDVD8170 Car DVD Player
Acer Aspire 9410 has no picture
it sounds like a problem with the connection with the display, maybe take it apart, and fix the wires
Jan 10, 2009 | Acer Aspire 9410 Notebook
HP P5750-69001 - System Board/P4 Motherboard Logo
115 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
