Question about Microsoft Computers & Internet
How can I reset tyhe region code on my dvd drive
How can I reset the region code on my dvd drive .
I can't reset it back to region 4 after playing some region 1 DVD's
  • 497 Answers
Normally you have 5 changes allowed. However there are other solutions, you may be able to find a region free firmware solution or for a software
solution go to http://www.dvdidle.com/dvd-region-free.htm or
http://www.tomdownload.com/dvd_software/dvd_fab.htm .
http://www.cdmediaworld.com/hardware/cdrom/dvd_utils_2.shtml
Good Luck!!!!!!!!!!!!!
Posted on Sep 25, 2009
Testimonial: "Thanks for the advice and quick response cheers. :-)"
DVD says wrong region ?
hi Nigel.
Region codes prevent playback of DVDs in other geographical regions. If you receive a region error while playing a DVD with RealTimes, this means that the region code of the DVD does not match the region code of the DVD drive. ... You can play Region 2DVDs only on a DVD drive that is set for Region 2.
Region errors when playing DVDs with RealPlayer - SUPPORT
https://customer.real.com/.../204041263-Region-errors-when-playing-DVDs-with-RealPl...
How do you change the region on a DVD?Click Performance and Maintenance, and then click System. On the Hardware tab, click Device Manager. The DVD Region tab might not be available for all DVD drives. To configure your DVD drive to play discs from other regions, select a geographic area from the list of regions.
(you could try this link but what ever it tells you to do you do so at your own risk.)
Make Your DVD Player Region Free in Seconds
Nov 18, 2017 | Televison & Video
Code multiregion
here is one way:
To change the player region code
1. Be sure players drive is empty (nodISC)
2. Enter following key sequence using remote control:
Enter, 6, >=10, <<, 00F2, Audio, 8, * requested region code here (1-8) *, Subtitle, 1
3. Player will reset and requested region code will be set.
- For example to set region code to 3 press: "Enter, 6, >=10, <<, 00F2, Audio, 8, 3, Subtitle, 1"
To set the player to RCE proof region free
Enter, 6, >=10, <<, 00F2, Audio, 8, 1, Subtitle, 4
3. Player will reset and set to "region-free" and "RCE-free" mode
To restore players factory region code
Enter, 6, >=10, <<, 00F2, Audio, 8, 9, Subtitle, 1
3. Player will reset and set to factory region code
and here is a forum whre you can get more information
http://www.avforums.com/forums/showthread.php?s=df1223ea6de85d218b01e9719ddec248&t=368649
Dec 18, 2007 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I am from New Zealand . I recently played a DVD disc from the U.S. which is region 1. I had to change the region setting on the bluray drive to play it. I tried to play a region 4 disc on it, and after...
Ask the people you purchased the bluray drive to give you instruction on how to reset (usually is about 5 times and then it gets stuck in the last region used, the Blu-ray region is set in the playback software, not the drive.). You may also want to try re-install the software, which resets it. Good luck.
Mar 05, 2011 | Computers & Internet
The dvd player has had he region code changed the maximum amount of times and now i need to reset it back to region 4 i rang compaq and they instructed that i would need to replace the dvd drive is there a...
Region Code is a software embedded within your system. I have never heard of a dvd/drive for a computer using codes, only heard it on dvd players, because the manufacture use it to control movie distrubution in case of illegal copying from another region.. Probraly because it's compaq who has embedded this in there software to help with copyright issues.. You might be able to reflash the code embedded within your computer system dvd-drive. Try downloading http://www.cccp-project.net/, and download the codec, it's able to play avi, svcd, mkv and is region free or you can download this software calll riodvd region free player at download.com which causes some money because you are purchasing their software.
Jan 27, 2011 | Computers & Internet
How do i change my region code back?
There are three options you can try: 1. download the DVD drive's firmware from the manufacturer and re-flash the drive's firmware, this will reset any region code in 99% of all DVD drives. http://www.ehow.com/how_2316521_flash-dv? 2. you can use software that, in realtime as you play the videos back, removes region code out of the file transfer stream from DVD to playback software. The best software to do this that I know of is called "AnyDVD". http://www.slysoft.com/en/anydvd.html 3. use region free DVD playback software like VLC, which is freeware. http://www.videolan.org/vlc/ The first option is the riskiest, if something fails while flashing the firmware, it could disable the drive, but it is 100% FREE. The second option involves buying software and making sure its running before watching any DVD's in the future. The third option is probably the safest, cheapest, and simplest for you. The DVD drive is not going to prevent playback of a region 1 or 2 movie if its set to region 4, its the playback software that makes this decision. If you rely on commercial DVD playback software or Windows Media Player, they will not allow the playback. VLC is region free, it doesn't even check the region the DVD was produced for.
Apr 10, 2010 | Philips DVP5992/37 DVD Player
A friend placed a malaysian cdrw or data dvd in my computer and now my cd/dvd player is juddery. Sound and dvd files play fine off the hard drive. It is the mechanical drive that malfunctions. Can you help...
it's not mechanical fault. In DVD drive,there si one thing called "DVD Regional code"
What are regional codes ?
