Question about HP Compaq Evo n610c Notebook
Compaq armada battery does not charge and laptop does not work with ac connection
    Problem Solver:
  • 5 Answers
Your charger is not working so change it
Posted on Sep 25, 2009
5 Suggested Answers
djhollewood
  • 54 Answers
SOURCE: laptop only works with mains power supply connected
When you power your system up do you get a message saying battery charge failure or some other disappointing driver message? Try powering down, removing the battery, and look for a little button on the underneath of the battery. You should be able to press this button and a series of lights will or won't appear. If they light up it means the battery is truly charged. If not there is something wrong with the connection. Try wiping the surface off and replacing the battery. Also make sure the pin that you place into the laptop to charge the battery is free of dust, etc.
Posted on Jan 14, 2009
Nandakishore
  • 304 Answers
SOURCE: how to charge battery in compaq armada e500
You need to connect the power adapter and charge it for some time and check.
Posted on May 09, 2009
  • 8 Answers
SOURCE: compaq armada 110 battery not charging
I'm sorry to here this but in this case you must bring the laptop in the manufacturers service center because they have to replace batt terminals for it to charge them again. It happened to my cousins laptop.
Posted on Apr 06, 2010
SOURCE: Compaq Armada 110 works only, when AC adapter
OK, check the connection IN the laptop make sure they are actually making contact and are actually working. Now IF that is all in order, then I suspect, that your Battery Charger/Internal Power Supply, has faulted, the External and Internal supplies are separate, with exception for tap off to battery charger.
I have had this many times in my shop, you can most likely buy the Power supply sub board assembly and replace it.
Below is a service manual that will show you what to do and the part numbers. Most likely Ebay will be your best bet, or go straight to Compaq or Compaq dealer for the spare parts, or use the 'net.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=Compaq+Armada+110
If you don't wish to DIY, then please get a "Quote" from a Compaq repair Centre
Posted on Oct 15, 2010
My laptop is compaq Armada M700 with Windows XP Professional version 2002, how will i know if my battery is already fully charged? i have been charging it for a day and when I disconnect the charger tha...
From your description it seems the battery hasn't been charged right, so there maybe something wrong with the battery or laptop. First, do a clean to the your Compaq Armada M700 battery and the connection chip on your laptop, then to see if there is something get better. When you charge you laptop, there will be a lights to note the state, do you have noticed? Else if your Compaq laptop battery are used for 2 years please try a new one
Aug 25, 2011 | Compaq Armada M700 Notebook
Compaq Armada 110 works only, when AC adapter (PSU) is connected. I changed a new battery (refurbished) and now fully charged, but when unplug AC cable power will be lost. It was same behaviour with the...
Oct 15, 2010 | Compaq Armada 110 Notebook
Compaq armada 110 battery not charging at all laptop works on power supply perfectly but when cable removed no charge in battery, new battery purchased same problem how can i resolve please
Apr 06, 2010 | Compaq Armada 110 Notebook
Armada E500 notebook Power button not responding.
Unless you took the batteries to a service center, I am dubious about your ability to confirm the main battery is holding a charge. The average lifespan of these kinds of batteries range between 3-5 years and is likely at the end of its lifespan. This would explain the diminishing performance over the last year if there were significant power or power circuit issues, they would likely be observed on AC power as well. This model of laptop requires the battery calibration utility be run in order for the laptop use the battery. In fact, the battery can show a full charge and still not function if the utility and battery have not been properly configured.. . . instructions on HOW TO do this below. If this doesn't FixYa then the battery will need to be replaced (links to replacement sources) www.BatteriesOvernight.com/HP-Batteries,----- OR --- www.new-laptop-battery.com/Compaq/?Compaq-Armada-E500-battery.htm. You will still have to run the configuration utility when you receive your new battery.
Link to Armada e500 manuals:http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01124216/c01124216.pdf
How to run config utility: Standby and hibernation must be disabled for the battery to discharge completely and shut off. To use the Battery Calibration utility, first identify whether the battery requires calibration by launching the Power Management applet as described above. On the Battery Calibration tab, all installed batteries will be displayed in the primary list box. Next to each battery name will be an indication of whether calibration is required for that battery. If calibration is necessary, the phrase “Needs Calibration” will be displayed. Select the battery to be calibrated, and click the Start Calibration button. During calibration, the utility will display an icon on the Windows System Tray to indicate that calibration is in progress. Each phase of calibration (charging or discharging) will also be displayed. Calibration is complete when the icon is no longer displayed in the System Tray. Battery calibration requires several hours for completion. If you choose to continue using the computer during the calibration process, it must be connected to AC power. The calibration process must be allowed to finish without interruption. Performing any of the following actions will prematurely terminate calibration:  Clicking the Stop Calibrating button in the Compaq Power tab.  Unplugging AC power from the computer.  Unplugging the calibrating battery. (This action may result in data loss if a second battery is not installed.)  Undocking the computer.  Pressing the power or standby button.  Powering down or suspending the machine by using the Windows menu. IMPORTANT: If the calibration process is interrupted, it cannot be resumed. You must restart the computer and start the process again.
CALIBRATING WITHOUT THE UTILITY To calibrate a battery on computers without the battery calibration utility, complete the following steps: 1. Remove the second battery, if present, so that only the battery needing calibration remains in the computer. 2. Dock the computer or connect the computer to AC power. 3. Turn on the computer. 4. Check the current battery capacity level by positioning the cursor over the battery icon in the system tray. 5. Allow the battery to charge to 100%. You may use the computer, but the recharging process will require more time. 6. Set the system to “drain” mode on the battery conservation settings by pressing Fn+F7, or select Start > Settings > Control Panel > Power (or Compaq Power in Windows NT). 7. Undock the computer or disconnect the computer from AC power. 8. Restart the computer in MS-DOS mode by clicking Start > Shut Down > Restart the Computer in MS-DOS Mode > OK. 9. Allow the computer to discharge until it shuts off. 10. Dock the computer or reconnect AC power. 11. Allow the computer to charge again to 100% as in Step 5.
Feb 19, 2010 | Compaq Armada E500 Notebook
How to charge battery in compaq armada e500
May 09, 2009 | Compaq Armada E500 Notebook
Laptop only works with mains power supply connected
Aug 30, 2008 | Compaq Armada M700 Notebook
Acer 4200 series
find some one with a charged battery and boot up then. check your battery for a charge.
Nov 19, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700
Always start with the simplest solution first so start by cleaning all the contacts, AC adapter laptop plug, laptop socket, laptop battery contacts and battery contacts. How have you confirmed power output from the AC adapter? have you used a voltmeter to ensure you are getting power at the laptop end? Have you used a voltmeter to test the battery? Assuming you have tried all this don't forget that almost any component can interrupt power on some laptops, however you're 2 main culprits with this kind of problem are usually power controller (voltage regulator) and in some cases, on a laptop of this vintage, the charge controller built in to the battery. Try it with a different battery if you have one.
Aug 10, 2007 | Compaq Armada M700 Notebook
HP Compaq Evo n610c Notebook Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