Motion picture studios want to control the home release of movies in different countries because theater releases aren't simultaneous (a movie may come out on video in the U.S. when it's just hitting screens in Europe). Also, studios sell distribution rights to different foreign distributors and would like to guarantee an exclusive market. Therefore they required that the DVD standard include codes to prevent playback of certain discs in certain geographical regions. Each player is given a code for the region in which it's sold. The player will refuse to play discs that are not coded for its region. This means that a disc bought in one country may not play on a player bought in another country. Some people believe that region codes are an illegal restraint of trade, but no legal cases have established this.
The world is split up into 8 DVD regions:
Region 1: U.S., Canada, U.S. Territories
Region 2: Japan, Europe, South Africa, and Middle East (including Egypt)
Region 3: Southeast Asia and East Asia (including Hong Kong)
Region 4: Australia, New Zealand, Pacific Islands, Central America, Mexico, South America, and the Caribbean
Region 5: Eastern Europe (Former Soviet Union), Indian subcontinent, Africa, North Korea, and Mongolia
Region 6: China
Region 7: Reserved
Region 8: Special international venues (airplanes, cruise ships, etc.)
Old DVD-ROM drives came with a firmware level RPC-1. Software protection was used to control which region is played.
New DVD-ROM drives come with a firmware level RPC-2 with hardware protection. RPC 2 drives have a 5 change limit on regions, once the counter gets to 0 your drive is permanently locked to the last region it was set to. Even if you reformat or move the drive to another system it will still be locked to the last region. There are ways to get around it, some models have resetting tools made by 3rd parties to reset the change limit back to 5 and some also have firmware patches to remove the region lock.
Now as far as solving the problem. Just follow the below instruction.
Windows keeps track of the DVD region and after its initial setting you are allowed to only change it once more. Its possible to reset the counter by performing the following registry change:
Start the registry editor (regedit.exe)
Move to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft
There will be a subkey (the first) of a strange format, e.g. ';t-z% with a single REG_QWORD value
Select the key and delete
Restart the computer
Upon restart you should be able to modify the region again.
I don't think you need to modify as your DVD refional counter will start from 5.
That's it.
Jan 20, 2010 | Advent Netbook
Panasonic dvd-s54 unlock code to make it play region-free
Please follow the steps : To change the player region code
Regards, Jay__uji8
Dec 27, 2009 | Panasonic DVD-S54 DVD Player
I need to change the region from 1 to 4
You have to go to the device manager of the operating system. List the hardware. Right click on the actual dvd drive and select the area that you want to change the region to. It will display the region.
Aug 10, 2009 | HP Pavilion dv5-1160us Notebook
Changing the DVD Region code
The first solution is free VideoLAN player: click here to download VideoLAN.
The second solution is free Remote Selector tool: click here to download Remote Selector. Launch remselec22.exe file. Click Control tab. Choose Enabled, and check all options Region Free, Disable Macrovision, Disable User Prohibition Click Start Player button, and try to play your DVD
Finally Load another firmware for your DVD drive which disables the region code protection.
Jan 26, 2009 | Microsoft Windows XP Professional for PC
since the changes remaining is set to 0, sorry to say that you cna no longer change this to a different regional setting, unless you reinstall the OS,
chances are you have selected the region previously, or somebody else.
Region 6: China
Region 7: Reserved
How to bypass DVD region code protection ?
As we've said, a lot of newer drives are RPC-2 drives these days. Some of these drives don't allow raw access to the drive until the drive firmware has done a regioncheck. But some RPC-2 drives DO allow raw access, so in some cases it is quite possible to use a special software to bypass the protection:
The first solution is free VideoLAN player: click here to download VideoLAN. It might take a long time to initialize DVD. So just pop the disc in your drive and try it out, while you get a coffee.
The second solution is free Remote Selector tool: click here to download Remote Selector. Launch remselec22.exe file. Click Control tab. Choose Enabled, and check all options Region Free, Disable Macrovision, Disable User Prohibition as shown below:
or you can install one of this program:
The region can only be changed five times, before its set permanently.
In WinDVD: if a DVD from a region different than the default one is tried to be played, the dialog box for changing the DVD region code should appear. If that dialog box do not appear, check the region code set in the software:
Click Start, All Programs, Intervideo Win DVD, and Intervideo Win DVD.
Right-click the Win DVD window and select Setup or Properties.
Click the Region tab and check the region code selected.
If there is a 0 in the Changes Until Permanent field, the DVD region code will not be able to be changed again.
If a number from 1 to 4 appears in the Changes Until Permanent field, add a mark in the checkbox of the desired region and click OK. The new region will be set up.
In PowerDVD: the first time you insert a DVD title, to be played on PowerDVD, a small dialogue box will appear. It will set the region code to match that of the DVD title you wish to play. After this the program will be set. However, if you have a region free DVD-ROM drive, you have the option of playing DVD titles from different regions. PowerDVD will allow you to change the region code setting up to five times, and then it will be locked on the region you have listed on your fifth and last change. At that point you will only be allowed to watch DVD titles from that region. To change the region code, from the original setting, just insert the DVD title in your DVD-ROM drive and run PowerDVD. When the software recognizes that the disc is from a different region than what was previously set, a dialogue box will appear. For this example, the Current Region is Region 1. After changing from one region to another, I will have four changes left. The program detected the disc I inserted was from Region 2, so it selected this option. Once I click OK the Current Region will be changed to Region 2 and the DVD title will play.
hope this helps dont forget to mark my solution pls
Aug 07, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
386 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
